Bonjour, je ne sais pas si cela a une relation, depuis la dernière mise a jour et celle du core, j’ai des erreurs de jeeduino dans les Logs du Cron-Execution:
PHP Deprecated: Non-static method jeedouino::StatusBoardDemon() should not be called statically in /var/www/html/plugins/jeedouino/core/class/jeedouino.class.php on line 192
PHP Deprecated: Non-static method jeedouino::FilterDemon() should not be called statically in /var/www/html/plugins/jeedouino/core/class/jeedouino.class.php on line 1948
PHP Deprecated: Non-static method jeedouino::ConfigurePinValue() should not be called statically in /var/www/html/plugins/jeedouino/core/class/jeedouino.class.php on line 4215
PHP Deprecated: Non-static method jeedouino::SendToBoardDemon() should not be called statically in /var/www/html/plugins/jeedouino/core/class/jeedouino.class.php on line 904
PHP Deprecated: Non-static method jeedouino::FilterDemon() should not be called statically in /var/www/html/plugins/jeedouino/core/class/jeedouino.class.php on line 1585
PHP Deprecated: Non-static method jeedouino::GetJeedomIP() should not be called statically in /var/www/html/plugins/jeedouino/core/class/jeedouino.class.php on line 1595
PHP Deprecated: Non-static method jeedouino::GetJeedomIP() should not be called statically in /var/www/html/plugins/jeedouino/core/class/jeedouino.class.php on line 1599
J’ai relancer l’installation des dépendances sans changement.
Cela n’a pas pour le moment d’incidence sur le fonctionnement de mon installation.
Je viens de voir apres avoir lancer une verification général dans la page de configuration que j’ai d’autres programme qui me signalent PHP Deprecated le plugin Mail
Citation
PHP Deprecated: __autoload() is deprecated, use spl_autoload_register() instead in /var/www/html/plugins/mail/3rdparty/PHPMailer/PHPMailerAutoload.php on line 45
Merci de vos réponses.
Cdt
