bonjour,
J4ai remqué que j’avais plusieurs erreurs de ce type dans les logs http.error et je voudrais essayer de comprendre ce que ca veut dire :
0000|[Wed Apr 12 19:20:28.321430 2023] [php7:error] [pid 19150] [client 20.54.163.231:0] PHP Fatal error: Uncaught Exception: [MySQL] Error code : 42S02 (1146). Table 'jeedom.NAEvent' doesn't exist : INSERT INTO NAEvent
0001|(`logicalId`,`json`) VALUES (?,?) in /var/www/html/core/class/DB.class.php:102
0002|Stack trace:
0003|#0 /var/www/html/plugins/netatmopro/core/php/NAWebhookClient.php(44): DB::Prepare('INSERT INTO NAE...', Array, 0)
0004|#1 {main}
0005|thrown in /var/www/html/core/class/DB.class.php on line 102
0006|[Wed Apr 12 19:44:45.623788 2023] [php7:error] [pid 18965] [client 20.54.163.231:0] PHP Fatal error: Uncaught Exception: [MySQL] Error code : 42S02 (1146). Table 'jeedom.NAEvent' doesn't exist : INSERT INTO NAEvent
0007|(`logicalId`,`json`) VALUES (?,?) in /var/www/html/core/class/DB.class.php:102
0008|Stack trace:
0009|#0 /var/www/html/plugins/netatmopro/core/php/NAWebhookClient.php(44): DB::Prepare('INSERT INTO NAE...', Array, 0)
0010|#1 {main}
0011|thrown in /var/www/html/core/class/DB.class.php on line 102
Merci d’avance pour votre aide
