je viens d’observer une erreur dans le cron_execution concernant le plugin APS ECU.
est ce une erreur de config de ma part ou est ce normal (par exemple la nuit lorsque pas de connexion au PV) ?
voici mon log
0000|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 115
0001|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 174
0002|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 147
0003|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 115
0004|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 174
0005|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 147
0006|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 115
0007|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 174
0008|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 147
0009|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 115
0010|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 174
0011|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 147
0012|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 115
0013|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 174
0014|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 147
0015|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 115
0016|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 174
0017|PHP Warning: socket_set_timeout(): supplied resource is not a valid stream resource in /var/www/html/plugins/aps_ecu/core/class/aps_ecu.class.php on line 147
