L’installation se fait avec erreur (sur Jeedom Atlas).
Que faire ?
Début de l'installation
Installation mplayer
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400).
mpg123 is already the newest version (1.25.10-2).
mplayer is already the newest version (2:1.3.0-8+b4).
software-properties-common is already the newest version (0.96.20.2-2).
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
libttspico-utils:armhf : Depends: libc6:armhf (>= 2.4) but it is not going to be installed
Depends: libpopt0:armhf (>= 1.14) but it is not going to be installed
Depends: libttspico0:armhf (>= 1.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Installation PicoTTS
libsox-fmt-mp3 is already the newest version (14.4.2+git20190427-1).
sox is already the newest version (14.4.2+git20190427-1).
(Reading database ... 59973 files and directories currently installed.)
Preparing to unpack libttspico-data_1.0+git20130326-3_all.deb ...
Unpacking libttspico-data (1.0+git20130326-3) over (1.0+git20130326-3) ...
Setting up libttspico-data (1.0+git20130326-3) ...
dpkg: regarding libttspico0_1.0+git20130326-3_armhf.deb containing libttspico0:armhf, pre-dependency problem:
libttspico0:armhf pre-depends on multiarch-support
dpkg: error processing archive libttspico0_1.0+git20130326-3_armhf.deb (--install):
pre-dependency problem - not installing libttspico0:armhf
Errors were encountered while processing:
Preparing to unpack libttspico-utils_1.0+git20130326-3_armhf.deb ...
Unpacking libttspico-utils:armhf (1.0+git20130326-3) over (1.0+git20130326-3) ...
dpkg: dependency problems prevent configuration of libttspico-utils:armhf:
libttspico-utils:armhf depends on libc6 (>= 2.4).
libttspico-utils:armhf depends on libpopt0 (>= 1.14).
libttspico-utils:armhf depends on libttspico0 (>= 1.0); however:
Package libttspico0:armhf is not installed.
dpkg: error processing package libttspico-utils:armhf (--install):
dependency problems - leaving unconfigured
Processing triggers for man-db (2.8.5-2) ...
Ajout de www-data dans le groupe audio
Fin de l'installation
