Depuis quelques jours, j’ai le plugin qui ne se lance plus. Si j’en crois le debug, le serveur répond l’erreur 403 sur le GET locations, mais cette erreur n’est pas documentée…
Suis-je le seul dans ce cas?
[2023-05-05 19:35:02][INFO] : Starting daemon
[2023-05-05 19:35:02][INFO] : Log level: debug
[2023-05-05 19:35:02][DEBUG] : Socket port: 55070
[2023-05-05 19:35:02][DEBUG] : PID file: /tmp/jeedom/gardena/deamon.pid
[2023-05-05 19:35:02][DEBUG] : Init request module v2.28.1
[2023-05-05 19:35:06][DEBUG] : token content:
[2023-05-05 19:35:06][DEBUG] : # access_token: eyJhbGciOi...
[2023-05-05 19:35:06][DEBUG] : # user_id: 4ec79bc2-0...
[2023-05-05 19:35:06][DEBUG] : # scope: ['iam:read', 'amc:api', 'sg-integration-api:read', 'sg-integration-api:write']
[2023-05-05 19:35:06][DEBUG] : # expires_in: 86397
[2023-05-05 19:35:06][DEBUG] : # expires_at: 1683394503.8773346
[2023-05-05 19:35:06][DEBUG] : # token_type: Bearer
[2023-05-05 19:35:06][DEBUG] : # provider: husqvarna
[2023-05-05 19:35:06][INFO] : Authentication done
[2023-05-05 19:35:06][INFO] : updating locations
[2023-05-05 19:35:07][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2023-05-05 19:35:07][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2023-05-05 19:35:07][INFO] : Shuting down
[2023-05-05 19:35:07][DEBUG] : Removing PID file /tmp/jeedom/gardena/deamon.pid
[2023-05-05 19:35:07][DEBUG] : Exit 0
Version du plugin : 2023-04-06 10:50:20
