Suite à l’installation je tiens le message d’erreur suivant lors de la synchronisation et seule une partie des équipement se synchronisent.
[2024-04-22 15:36:03][DEBUG] : cron:: refresh:''
[2024-04-22 15:36:10][DEBUG] : synchronize:: update:false
[2024-04-22 15:36:10][DEBUG] : synchronize:: scope:array ( )
[2024-04-22 15:36:10][DEBUG] : synchronize:: NAWSApiClient
[2024-04-22 15:36:10][DEBUG] : synchronize:: WS:array ( 'devices' => array ( 0 => array ( '_id' => '70:ee:50:28:8e:b0', 'date_setup' => 1490983765, 'last_setup' => 1696490299, 'type' => 'NAMain', 'last_status_store' => 1713792756, 'module_name' => 'Séjour', 'firmware' => 203, 'last_upgrade' => 1490983766, 'wifi_status' => 57, 'reachable' => true, 'co2_calibrating' => false, 'data_type' => array ( 0 => 'Temperature', 1 => 'CO2', 2 => 'Humidity', 3 => 'Noise', 4 => 'Pressure', ), 'place' => array ( 'altitude' => 128, 'city' => 'Jodoigne', 'country' => 'BE', 'timezone' => 'Europe/Brussels', 'location' => array ( 0 => 4.81191, 1 => 50.7475706, ), ), 'station_name' => 'Home (Séjour)', 'home_id' => '651e632ba9307e8f9a0f1d16', 'home_name' => 'Home', 'dashboard_data' => array ( 'time_utc' => 1713792754, 'Temperature' => 17.6, 'CO2' => 865, 'Humidity' => 54, 'Noise' => 35, 'Pressure' => 1023, 'AbsolutePressure' => 1007.6, 'min_temp' => 16.4, 'max_temp' => 20.1, 'date_max_temp' => 1713736924, 'date_min_temp' => 1713770156, 'temp_trend' => 'stable', 'pressure_trend' => 'down', ), 'modules' => array ( 0 => array ( '_id' => '03:00:00:05:40:40', 'type' => 'NAModule4', 'module_name' => 'SDB', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Temperature', 1 => 'CO2', 2 => 'Humidity', ), 'battery_percent' => 39, 'reachable' => true, 'firmware' => 53, 'last_message' => 1713792752, 'last_seen' => 1713792714, 'rf_status' => 76, 'battery_vp' => 4901, 'dashboard_data' => array ( 'time_utc' => 1713792714, 'Temperature' => 14.3, 'CO2' => 2191, 'Humidity' => 69, 'min_temp' => 12.6, 'max_temp' => 14.5, 'date_max_temp' => 1713792406, 'date_min_temp' => 1713765284, 'temp_trend' => 'up', ), ), 1 => array ( '_id' => '03:00:00:07:4f:c4', 'type' => 'NAModule4', 'module_name' => 'Ch Manu', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Temperature', 1 => 'CO2', 2 => 'Humidity', ), 'battery_percent' => 43, 'reachable' => true, 'firmware' => 53, 'last_message' => 1713792752, 'last_seen' => 1713792746, 'rf_status' => 65, 'battery_vp' => 4967, 'dashboard_data' => array ( 'time_utc' => 1713792746, 'Temperature' => 14.5, 'CO2' => 1236, 'Humidity' => 64, 'min_temp' => 10.3, 'max_temp' => 14.5, 'date_max_temp' => 1713792130, 'date_min_temp' => 1713768905, 'temp_trend' => 'stable', ), ), 2 => array ( '_id' => '03:00:00:05:40:42', 'type' => 'NAModule4', 'module_name' => 'Bureau', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Temperature', 1 => 'CO2', 2 => 'Humidity', ), 'battery_percent' => 71, 'reachable' => true, 'firmware' => 53, 'last_message' => 1713792752, 'last_seen' => 1713792733, 'rf_status' => 68, 'battery_vp' => 5473, 'dashboard_data' => array ( 'time_utc' => 1713792733, 'Temperature' => 16.9, 'CO2' => 1751, 'Humidity' => 56, 'min_temp' => 13.9, 'max_temp' => 16.9, 'date_max_temp' => 1713792118, 'date_min_temp' => 1713764688, 'temp_trend' => 'up', ), ), 3 => array ( '_id' => '05:00:00:03:6e:30', 'type' => 'NAModule3', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Rain', ), 'battery_percent' => 51, 'reachable' => true, 'firmware' => 14, 'last_message' => 1713792752, 'last_seen' => 1713792746, 'rf_status' => 74, 'battery_vp' => 4912, 'dashboard_data' => array ( 'time_utc' => 1713792746, 'Rain' => 0, 'sum_rain_1' => 0, 'sum_rain_24' => 0, ), ), 4 => array ( '_id' => '02:00:00:ab:f3:9c', 'type' => 'NAModule1', 'module_name' => 'Extérieur', 'last_setup' => 1696494605, 'data_type' => array ( 0 => 'Temperature', 1 => 'Humidity', ), 'battery_percent' => 83, 'reachable' => true, 'firmware' => 53, 'last_message' => 1713792752, 'last_seen' => 1713792714, 'rf_status' => 57, 'battery_vp' => 5688, 'dashboard_data' => array ( 'time_utc' => 1713792714, 'Temperature' => 10.5, 'Humidity' => 51, 'min_temp' => 2.6, 'max_temp' => 10.8, 'date_max_temp' => 1713790919, 'date_min_temp' => 1713760157, 'temp_trend' => 'stable', ), ), 5 => array ( '_id' => '06:00:00:01:e7:b6', 'type' => 'NAModule2', 'module_name' => 'Anémomètre', 'last_setup' => 1696585566, 'data_type' => array ( 0 => 'Wind', ), 'battery_percent' => 78, 'reachable' => true, 'firmware' => 27, 'last_message' => 1713792752, 'last_seen' => 1713792752, 'rf_status' => 77, 'battery_vp' => 5545, 'dashboard_data' => array ( 'time_utc' => 1713792752, 'WindStrength' => 4, 'WindAngle' => 237, 'GustStrength' => 8, 'GustAngle' => 302, 'max_wind_str' => 15, 'max_wind_angle' => 322, 'date_max_wind_str' => 1713781864, ), ), ), ), ), 'user' => array ( 'mail' => 'manu@ceulemans.biz', 'administrative' => array ( 'country' => 'BE', 'reg_locale' => 'fr-BE', 'lang' => 'fr-FR', 'unit' => 0, 'windunit' => 0, 'pressureunit' => 0, 'feel_like_algo' => 0, ), ), )
[2024-04-22 15:36:10][DEBUG] : synchronize:: M_UPDATE_IN_PROGRESS:array ( '_id' => '03:00:00:05:40:40', 'type' => 'NAModule4', 'module_name' => 'SDB', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Temperature', 1 => 'CO2', 2 => 'Humidity', ), 'battery_percent' => 39, 'reachable' => true, 'firmware' => 53, 'last_message' => 1713792752, 'last_seen' => 1713792714, 'rf_status' => 76, 'battery_vp' => 4901, 'dashboard_data' => array ( 'time_utc' => 1713792714, 'Temperature' => 14.3, 'CO2' => 2191, 'Humidity' => 69, 'min_temp' => 12.6, 'max_temp' => 14.5, 'date_max_temp' => 1713792406, 'date_min_temp' => 1713765284, 'temp_trend' => 'up', ), )
[2024-04-22 15:36:10][DEBUG] : synchronize:: M_UPDATE_IN_PROGRESS:array ( '_id' => '03:00:00:07:4f:c4', 'type' => 'NAModule4', 'module_name' => 'Ch Manu', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Temperature', 1 => 'CO2', 2 => 'Humidity', ), 'battery_percent' => 43, 'reachable' => true, 'firmware' => 53, 'last_message' => 1713792752, 'last_seen' => 1713792746, 'rf_status' => 65, 'battery_vp' => 4967, 'dashboard_data' => array ( 'time_utc' => 1713792746, 'Temperature' => 14.5, 'CO2' => 1236, 'Humidity' => 64, 'min_temp' => 10.3, 'max_temp' => 14.5, 'date_max_temp' => 1713792130, 'date_min_temp' => 1713768905, 'temp_trend' => 'stable', ), )
[2024-04-22 15:36:10][DEBUG] : synchronize:: M_UPDATE_IN_PROGRESS:array ( '_id' => '03:00:00:05:40:42', 'type' => 'NAModule4', 'module_name' => 'Bureau', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Temperature', 1 => 'CO2', 2 => 'Humidity', ), 'battery_percent' => 71, 'reachable' => true, 'firmware' => 53, 'last_message' => 1713792752, 'last_seen' => 1713792733, 'rf_status' => 68, 'battery_vp' => 5473, 'dashboard_data' => array ( 'time_utc' => 1713792733, 'Temperature' => 16.9, 'CO2' => 1751, 'Humidity' => 56, 'min_temp' => 13.9, 'max_temp' => 16.9, 'date_max_temp' => 1713792118, 'date_min_temp' => 1713764688, 'temp_trend' => 'up', ), )
[2024-04-22 15:36:10][DEBUG] : synchronize:: M_CREATE_IN_PROGRESS:array ( '_id' => '05:00:00:03:6e:30', 'type' => 'NAModule3', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Rain', ), 'battery_percent' => 51, 'reachable' => true, 'firmware' => 14, 'last_message' => 1713792752, 'last_seen' => 1713792746, 'rf_status' => 74, 'battery_vp' => 4912, 'dashboard_data' => array ( 'time_utc' => 1713792746, 'Rain' => 0, 'sum_rain_1' => 0, 'sum_rain_24' => 0, ), )
[2024-04-22 15:36:10][DEBUG] : createEqLogic:: data:array ( '_id' => '05:00:00:03:6e:30', 'type' => 'NAModule3', 'last_setup' => 1696490283, 'data_type' => array ( 0 => 'Rain', ), 'battery_percent' => 51, 'reachable' => true, 'firmware' => 14, 'last_message' => 1713792752, 'last_seen' => 1713792746, 'rf_status' => 74, 'battery_vp' => 4912, 'dashboard_data' => array ( 'time_utc' => 1713792746, 'Rain' => 0, 'sum_rain_1' => 0, 'sum_rain_24' => 0, ), )
[2024-04-22 15:36:10][DEBUG] : createEqLogic:: name:NULL
[2024-04-22 15:36:10][DEBUG] : loadConfigFile::
[2024-04-22 15:37:03][DEBUG] : cron:: refresh:''
La connexion avec les différentes clientID/secret vers l’application Netatmo a été confirmé opérationnelle.
Auriez vous une piste ou solution à proposer ?
