Hello ![]()
suite à l’achat d’une clim daikin en 2024, j’ai installé et abandonné le plugin après quelques tentatives infrustueuses (debian 10 à l’époque) ![]()
Ayant réinstallé Jeedom sur un nouveau rpi3 et une debian 11, je n’arrive pas à démarrer le plugin ![]()
J’ai ce message d’erreur (je n’ai rien trouvé d’équivalent sur le forum) :
[main.ts] => Starting DaikinToMQTT
[2025-03-30 20:03:54.941] info: [main.ts] => Load configuration
[2025-03-30 20:03:54.972] info: [main.ts] => Connect to MQTT
[2025-03-30 20:03:55.187] info: [main.ts] => Connect to Daikin
[2025-03-30 20:03:55.195] info: [main.ts] => DaikinToMQTT Started !!
[2025-03-30 20:03:55.198] debug: [daikin.ts] => Cache invalid ou recup forcé, recuperation information sur le cloud
[2025-03-30 20:03:55.199] debug: [daikin.ts] => Send Request to cloud : Refresh
============> [Daikin - oidc-client.ts] [1743357835202] - Get Token - Start
============> [Daikin - oidc-client.ts] [1743357835223] - Get Token - TokenOK=> Authorize => Start
============> [Daikin - oidc-client.ts] [1743357835224] - Authorize - START
[2025-03-30 20:03:55.531] info: [daikin.ts] =>
Please make sure that https://192.168.0.136:8765 is set as "Redirect URL" in your Daikin Developer Portal account for the used Client!
Then please open the URL https://192.168.0.136:8765 in your browser and accept the security warning for the self signed certificate (if you open this for the first time).
Afterwards you are redirected to Daikin to approve the access and then redirected back.
[2025-03-30 20:03:55.540] debug: [mqtt.ts] => Send Data to MQTT : system/bridge/url
[2025-03-30 20:03:55.542] debug: [mqtt.ts] => Send Data to MQTT : system/bridge/authorization_request
[2025-03-30 20:03:55.544] debug: [mqtt.ts] => Send Data to MQTT : system/bridge/authorization_timeout
============> [Daikin - oidc-client.ts] [1743357847599] - Authorize - FINISH
OPError: invalid_client (Client authentication failed.)
at processResponse (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/openid-client/lib/helpers/process_response.js:38:13)
at Client.grant (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/openid-client/lib/client.js:1381:22)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async #authorize (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/daikin-controller-cloud/dist/onecta/oidc-client.js:65:16)
at async #getTokenSet (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/daikin-controller-cloud/dist/onecta/oidc-client.js:118:24) {
error: 'invalid_client',
error_description: 'Client authentication failed.'
j’accepte bien les conditions sur la page https://192.168.0.136:8765 et j’ai le résultat suivant :
Authorization complete
Thank you for authorizing daikin-controller-cloud to access your devices.
Une idée du problème ?
Merci beaucoup ![]()
