Hello à tous,
Suite à la dernière mise à jour stable du plugin (2023-07-12 01:00:23), et la relance des dépendances je me retrouve avec une erreur sur la lib rust / cryptography et donc impossible de lancer le démon.
Jeedom v4.3.17 stable
RPi 4 sous buster uptodate
Page santé
Logs dépendances :
* Launch install of dependencies *
Tue Jul 18 21:22:24 CEST 2023
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
Reading package lists...
Install modules using apt-get
Building dependency tree...
Reading state information...
python3 is already the newest version (3.7.3-1).
python3-requests is already the newest version (2.21.0-1+deb10u1).
python3-setuptools is already the newest version (40.8.0-1).
python3-venv is already the newest version (3.7.3-1).
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
ffmpeg is already the newest version (7:4.1.11-0+deb10u1+rpt1).
Creating python 3 virtual environment
Done
Install the required python libraries
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (23.2)
Requirement already satisfied: wheel in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (0.40.0)
Collecting cryptography
Using cached cryptography-41.0.2.tar.gz (630 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Requirement already satisfied: monotonic>=1.5 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (1.6)
Requirement already satisfied: urllib3>=1.26 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (2.0.3)
Requirement already satisfied: requests>=2.31 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (2.31.0)
Requirement already satisfied: sseclient==0.0.18 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (0.0.18)
Requirement already satisfied: cloudscraper>=1.2.70 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (1.2.71)
Requirement already satisfied: six in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (from sseclient==0.0.18) (1.16.0)
Collecting cffi>=1.12 (from cryptography)
Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
Requirement already satisfied: charset-normalizer<4,>=2 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (from requests>=2.31) (3.1.0)
Requirement already satisfied: idna<4,>=2.5 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (from requests>=2.31) (3.4)
Requirement already satisfied: certifi>=2017.4.17 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (from requests>=2.31) (2023.5.7)
Requirement already satisfied: requests-toolbelt>=0.9.1 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (from cloudscraper>=1.2.70) (1.0.0)
Requirement already satisfied: pyparsing>=2.4.7 in /var/www/html/plugins/arlo/resources/venv/lib/python3.7/site-packages (from cloudscraper>=1.2.70) (3.0.9)
Collecting pycparser (from cffi>=1.12->cryptography)
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
Building wheels for collected packages: cryptography
Building wheel for cryptography (pyproject.toml): started
Building wheel for cryptography (pyproject.toml): finished with status 'error'
error: subprocess-exited-with-error
× Building wheel for cryptography (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [172 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-cpython-37
creating build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
creating build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
running egg_info
writing src/cryptography.egg-info/PKG-INFO
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
/tmp/pip-build-env-fbv8s7g0/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
config = read_configuration(filepath, True, ignore_option_errors, dist)
warning: no files found matching '*.c' under directory 'src/_cffi_src'
warning: no files found matching '*.h' under directory 'src/_cffi_src'
no previously-included directories found matching 'docs/_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files found matching 'src/rust/target'
warning: no previously-included files matching '*' found under directory 'src/rust/target'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'ci-constraints-requirements.txt'
warning: no previously-included files found matching 'mypy.ini'
adding license file 'LICENSE'
adding license file 'LICENSE.APACHE'
adding license file 'LICENSE.BSD'
writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
running build_ext
running build_rust
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Read https://cryptography.io/en/latest/installation/ for specific
instructions for your platform.
3) Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq/
4) Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation/#rust
Python: 3.7.3
platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
pip: n/a
setuptools: 68.0.0
setuptools_rust: 1.6.0
rustc: n/a
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.56.0.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
ffmpeg version 4.1.11-0+deb10u1+rpt1 Copyright (c) 2000-2023 the FFmpeg developers
built with gcc 8 (Raspbian 8.3.0-6+rpi1)
configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
libpostproc 55. 3.100 / 55. 3.100
Tue Jul 18 21:22:57 CEST 2023
* Install ended *
J’ai un problème similaire sur ma plateforme de dev avec les mêmes libs (rust / cryptography) sur un jeedom en 4.4 alpha avec le plugin de @nebz plugin-atvremote. J’ai pas mal fouiné sur les forums et testé bcp de commandes en ligne sans succès. A priori lié à Buster. Le pb n’existe pas sous Bullseye.
Si jamais certains ont trouvé la solution, je suis preneur, sinon je migrerai sous bullseye ce week-end
Merci d’avance
Xav
