Le plug in fonctionne correctement, par contre j’ai en permanence des erreur « getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API » sur chacune des API et ceci toutes les 2 H
Est ce normal ?
Ci joint extrait du log
[2022-06-07 10:25:06][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 10:25:06][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 10:25:06][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 10:25:06][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 14:30:08][ERROR] : getInfos::vehiclestatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 14:30:08][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 14:30:08][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 14:30:08][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 14:30:09][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 16:35:05][ERROR] : getInfos::vehiclestatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 16:35:05][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 16:35:05][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 16:35:05][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 16:35:05][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 18:40:07][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 20:45:06][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 20:45:06][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 20:45:06][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-07 20:45:06][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 00:50:06][ERROR] : getInfos::vehiclestatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 00:50:06][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 00:50:06][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 00:50:06][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 00:50:06][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 02:55:06][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 02:55:06][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-08 02:55:06][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 01:25:05][ERROR] : getInfos::vehiclestatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 01:25:05][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 01:25:05][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 01:25:05][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 01:25:06][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 05:30:08][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 05:30:08][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 05:30:08][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 05:30:08][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 11:35:06][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 11:35:06][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 11:35:06][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 23:40:06][ERROR] : getInfos::vehiclestatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 23:40:06][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 23:40:06][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 23:40:06][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-09 23:40:06][ERROR] : getInfos::electricvehicle::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-10 15:50:06][ERROR] : getInfos::vehiclestatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-10 15:50:06][ERROR] : getInfos::vehiclelockstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-10 15:50:06][ERROR] : getInfos::fuelstatus::Response Error with code 401 and reason : Invalid or missing authorization/API
[2022-06-10 15:50:06][ERROR] : getInfos::payasyoudrive::Response Error with code 401 and reason : Invalid or missing authorization/API```
