Endpoint Incomplet ou manquant — BRP069A62
Voici un rapport de debug emis par le plugin :
=== DaikinToMQTT Debug Report ===
deviceId: [redacted]
deviceName: [redacted]
gatewayModelRaw: BRP069A62
gatewayModelResolved: BRP069A62
supportStatus: full
configCoverage: incomplete
configCoverageDetail: 29/42 datapoints mapped
firmwareVersion:
serialNumber: [redacted]
daemonVersion: 2.1.9
authMode: developer_portal
detectedAt: 2026-10-12T15:52:35.256Z
supportMessage: Static gateway configuration is incomplete for this API variant. Please open a GitHub issue with the debug report below.
managementPoints: 0, 1, 2, 3, 4, 5
unitModels: {"0":"BRP069A62","1":"[redacted]","3":"ETVZ16S23DA6V"}
apiDatapointsCount: 42
apiDatapointsDetail: [{"key":"0/firmwareVersion","settable":false,"valueType":"string"},{"key":"0/isFirmwareUpdateSupported","settable":false,"valueType":"boolean"},{"key":"0/serialNumber","settable":false,"valueType":"string"},{"key":"0/modelInfo","settable":false,"valueType":"string"},{"key":"0/ipAddress","settable":false,"valueType":"string"},{"key":"0/macAddress","settable":false,"valueType":"string"},{"key":"0/errorCode","settable":false,"valueType":"string"},{"key":"0/isInErrorState","settable":false,"valueType":"boolean"},{"key":"1/name","settable":true,"valueType":"string"},{"key":"1/errorCode","settable":false,"valueType":"string"},{"key":"1/isHolidayModeActive","settable":false,"valueType":"boolean"},{"key":"1/isInErrorState","settable":false,"valueType":"boolean"},{"key":"1/isInWarningState","settable":false,"valueType":"boolean"},{"key":"1/isInInstallerState","settable":false,"valueType":"boolean"},{"key":"1/isInEmergencyState","settable":false,"valueType":"boolean"},{"key":"1/onOffMode","settable":true,"valueType":"string","values":["on","off"]},{"key":"1/setpointMode","settable":false,"valueType":"string","values":["fixed","weatherDependent","weatherDependentHeatingFixedCooling"]},{"key":"1/controlMode","settable":false,"valueType":"string","values":["roomTemperature","leavingWaterTemperature","externalRoomTemperature"]},{"key":"1/sensoryData/outdoorTemperature","settable":false,"valueType":"number"},{"key":"1/sensoryData/leavingWaterTemperature","settable":false,"valueType":"number"},{"key":"1/temperatureControl/operationModes/heating/setpoints/leavingWaterOffset","settable":true,"valueType":"number","minValue":-10,"maxValue":10,"stepValue":1},{"key":"1/operationMode","settable":true,"valueType":"string","values":["heating"]},{"key":"1/targetTemperature","settable":true,"valueType":"number","minValue":-10,"maxValue":10,"stepValue":1},{"key":"2/name","settable":true,"valueType":"string"},{"key":"2/errorCode","settable":false,"valueType":"string"},{"key":"2/isHolidayModeActive","settable":false,"valueType":"boolean"},{"key":"2/isInErrorState","settable":false,"valueType":"boolean"},{"key":"2/isInWarningState","settable":false,"valueType":"boolean"},{"key":"2/isInInstallerState","settable":false,"valueType":"boolean"},{"key":"2/isInEmergencyState","settable":false,"valueType":"boolean"},{"key":"2/isPowerfulModeActive","settable":false,"valueType":"boolean"},{"key":"2/onOffMode","settable":true,"valueType":"string","values":["on","off"]},{"key":"2/powerfulMode","settable":true,"valueType":"string","values":["off","on"]},{"key":"2/heatupMode","settable":false,"valueType":"string","values":["reheatOnly","scheduleOnly","reheatSchedule"]},{"key":"2/sensoryData/tankTemperature","settable":false,"valueType":"number"},{"key":"2/temperatureControl/operationModes/heating/setpoints/domesticHotWaterTemperature","settable":false,"valueType":"number","minValue":30,"maxValue":65,"stepValue":1},{"key":"2/operationMode","settable":false,"valueType":"string","values":["heating"]},{"key":"2/setpointMode","settable":false,"valueType":"string","values":["fixed","weatherDependent"]},{"key":"3/modelInfo","settable":false,"valueType":"string"},{"key":"3/softwareVersion","settable":false,"valueType":"string"},{"key":"4/softwareVersion","settable":false,"valueType":"string"},{"key":"5/softwareVersion","settable":false,"valueType":"string"}]
unmappedDatapoints: 0/isFirmwareUpdateSupported, 0/ipAddress, 0/macAddress, 0/errorCode, 1/name, 1/temperatureControl/operationModes/heating/setpoints/leavingWaterOffset, 2/name, 2/errorCode, 2/isPowerfulModeActive, 3/modelInfo, 3/softwareVersion, 4/softwareVersion, 5/softwareVersion
unmappedDatapointsDetail: [{"key":"0/isFirmwareUpdateSupported","settable":false,"valueType":"boolean"},{"key":"0/ipAddress","settable":false,"valueType":"string"},{"key":"0/macAddress","settable":false,"valueType":"string"},{"key":"0/errorCode","settable":false,"valueType":"string"},{"key":"1/name","settable":true,"valueType":"string"},{"key":"1/temperatureControl/operationModes/heating/setpoints/leavingWaterOffset","settable":true,"valueType":"number","minValue":-10,"maxValue":10,"stepValue":1},{"key":"2/name","settable":true,"valueType":"string"},{"key":"2/errorCode","settable":false,"valueType":"string"},{"key":"2/isPowerfulModeActive","settable":false,"valueType":"boolean"},{"key":"3/modelInfo","settable":false,"valueType":"string"},{"key":"3/softwareVersion","settable":false,"valueType":"string"},{"key":"4/softwareVersion","settable":false,"valueType":"string"},{"key":"5/softwareVersion","settable":false,"valueType":"string"}]
githubIssueUrl: https://github.com/ThibautTrarbach/daikintomqtt/issues/new
Relancer les dépendances devrait te faire passer sur le Deamon 2.1.10.
Et cela devrait implémentée ce qu’il manquais.
Cordialement
Thibaut
