Bonjour a tous,
aprés avoir migré sous JeeZigbee pendant un paquet d’heure
mes backup ne s’exécute plus
j’ai essayé de redémarrer une commande sous ssh suite a un autre poste
mais toujours le meme probleme
dernier backup le 16/08, j’ai fais les modifs dans mon jeedom le 17/08
merci de votre aide
[START BACKUP]
***************Start of Jeedom backup at 2023-08-18 08:47:09***************
Send begin backup event...OK
Checking files rights...chmod: cannot operate on dangling symlink '/var/www/html/core/class/../../phpmyadmin'
OK
Backup plugin JeedomConnect...OK
Checking database...
mysqlcheck: Got error: 2013: Lost connection to MySQL server during query when executing 'CHECK TABLE ... '
OK
Backing up database...mysqldump: Got error: 2002: "Can't connect to local MySQL server through socket '/run/mysqld/mysqld.sock' (111)" when trying to connect
Error during backup: Backing up database failed. Check mysqldump installation. Code: 2Details : Array
[END BACKUP ERROR]
PHP Fatal error: Uncaught Exception: Backing up database failed. Check mysqldump installation. Code: 2 in /var/www/html/install/backup.php:104
Stack trace:
#0 {main}
thrown in /var/www/html/install/backup.php on line 104
