Erreur API
bonjour,
Aujourd’hui, j’ai une erreur sur le plugin :
Erreur sur Diagral_eOne::pull() : Exception Object ( [message:protected] => ttmSessionId is not in the response. Please retry later.{"message":"transmitter.connection.overlimit","details":"Connection has reached the limit per hour transmitter {}"} [string:Exception:private] => [code:protected] => 33 [file:protected] => /var/www/html/plugins/Diagral_eOne/3rparty/Diagral-eOne-API-PHP/class/Diagral/Diagral_eOne.class.php [line:protected] => 389 [trace:Exception:private] => Array ( [0] => Array ( [file] => /var/www/html/plugins/Diagral_eOne/3rparty/Diagral-eOne-API-PHP/class/Diagral/Diagral_eOne.class.php [line] => 344 [function] => createNewSession [class] => Mguyard\Diagral\Diagral_eOne [type] => -> ) [1] => Array ( [file] => /var/www/html/plugins/Diagral_eOne/core/class/Diagral_eOne.class.php [line] => 902 [function] => connect [class] => Mguyard\Diagral\Diagral_eOne [type] => -> ) [2] => Array ( [file] => /var/www/html/plugins/Diagral_eOne/core/class/Diagral_eOne.class.php [line] => 932 [function] => setDiagralEnv [class] => Diagral_eOne [type] => -> ) [3] => Array ( [file] => /var/www/html/core/php/jeeCron.php [line] => 78 [function] => pull [class] => Diagral_eOne [type] => :: ) ) [previous:Exception:private] => )
C’est dommage en effet.
Comme l’indique l’erreur, l’API vous bloque car vous avez fait trop de demandes.
ok merci pour l’aide
