En Version Béta : [Jeedom PI4][LOCAL-EXEC] DetectVirt ReturnCode :: 1
Bonjour, depuis la mise a jour du plugin en béta du 2025-10-08 01:14:27,
J’ai le message suivant qui remonte.
Je confirme sur un Raspi 4.
RAS sur une VM.
Voilà les logs en debug (erreur en igne 004) :
0000|[2025-10-08 18:53:19] DEBUG  [Jeedom 2][POSTSAVE] CustomPull :: Timeout 1min
0001|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] ARMv :: LC_ALL=C timeout 30 lscpu 2>/dev/null | awk -F':' '/Architecture/ { print $2 }' | awk -v ORS="" '{ gsub(/^[[:space:]]+|[[:space:]]+$/, ""); print }'
0002|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] ARMv Result :: aarch64
0003|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] DetectVirt :: timeout 30 systemd-detect-virt 2>/dev/null
0004|[2025-10-08 18:53:20] ERROR  [Jeedom 2][LOCAL-EXEC] DetectVirt ReturnCode :: 1
0005|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] ArchKey :: aarch64 (ARMv)
0006|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] NetworkCard :: LC_ALL=C timeout 30 ip -o -f inet a 2>/dev/null | grep -Ev 'docker|127.0.0.1|127.0.1.1' | head -1 | awk '{ print $2 }' | awk -F'@' -v ORS="" '{ print $1 }'
0007|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] NetworkCard Result :: eth0
0008|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][getNetworkCard] NetworkCard :: eth0
0009|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][getCommands] Key (LocalorRemote) :: aarch64 (local)
0010|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] DistriBits :: timeout 30 getconf LONG_BIT 2>/dev/null
0011|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] DistriBits Result :: 64
0012|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] DistriName :: timeout 30 awk -F'=' '/^PRETTY_NAME/ { print $2 }' /etc/*-release 2>/dev/null | awk -v ORS="" '{ gsub(/"/, ""); print }'
0013|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] DistriName Result :: Debian GNU/Linux 12 (bookworm)
0014|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] OsVersion :: timeout 30 awk -F'=' '/^VERSION_ID/ { print $2 }' /etc/*-release 2>/dev/null | awk -v ORS="" '{ gsub(/"/, ""); print }'
0015|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] OsVersion Result :: 12
0016|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] Uptime :: timeout 30 awk '{ print $1 }' /proc/uptime 2>/dev/null | awk -v ORS="" '{ gsub(/^[[:space:]]+|[[:space:]]+$/, ""); print }'
0017|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] Uptime Result :: 1073512.97
0018|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] LoadAverage :: timeout 30 cat /proc/loadavg 2>/dev/null
0019|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] LoadAverage Result :: 1.01 1.28 1.46 1/286 583936
0020|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] Memory :: LC_ALL=C timeout 30 free 2>/dev/null | grep 'Mem' | head -1 | awk '{ print $2,$3,$4,$6,$7 }'
0021|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] Memory Result :: 8007524 1241476 419544 6494440 6766048
0022|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] Swap :: LC_ALL=C timeout 30 free 2>/dev/null | awk -F':' '/Swap/ { print $2 }' | awk '{ print $1,$2,$3}'
0023|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] Swap Result :: 2097148 0 2097148
0024|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] ReseauRXTX :: timeout 30 cat /proc/net/dev 2>/dev/null | grep "eth0:" | awk '{ print $1,$2,$10 }' | awk -v ORS="" '{ gsub(/:/, ""); print }'
0025|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] ReseauRXTX Result :: eth0 5231828676 10262267086
0026|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] ReseauIP :: LC_ALL=C timeout 30 ip -o -f inet a 2>/dev/null | grep "eth0 " | awk '{ print $4 }' | awk -v ORS="" '{ gsub(/\/[0-9]+/, ""); print }'
0027|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] ReseauIP Result :: 192.168.1.151
0028|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] NbCPU :: LC_ALL=C timeout 30 lscpu 2>/dev/null | grep '^CPU(s):' | awk '{ print $2 }'
0029|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] NbCPU Result :: 4
0030|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] HDD :: LC_ALL=C timeout 30 df -lP 2>/dev/null | grep '/$' | head -1 | awk '{ print $2,$3,$4,$5 }'
0031|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] HDD Result :: 245656812 15114000 218050172 7%
0032|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] CPUFreq-1 :: timeout 30 cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq 2>/dev/null
0033|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] CPUFreq-1 Result :: 1800000
0034|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] CPUTemp-1 :: timeout 30 cat /sys/class/thermal/thermal_zone0/temp 2>/dev/null
0035|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL-EXEC] CPUTemp-1 Result :: 58426
0036|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] DistriName :: Debian GNU/Linux 12 (bookworm)
0037|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] DistriBits :: 64
0038|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] OsVersion :: 12
0039|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] Uptime :: 1073512.97
0040|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] LoadAverage :: 1.01 1.28 1.46 1/286 583936
0041|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] Memory :: 8007524 1241476 419544 6494440 6766048
0042|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] Swap :: 2097148 0 2097148
0043|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] HDD :: 245656812 15114000 218050172 7%
0044|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] HDD Id ::
0045|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] ReseauRXTX :: eth0 5231828676 10262267086
0046|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] ReseauIP :: 192.168.1.151
0047|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] NbCPU :: 4
0048|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] CPUFreq :: 1800000
0049|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] CPUFreq Id :: 1
0050|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] CPUTemp :: 58426
0051|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][LOCAL] CPUTemp Id :: 1
0052|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] General DistriName :: Debian GNU/Linux 12 (bookworm) 64bits (aarch64)
0053|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Total :: 8007524
0054|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Used :: 1241476
0055|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Free :: 419544
0056|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Buff/Cache :: 6494440
0057|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Available :: 6766048
0058|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Used % :: 96.6
0059|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Free % :: 5.2
0060|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Memory Available % :: 84.5
0061|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Swap Total :: 2097148
0062|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Swap Used :: 0
0063|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Swap Free :: 2097148
0064|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Swap Used % :: 0
0065|[2025-10-08 18:53:20] DEBUG  [Jeedom 2] Swap Free % :: 100
0066|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][RESEAU] Carte Réseau / IP (TX - RX) :: eth0 / IP : 192.168.1.151 (TX : 9.56 Go - RX : 4.87 Go)
0067|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][HDD] HDD Total :: 245656812
0068|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][HDD] HDD Used :: 15114000
0069|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][HDD] HDD Free :: 218050172
0070|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][HDD] HDD Used % :: 6.2
0071|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][HDD] HDD Free % :: 88.8
0072|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][formatCPU] OS :: aarch64
0073|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][getStats] Tendance :: Charge Système 1 min :: 0.00033221554381954
0074|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][getStats] Tendance :: Charge Système 5 min :: 0.00031335874144179
0075|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][getStats] Tendance :: Charge Système 15 min :: 0.00030332005018687
0076|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][getStats] Tendance :: Espace Disque Libre (Pourcent) :: -0.00015980575691186
0077|[2025-10-08 18:53:20] DEBUG  [Jeedom 2][getStats] Tendance :: Swap Libre (Pourcent) :: 0
0078|[2025-10-08 18:53:21] DEBUG  [Jeedom 2][getStats] Tendance :: Mémoire Disponible (Pourcent) :: -0.00012421113457093
0079|[2025-10-08 18:53:21] DEBUG  [Jeedom 2][getStats] Tendance :: Température CPU :: 0.00022197031351889
Ah bon je ne suis pas tout seul alors :sweat_smile:
Merci, comme je bricolais à faire du ménage sur jeedom cet après-midi je me demandais ce que j’avais encore fais comme bêtise
Merci pour ces retours, j’avais zappé que le code retour de cette commande était 1 s’il ne détectait pas de virtualisation :confused: (malgré cette erreur, ce n’est pas bloquant, mais cela mérite d’être corrigé :stuck_out_tongue: )
une nouvelle version BETA v3.1.17 sera disponible demain matin, qui devrait corriger cette erreur.
Merci d’avance pour vos retours, voir si le soucis disparait bien :wink:
Bonne fin de soirée,
TiTidom.
3 « J'aime »
Tout est OK sur la 3.1.17 :+1:
