bonjour,
depuis la derniere version, mon antenne ne s’installe plus.
j’ai mis a jour debian (10->11->12) mais toujours pareil.
voici la log du update:
[2024-08-28 12:51:44] *************************************
[2024-08-28 12:51:44] * Launch install of dependencies *
[2024-08-28 12:51:44] == Version Debian:12
[2024-08-28 12:51:44] == Version Python:3.7.3
[2024-08-28 12:51:44] Reading package lists...
[2024-08-28 12:51:45] Building dependency tree...
[2024-08-28 12:51:45] Reading state information...
[2024-08-28 12:51:47] Some packages could not be installed. This may mean that you have
[2024-08-28 12:51:47] requested an impossible situation or if you are using the unstable
[2024-08-28 12:51:47] distribution that some required packages have not yet been created
[2024-08-28 12:51:47] or been moved out of Incoming.
[2024-08-28 12:51:47] The following information may help to resolve the situation:
[2024-08-28 12:51:47] The following packages have unmet dependencies:
[2024-08-28 12:51:48] dconf-gsettings-backend : Depends: dconf-service (< 0.38.0-2.1~) but it is not going to be installed
[2024-08-28 12:51:48] Depends: dconf-service (>= 0.38.0-2) but it is not going to be installed
[2024-08-28 12:51:48] glib-networking : Depends: glib-networking-services (< 2.58.0-2+deb10u2.1~) but 2.74.0-4 is to be installed
[2024-08-28 12:51:48] Depends: gsettings-desktop-schemas but it is not going to be installed
[2024-08-28 12:51:48] libc6-dev : Breaks: libgcc-8-dev (< 8.4.0-2~) but 8.3.0-6+rpi1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 2 100 2 0 0 27 0 --:--:-- --:--:-- --:--:-- 28
[2024-08-28 12:51:48] == ERROR Your version of Debian (12) or version of Python (3.7.3) is not supported, please update your distribution !
[2024-08-28 12:51:48] ***************************
[2024-08-28 12:51:48] * Install ended *
j’ai tenté l update du python mais je n’y arrive pas :
XXX@raspberrypi:~ $ sudo apt install python3
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Certains paquets ne peuvent être installés. Ceci peut signifier
que vous avez demandé l'impossible, ou bien, si vous utilisez
la distribution unstable, que certains paquets n'ont pas encore
été créés ou ne sont pas sortis d'Incoming.
L'information suivante devrait vous aider à résoudre la situation :
Les paquets suivants contiennent des dépendances non satisfaites :
dconf-gsettings-backend : Dépend: dconf-service (< 0.38.0-2.1~) mais ne sera pas installé
Dépend: dconf-service (>= 0.38.0-2) mais ne sera pas installé
glib-networking : Dépend: glib-networking-services (< 2.58.0-2+deb10u2.1~) mais 2.74.0-4 devra être installé
Dépend: gsettings-desktop-schemas mais ne sera pas installé
libc6-dev : Casse: libgcc-8-dev (< 8.4.0-2~) mais 8.3.0-6+rpi1 devra être installé
E: Erreur, pkgProblem::Resolve a généré des ruptures, ce qui a pu être causé par les paquets devant être gardés en l'état.
XXX@raspberrypi:~ $ sudo apt upgrade python3
Calcul de la mise à jour... Fait
python3 : Pré-Dépend: python3-minimal (= 3.11.2-1) mais 3.7.3-1 devra être installé
Dépend: python3.11 (>= 3.11.2-1~) mais ne sera pas installé
Dépend: libpython3-stdlib (= 3.11.2-1) mais 3.7.3-1 devra être installé
python3-apt : Dépend: python3 (< 3.8) mais 3.11.2-1 devra être installé
python3-cffi-backend : Dépend: python3 (< 3.8) mais 3.11.2-1 devra être installé
python3-crypto : Dépend: python3 (< 3.8) mais 3.11.2-1 devra être installé
python3-dev : Dépend: python3 (= 3.7.3-1) mais 3.11.2-1 devra être installé
python3-gi : Dépend: python3 (< 3.8) mais 3.11.2-1 devra être installé
python3-pycurl : Dépend: python3 (< 3.8) mais 3.11.2-1 devra être installé
python3-systemd : Dépend: python3 (< 3.8) mais 3.11.2-1 devra être installé
python3-venv : Dépend: python3 (= 3.7.3-1) mais 3.11.2-1 devra être installé
E: Paquets défectueux
