Une petite question sur le plugin Harmony. Je constate de nombreuses erreurs dans le log http.error :
[Sun May 08 23:01:25.710634 2022] [access_compat:error] [pid 3663500] [client 192.168.x.y:38318] AH01797: client denied by server configuration: /var/www/html/api
[Sun May 08 23:02:38.625337 2022] [access_compat:error] [pid 4191989] [client 192.168.x.y:53363] AH01797: client denied by server configuration: /var/www/html/api
[Sun May 08 23:04:01.531571 2022] [access_compat:error] [pid 1575697] [client 192.168.x.y:53365] AH01797: client denied by server configuration: /var/www/html/api
[Sun May 08 23:05:35.016320 2022] [access_compat:error] [pid 1575697] [client 192.168.x.y:53366] AH01797: client denied by server configuration: /var/www/html/api
Ces erreurs surviennent environ 30s après que le log du plugin Harmony indique un « show current activity »:
[2022-05-08 23:01:01]DEBUG : Execution de :sudo /usr/bin/python /var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py --harmony_ip HarmonyHub.lan show_current_activity
[2022-05-08 23:02:02]DEBUG : Execution de :sudo /usr/bin/python /var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py --harmony_ip HarmonyHub.lan show_current_activity
[2022-05-08 23:03:01]DEBUG : Execution de :sudo /usr/bin/python /var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py --harmony_ip HarmonyHub.lan show_current_activity
[2022-05-08 23:04:01]DEBUG : Execution de :sudo /usr/bin/python /var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py --harmony_ip HarmonyHub.lan show_current_activity
[2022-05-08 23:05:04]DEBUG : Execution de :sudo /usr/bin/python /var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py --harmony_ip HarmonyHub.lan show_current_activity
L’IP « 192.168.x.y » du log correspond à mon HUB Harmony. Quelqu’un d’autre à ce problème ?
J’ai pu trouver des pistes ou ça parle de requêtes anormales et qui conseillent d’installer fail2ban mais là le contexte me semble différent. On est sur une ip interne, la fréquence correspond au polling de l’activité.
