Bonsoir
Et non
Log complet :
[2021-04-09 19:20:09][INFO] : Trouvé Client Décodeur TV UHD(48:29:52:XX:XX:XX):{"Key":"48:29:52:XX:XX:XX","DiscoverySource":"bridge","Name":"D\u00e9codeur TV UHD","DeviceType":"Set-top Box","Active":true,"Tags":"lan edev mac physical eth flowstats ipv4 ipv6 dhcp events stb orange stellar upnp","FirstSeen":"2021-04-09T14:43:20Z","LastConnection":"2021-04-09T16:44:21Z","LastChanged":"2021-04-09T17:16:07Z","Master":"","Location":"","PhysAddress":"48:29:52:XX:XX:XX","Layer2Interface":"eth3","InterfaceName":"eth3","MACVendor":"","Owner":"","VendorClassID":"sagem","UserClassID":"PC_MLTV_WHD94","ClientID":"01:48:29:52:XX:XX:XX","SerialNumber":"","ProductClass":"","OUI":"","DHCPOption55":"[1,3,6,7,12,15,28,33,42,43,72,121,125]","IPAddress":"192.168.1.20","IPAddressSource":"DHCP","HardwareVersion":"","SoftwareVersion":"","Index":"1209","Actions":[{"Function":"setName","Name":"Edit Name","Arguments":[{"Name":"name","Type":"string","Mandatory":true},{"Name":"source","Type":"string","Mandatory":false}]},{"Function":"setType","Name":"Edit Type","Arguments":[{"Name":"type","Type":"string","Mandatory":true},{"Name":"source","Type":"string","Mandatory":false}]},{"Function":"startEventing","Name":"startEventing","Arguments":[{"Name":"name","Type":"string","Mandatory":true},{"Name":"types","Type":"string","Mandatory":false}]},{"Function":"stopEventing","Name":"stopEventing","Arguments":[{"Name":"name","Type":"string","Mandatory":true}]},{"Function":"getEventLog","Name":"getEventLog","Arguments":[{"Name":"type","Type":"string","Mandatory":true},{"Name":"since","Type":"datetime","Mandatory":false},{"Name":"until","Type":"datetime","Mandatory":false}]},{"Function":"listLiveEventTypes","Name":"listLiveEventTypes"},{"Function":"listLogEventTypes","Name":"listLogEventTypes"},{"Function":"listEventSubscribers","Name":"listEventSubscribers"}],"Names":[{"Name":"PC","Source":"default","Suffix":"1209","Id":"default"},{"Name":"PC_MLTV_WHD94","Source":"UserClassID","Suffix":"1","Id":"UserClassID"},{"Name":"D\u00e9codeur TV UHD","Source":"upnp","Suffix":"","Id":"upnp"}],"DeviceTypes":[{"Type":"Computer","Source":"default","Id":"default"},{"Type":"Set-top Box","Source":"dhcp","Id":"dhcp"},{"Type":"MediaRenderer","Source":"upnp-uuid:00ababad-7947-1048-8a00-482952c668dc","Id":"upnp-uuid:00ababad-7947-1048-8a00-482952c668dc"},{"Type":"Basic","Source":"upnp-uuid:3653efe6-1d0c-53b5-8c55-0fc767087235","Id":"upnp-uuid:3653efe6-1d0c-53b5-8c55-0fc767087235"}],"Locations":[],"Groups":[],"UserAgents":[],"IPv4Address":[{"Address":"192.168.1.XX","Status":"reachable","Scope":"global","AddressSource":"DHCP","Reserved":false,"Id":"192_168_1_XX"}],"IPv6Address":[]}
[2021-04-09 19:20:09][ERROR] : Erreur sur livebox::pull() : [MySQL] Error code : 23000 (1062). Duplicate entry 'Décodeur TV UHD-20' for key 'unique' : INSERT INTO `eqLogic` SET `id` = :id, `name` = :name, `logicalId` = :logicalId, `generic_type` = :generic_type, `object_id` = :object_id, `eqType_name` = :eqType_name, `isVisible` = :isVisible, `isEnable` = :isEnable, `configuration` = :configuration, `timeout` = :timeout, `category` = :category, `display` = :display, `order` = :order, `comment` = :comment, `tags` = :tags
