Echec lors de l'authentification
< Ajoutez un titre puis rédigez votre question/problème ici, sans effacer les infos de config indiquées ci-dessous >
Mes infos de config :
Jeedom Core : 4.4.20 (master)
DNS Jeedom : oui
Statut Démon : Stoppé (NA)
Version JC : 1.17.2 stable
Version OS : debian 11.8
Version PHP : 7.4.33
Bin : ok / vNotif_2
Dépendances : ok
Equipements :
  Iphone Michel : v1.18.0 (82) stable sur ios [os : 18.4.1] (polling) - PA
Depuis quelques temps j’ai des problèmes de connection avec Jeedomconnect sur mon mobile, voici un extrait de log:
{"method":"CONNECT","params":{"apiKey":"72f362aec737845ebbead29f16825cec","deviceId":"4A51298E-2366-4CA3-9CDF-DB324FEB68D1","deviceName":"iPhone","userHash":"YRTZRIqseQ******************************************************","appVersion":"1.20.1","pluginRequire":"1.7.1","token":"fK0aCLhe0URzoiJWx8wTyX:APA91bGZ4gERSj3nu0Pspk-bkN3SFT78GkfG1srgW0OyYGa_kx96B9gyyFRRnfSfabtNKv2FMzUdc_Vn7IFy9Z_VRGYGBlOJ01hEV5V_T2UrDsPfRMcdNAo","platformOs":"ios","osVersion":"18.4.1","appTypeVersion":"stable","buildVersion":"87"},"jsonrpc":"2.0","id":1762593425982}
[2025-11-08 10:17:06] DEBUG  : Send {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:06] ERROR  : Echec lors de l'authentification
[2025-11-08 10:17:06] DEBUG  : [API] Send CONNECT -> {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:06] DEBUG  : [API] Request Received {"method":"CONNECT","params":{"apiKey":"72f362aec737845ebbead29f16825cec","deviceId":"4A51298E-2366-4CA3-9CDF-DB324FEB68D1","deviceName":"iPhone","userHash":"YRTZRIqseQ******************************************************","appVersion":"1.20.1","pluginRequire":"1.7.1","token":"fK0aCLhe0URzoiJWx8wTyX:APA91bGZ4gERSj3nu0Pspk-bkN3SFT78GkfG1srgW0OyYGa_kx96B9gyyFRRnfSfabtNKv2FMzUdc_Vn7IFy9Z_VRGYGBlOJ01hEV5V_T2UrDsPfRMcdNAo","platformOs":"ios","osVersion":"18.4.1","appTypeVersion":"stable","buildVersion":"87"},"jsonrpc":"2.0","id":1762593426207}
[2025-11-08 10:17:07] DEBUG  : [API] Request Received {"method":"CONNECT","params":{"apiKey":"72f362aec737845ebbead29f16825cec","deviceId":"4A51298E-2366-4CA3-9CDF-DB324FEB68D1","deviceName":"iPhone","userHash":"YRTZRIqseQ******************************************************","appVersion":"1.20.1","pluginRequire":"1.7.1","token":"fK0aCLhe0URzoiJWx8wTyX:APA91bGZ4gERSj3nu0Pspk-bkN3SFT78GkfG1srgW0OyYGa_kx96B9gyyFRRnfSfabtNKv2FMzUdc_Vn7IFy9Z_VRGYGBlOJ01hEV5V_T2UrDsPfRMcdNAo","platformOs":"ios","osVersion":"18.4.1","appTypeVersion":"stable","buildVersion":"87"},"jsonrpc":"2.0","id":1762593427402}
[2025-11-08 10:17:07] DEBUG  : Send {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:07] ERROR  : Echec lors de l'authentification
[2025-11-08 10:17:07] DEBUG  : [API] Send CONNECT -> {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:07] DEBUG  : [API] Request Received {"method":"CONNECT","params":{"apiKey":"72f362aec737845ebbead29f16825cec","deviceId":"4A51298E-2366-4CA3-9CDF-DB324FEB68D1","deviceName":"iPhone","userHash":"YRTZRIqseQ******************************************************","appVersion":"1.20.1","pluginRequire":"1.7.1","token":"fK0aCLhe0URzoiJWx8wTyX:APA91bGZ4gERSj3nu0Pspk-bkN3SFT78GkfG1srgW0OyYGa_kx96B9gyyFRRnfSfabtNKv2FMzUdc_Vn7IFy9Z_VRGYGBlOJ01hEV5V_T2UrDsPfRMcdNAo","platformOs":"ios","osVersion":"18.4.1","appTypeVersion":"stable","buildVersion":"87"},"jsonrpc":"2.0","id":1762593427569}
[2025-11-08 10:17:09] DEBUG  : [API] Request Received {"method":"CONNECT","params":{"apiKey":"72f362aec737845ebbead29f16825cec","deviceId":"4A51298E-2366-4CA3-9CDF-DB324FEB68D1","deviceName":"iPhone","userHash":"YRTZRIqseQ******************************************************","appVersion":"1.20.1","pluginRequire":"1.7.1","token":"fK0aCLhe0URzoiJWx8wTyX:APA91bGZ4gERSj3nu0Pspk-bkN3SFT78GkfG1srgW0OyYGa_kx96B9gyyFRRnfSfabtNKv2FMzUdc_Vn7IFy9Z_VRGYGBlOJ01hEV5V_T2UrDsPfRMcdNAo","platformOs":"ios","osVersion":"18.4.1","appTypeVersion":"stable","buildVersion":"87"},"jsonrpc":"2.0","id":1762593428723}
[2025-11-08 10:17:09] DEBUG  : Send {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:09] ERROR  : Echec lors de l'authentification
[2025-11-08 10:17:09] DEBUG  : [API] Send CONNECT -> {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:10] DEBUG  : [API] Request Received {"method":"CONNECT","params":{"apiKey":"72f362aec737845ebbead29f16825cec","deviceId":"4A51298E-2366-4CA3-9CDF-DB324FEB68D1","deviceName":"iPhone","userHash":"YRTZRIqseQ******************************************************","appVersion":"1.20.1","pluginRequire":"1.7.1","token":"fK0aCLhe0URzoiJWx8wTyX:APA91bGZ4gERSj3nu0Pspk-bkN3SFT78GkfG1srgW0OyYGa_kx96B9gyyFRRnfSfabtNKv2FMzUdc_Vn7IFy9Z_VRGYGBlOJ01hEV5V_T2UrDsPfRMcdNAo","platformOs":"ios","osVersion":"18.4.1","appTypeVersion":"stable","buildVersion":"87"},"jsonrpc":"2.0","id":1762593429921}
[2025-11-08 10:17:10] DEBUG  : Send {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:10] ERROR  : Echec lors de l'authentification
[2025-11-08 10:17:10] DEBUG  : [API] Send CONNECT -> {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:11] DEBUG  : [API] Request Received {"method":"CONNECT","params":{"apiKey":"72f362aec737845ebbead29f16825cec","deviceId":"4A51298E-2366-4CA3-9CDF-DB324FEB68D1","deviceName":"iPhone","userHash":"YRTZRIqseQ******************************************************","appVersion":"1.20.1","pluginRequire":"1.7.1","token":"fK0aCLhe0URzoiJWx8wTyX:APA91bGZ4gERSj3nu0Pspk-bkN3SFT78GkfG1srgW0OyYGa_kx96B9gyyFRRnfSfabtNKv2FMzUdc_Vn7IFy9Z_VRGYGBlOJ01hEV5V_T2UrDsPfRMcdNAo","platformOs":"ios","osVersion":"18.4.1","appTypeVersion":"stable","buildVersion":"87"},"jsonrpc":"2.0","id":1762593431117}
[2025-11-08 10:17:11] DEBUG  : Send {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:17:11] ERROR  : Echec lors de l'authentification
[2025-11-08 10:17:11] DEBUG  : [API] Send CONNECT -> {"type":"EXCEPTION","payload":{"message":"Echec lors de l'authentification"}}
[2025-11-08 10:19:38] DEBUG  : getWidgets for all widgets with full config
[2025-11-08 10:19:40] DEBUG  : -- manage fx ajax getWidgetConfigAll ~~ retrieve config for ALL widgets
[2025-11-08 10:19:40] DEBUG  : getWidgetConfigAll ~~ result : [{"name":"ON\/OFF Portail","nameDisplayed":"","actions":[{"id":"1025","name":"state on l11","index":0,"subtype":"other","image":[]}],"contentCard":false,"lineMode":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"generic-action-other","blockDetail":false,"visibilityCond":"ON\/OFF Portail","enable":true,"room":2,"id":11},{"name":"STOP Portail","nameDisplayed":"","actions":[{"id":"1029","name":"state on l12","index":0,"subtype":"other","image":[]}],"contentCard":false,"lineMode":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"generic-action-other","blockDetail":false,"visibilityCond":"STOP Portail","enable":true,"room":2,"id":14},{"name":"Ouverture","nameDisplayed":"","actions":[{"id":"1088","name":"Fermeture","index":0,"subtype":"other","image":[],"options":[]}],"contentCard":false,"lineMode":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"generic-action-other","blockDetail":false,"visibilityCond":"Ouverture","enable":true,"room":2,"id":15},{"name":"Fermeture","nameDisplayed":"","actions":[{"id":"1089","name":"Ouverture","index":0,"subtype":"other","image":[],"options":[]}],"contentCard":false,"lineMode":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"generic-action-other","blockDetail":false,"visibilityCond":"Fermeture","enable":true,"room":2,"id":16},{"name":"Eclairage Bassin","nameDisplayed":"","subtitle":"#1368# W","onAction":{"id":"935","type":"action","subType":"other","step":"1"},"offAction":{"id":"934","type":"action","subType":"other","step":"1"},"statusInfo":{"id":"933","type":"info","subType":"binary","step":"1"},"powerInfo":{"id":"1368","type":"info","subType":"numeric","step":"1","unit":"W"},"statusImages":[{"index":0,"image":{"source":"jc","name":"light0.png","shadow":false},"condition":"#1368#< 10"},{"index":1,"condition":"#1368#>100","image":{"source":"jc","name":"light100.png","shadow":false}}],"autoBackground":false,"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"single-light-switch","blockDetail":false,"visibilityCond":"Eclairage Bassin","enable":true,"room":4,"id":2},{"name":"ESP Piscine","nameDisplayed":"","text":"","fontSize":14,"textAlign":"right","justifyContent":"center","type":"component","component":"text","visibilityCond":"ESP Piscine","enable":true,"room":4,"moreInfos":[{"type":"cmd","id":"749","name":"esp-piscine:status","unit":"","index":0}],"id":23},{"name":"Filtration","nameDisplayed":"","subtitle":"#956# W","enableInfo":{"id":"1304","type":"info","subType":"binary","step":"1"},"onAction":{"id":"1305","type":"action","subType":"other","step":"1"},"offAction":{"id":"1306","type":"action","subType":"other","step":"1"},"modes":[],"lineMode":false,"immediateTime":"","image":{"source":"user","name":"Filtration.jpeg","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"alarm","blockDetail":false,"visibilityCond":"Filtration","enable":true,"room":4,"moreInfos":[{"type":"cmd","id":"956","name":"Conso Filtration","unit":"W","index":0}],"id":25},{"name":"Robot","nameDisplayed":"","subtitle":"#955# W","enableInfo":{"id":"975","type":"info","subType":"binary","step":"1"},"onAction":{"id":"977","type":"action","subType":"other","step":"1"},"offAction":{"id":"976","type":"action","subType":"other","step":"1"},"modes":[],"lineMode":false,"immediateTime":"","image":{"source":"user","name":"robot.jpeg","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"alarm","blockDetail":false,"visibilityCond":"Robot","enable":true,"room":4,"moreInfos":[{"type":"cmd","id":"955","name":"Conso Robot","unit":"W","index":0}],"id":26},{"name":"Remplissage Bassin","nameDisplayed":"","subtitle":"#3016#%","onAction":{"id":"1317","type":"action","subType":"other","step":"1"},"offAction":{"id":"1318","type":"action","subType":"other","step":"1"},"statusInfo":{"id":"1316","type":"info","subType":"binary","step":"1"},"image":{"source":"user","name":"Remplissage.png","shadow":false},"statusImages":[],"autoBackground":false,"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"single-light-switch","blockDetail":false,"visibilityCond":"Remplissage Bassin","enable":true,"room":4,"moreInfos":[{"type":"cmd","id":"3016","name":"Niveau Piscine","unit":"%","index":0}],"id":27},{"name":"ON\/OFF PAC","nameDisplayed":"","subtitle":"#1367# W","actions":[{"id":"1048","name":"state on l1","index":0,"subtype":"other","image":[]}],"contentCard":false,"lineMode":false,"image":{"source":"user","name":"PAC.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"generic-action-other","blockDetail":false,"visibilityCond":"ON\/OFF PAC","enable":true,"room":4,"moreInfos":[{"type":"cmd","id":"1367","name":"Conso PAC","unit":"W","index":0}],"id":28},{"name":"Regul pH Auto","nameDisplayed":"","onAction":{"id":"1056","type":"action","subType":"other","step":"1"},"offAction":{"id":"1055","type":"action","subType":"other","step":"1"},"statusInfo":{"id":"1054","type":"info","subType":"binary","step":"1"},"statusImages":[],"autoBackground":false,"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"single-light-switch","blockDetail":false,"visibilityCond":"R\u00e9gul pH Auro","enable":true,"room":4,"id":31},{"name":"Injection Man pH","nameDisplayed":"","onAction":{"id":"1060","type":"action","subType":"other","step":"1"},"offAction":{"id":"1059","type":"action","subType":"other","step":"1"},"statusInfo":{"id":"1058","type":"info","subType":"binary","step":"1"},"statusImages":[],"autoBackground":false,"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"single-light-switch","blockDetail":false,"visibilityCond":"Injection Man pH","enable":true,"room":4,"id":33},{"name":"Injection pH Auto","nameDisplayed":"","enableInfo":{"id":"1050","type":"info","subType":"binary","step":"1"},"statusInfo":{"id":"1050","type":"info","subType":"binary","step":"1"},"onAction":{"id":"1052","type":"action","subType":"other","step":"1"},"offAction":{"id":"1051","type":"action","subType":"other","step":"1"},"modes":[],"lineMode":false,"immediateTime":"","statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"alarm","blockDetail":false,"visibilityCond":"Injection pH Auto","enable":true,"room":4,"id":35},{"name":"Pompe pH","nameDisplayed":"","statusInfo":{"id":"1370","type":"info","subType":"numeric","step":"1"},"showGauge":false,"historyBackground":false,"statusImages":[{"index":0,"condition":"#1370# ==1","image":{"source":"jc","name":"alarm_red.png","shadow":false}},{"index":1,"condition":"#1370# ==0","image":{"source":"jc","name":"alarm_grey.png","shadow":false}}],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"Pompe pH","enable":true,"room":4,"id":36},{"name":"Compteur GRDF","nameDisplayed":"","statusInfo":{"id":"1369","type":"info","subType":"numeric","step":"1"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Compteur GRDF","enable":true,"room":5,"id":37},{"name":"Conso mois (J-3)","nameDisplayed":"","statusInfo":{"id":"2696","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso mois (J-3)","enable":true,"room":5,"id":38},{"name":"Conso Jour (J-3)","nameDisplayed":"","statusInfo":{"id":"2694","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso Jour (J-3)","enable":true,"room":5,"id":39},{"name":"Portail","nameDisplayed":"","enableInfo":{"id":"3043","type":"info","subType":"binary","step":"1"},"modes":[],"lineMode":false,"immediateTime":"","statusImages":[{"index":0,"condition":"#3043#==1","image":{"source":"jc","name":"doorOff.png","shadow":false}},{"index":1,"condition":"#3043# ==0","image":{"source":"jc","name":"doorOn.png","shadow":false}}],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"alarm","blockDetail":false,"visibilityCond":"Portail","enable":true,"room":2,"id":4},{"name":"Co\u00fbt jour (J-3)","nameDisplayed":"","statusInfo":{"id":"2695","type":"info","subType":"numeric","step":"1","unit":"\u20ac"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Co\u00fbt jour (J-3)","enable":true,"room":5,"id":40},{"name":"Conso Jour ","nameDisplayed":"","statusInfo":{"id":"2720","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso Jour ","enable":true,"room":5,"id":41},{"name":"Conso mois ","nameDisplayed":"","statusInfo":{"id":"2721","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso mois ","enable":true,"room":5,"id":42},{"name":"Conso mois ","nameDisplayed":"","statusInfo":{"id":"1574","type":"info","subType":"numeric","step":"1","unit":"m3"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso mois ","enable":true,"room":5,"id":43},{"name":"Co\u00fbt jour ","nameDisplayed":"","statusInfo":{"id":"1582","type":"info","subType":"numeric","step":"1","unit":"\u20ac"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Co\u00fbt jour ","enable":true,"room":5,"id":44},{"name":"Pinject\u00e9e Linky","nameDisplayed":"","subtitle":"elapsedTime","statusInfo":{"id":"1356","type":"info","subType":"numeric","step":"1","unit":"VA"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Pinject\u00e9e Linky","enable":true,"room":5,"id":45},{"name":"Pnette Linky","nameDisplayed":"","subtitle":"elapsedTime","statusInfo":{"id":"1006","type":"info","subType":"numeric","step":"1","unit":"VA"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Pnette Linky","enable":true,"room":5,"id":46},{"name":"Conso jour Linky","nameDisplayed":"","subtitle":"elapsedTime","statusInfo":{"id":"2785","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso jour Linky","enable":true,"room":5,"moreInfos":[{"type":"cmd","id":"1353","name":"LTARF","unit":"","index":0}],"id":47},{"name":"Ptotale Enphase","nameDisplayed":"","statusInfo":{"id":"1386","type":"info","subType":"numeric","step":"1","unit":"W"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Ptotale Enphase","enable":true,"room":5,"id":48},{"name":"Production Enphase","nameDisplayed":"","subtitle":"elapsedTime","statusInfo":{"id":"1382","type":"info","subType":"numeric","step":"1","unit":"W"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Production Enphase","enable":true,"room":5,"id":49},{"name":"Pnette Enphase","nameDisplayed":"","subtitle":"elapsedTime","statusInfo":{"id":"1390","type":"info","subType":"numeric","step":"1","unit":"W"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Pnette Enphase","enable":true,"room":5,"id":50},{"name":"Conso Jour  (J-1)","nameDisplayed":"","statusInfo":{"id":"2723","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso Jour  (J-1)","enable":true,"room":5,"id":51},{"name":"Conso mois (J-1)","nameDisplayed":"","statusInfo":{"id":"2724","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Conso mois (J-1)","enable":true,"room":5,"id":52},{"name":"Export Jour (J-1)","nameDisplayed":"","statusInfo":{"id":"2728","type":"info","subType":"numeric","step":"1","unit":"kWh"},"historyBackground":false,"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"power","blockDetail":false,"visibilityCond":"Export Jour (J-1)","enable":true,"room":5,"id":53},{"name":"Alarme","nameDisplayed":"","enableInfo":{"id":"2767","type":"info","subType":"binary","step":"1"},"onAction":{"id":"2774","type":"action","subType":"other","step":"1"},"offAction":{"id":"2775","type":"action","subType":"other","step":"1"},"modes":[],"lineMode":false,"immediateTime":"","statusImages":[{"index":0,"image":{"source":"jeedom","name":"jeedom-lock-ferme"},"condition":"#2767# ==1"},{"index":1,"condition":"#2767# ==0","image":{"source":"jeedom","name":"jeedom-lock-ouvert"}}],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"alarm","blockDetail":false,"enable":true,"room":2,"id":56},{"name":"Alert","nameDisplayed":"","enableInfo":{"id":"2771","type":"info","subType":"binary","step":"1"},"modes":[],"lineMode":false,"immediateTime":"","statusImages":[{"index":0,"image":{"source":"jc","name":"alarm_green.png","shadow":false},"condition":"#2771# ==0"},{"index":1,"condition":"#2771# ==1","image":{"source":"jc","name":"alarm_red.png","shadow":false}}],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"alarm","blockDetail":false,"visibilityCond":"Alert","enable":true,"room":2,"id":57},{"name":"Porte Entr\u00e9e","nameDisplayed":"","enableInfo":{"id":"3039","type":"info","subType":"binary","step":"1"},"modes":[],"lineMode":false,"immediateTime":"","statusImages":[{"index":0,"condition":"#3039# ==1","image":{"source":"jc","name":"doorOff.png","shadow":false}},{"index":1,"condition":"#3039# ==0","image":{"source":"jc","name":"doorOn.png","shadow":false}}],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"alarm","blockDetail":false,"visibilityCond":"Porte Entr\u00e9e","enable":true,"room":2,"id":59},{"name":"Portail Voiture","nameDisplayed":"","statusInfo":{"id":"1019","type":"info","subType":"binary","step":"1","invert":true},"openAction":{"id":"1025","type":"action","subType":"other","step":"1"},"closeAction":{"id":"1024","type":"action","subType":"other","step":"1"},"statusImages":[{"index":0,"image":{"source":"jc","name":"gateClose.png","shadow":false},"condition":"#1019# ==0"},{"index":1,"image":{"source":"jc","name":"gatePartial.png","shadow":false},"condition":"#2716# ==1"},{"index":2,"condition":"#1020# ==0","image":{"source":"jc","name":"gateOpen.png","shadow":false}}],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"frontgate","blockDetail":false,"visibilityCond":"Portail Voiture","enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"1020","name":"Portail Ouvert","unit":"","index":0},{"type":"cmd","id":"2716","name":"Ouverture en cours","unit":"","index":1}],"id":6},{"name":"pH","nameDisplayed":"","statusInfo":{"id":"745","type":"info","subType":"numeric","step":"0.1"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"humidity.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"pH","enable":true,"room":4,"id":60},{"name":"ORP","nameDisplayed":"","statusInfo":{"id":"747","type":"info","subType":"numeric","step":"0.1","unit":"mV"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"humidity.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"ORP","enable":true,"room":4,"id":61},{"name":"Temp Eau Local","nameDisplayed":"","statusInfo":{"id":"748","type":"info","subType":"numeric","step":"0.1","unit":"\u00b0C"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"temperature.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"Eau Local","enable":true,"room":4,"id":62},{"name":"Salon","nameDisplayed":"","username":"admin","password":"Michel553","streamUrl":"rtsp:\/\/#username#:#password#@192.168.1.145:554\/h264Preview_01_main","onlyOnLan":true,"authent":"nill","snapshotUrl":"","refreshInterval":"5","compress":"70","resize":"","aspectRatio":"","recordFolder":"","statusImages":[],"displayOnWidget":false,"moreWidgets":[],"display":"detail","hideControlDevice":false,"type":"camera","blockDetail":false,"visibilityCond":"Salon","enable":true,"room":2,"id":63},{"name":"Piscine","nameDisplayed":"","username":"admin","password":"admin","streamUrl":"rtsp:\/\/#username#:#password#@192.168.1.85\/11","onlyOnLan":true,"authent":"nill","snapshotUrl":"","refreshInterval":"5","compress":"70","resize":"","aspectRatio":"","recordFolder":"","statusImages":[],"displayOnWidget":false,"moreWidgets":[],"display":"detail","hideControlDevice":false,"type":"camera","blockDetail":false,"visibilityCond":"Piscine","enable":true,"room":2,"id":66},{"name":"Entr\u00e9e","nameDisplayed":"","username":"admin","password":"Michel553","streamUrl":"rtsp:\/\/#username#:#password#@192.168.1.74:554\/h264Preview_01_main","onlyOnLan":true,"authent":"nill","snapshotUrl":"","refreshInterval":"5","compress":"70","resize":"","aspectRatio":"","recordFolder":"","statusImages":[],"displayOnWidget":false,"moreWidgets":[],"display":"detail","hideControlDevice":false,"type":"camera","blockDetail":false,"visibilityCond":"Entr\u00e9e","enable":true,"room":2,"id":67},{"name":"Salon","nameDisplayed":"","subtitle":"#3098#%","statusInfo":{"id":"3097","type":"info","subType":"numeric","step":"0.1","unit":"\u00b0C"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"temperature.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"Salon","enable":true,"room":6,"moreInfos":[{"type":"cmd","id":"3098","name":"Humidit\u00e9","unit":"%","index":0}],"id":69},{"name":"Chambre","nameDisplayed":"","subtitle":"#883#%","statusInfo":{"id":"882","type":"info","subType":"numeric","step":"0.1","unit":"\u00b0C"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"temperature.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"Chambre","enable":true,"room":6,"moreInfos":[{"type":"cmd","id":"883","name":"Humidit\u00e9","unit":"%","index":0}],"id":70},{"name":"SdBain","nameDisplayed":"","subtitle":"#897#%","statusInfo":{"id":"896","type":"info","subType":"numeric","step":"0.1","unit":"\u00b0C"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"temperature.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"SdBain","enable":true,"room":6,"moreInfos":[{"type":"cmd","id":"897","name":"Humidit\u00e9","unit":"%","index":0}],"id":71},{"name":"Facade Sud","nameDisplayed":"","statusInfo":{"id":"18","type":"info","subType":"numeric","step":"0.1","unit":"\u00b0C"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"temperature.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"Facade Sud","enable":true,"room":6,"id":72},{"name":"Facade Sud JZ","nameDisplayed":"","subtitle":"#3083#%","statusInfo":{"id":"3082","type":"info","subType":"numeric","step":"0.1","unit":"\u00b0C"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"temperature.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"Facade Sud JZ","enable":true,"room":6,"moreInfos":[{"type":"cmd","id":"3083","name":"Humidit\u00e9","unit":"%","index":0}],"id":73},{"name":"Cuisine","nameDisplayed":"","subtitle":"#3088#%","statusInfo":{"id":"3086","type":"info","subType":"numeric","step":"0.1","unit":"\u00b0C"},"showGauge":false,"historyBackground":false,"image":{"source":"jc","name":"temperature.png","shadow":false},"statusImages":[],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"type":"generic-info-numeric","blockDetail":false,"visibilityCond":"Cuisine","enable":true,"room":6,"moreInfos":[{"type":"cmd","id":"3088","name":"Humidit\u00e9","unit":"%","index":0}],"id":75},{"name":"Porte Garage","nameDisplayed":"","statusInfo":{"id":"815","type":"info","subType":"binary","step":"1","invert":true},"openAction":{"id":"1089","type":"action","subType":"other","step":"1"},"closeAction":{"id":"1088","type":"action","subType":"other","step":"1"},"statusImages":[{"index":0,"condition":"#815# ==1","image":{"source":"jc","name":"shutter100.png","shadow":false}},{"index":1,"condition":"#1517# ==1","image":{"source":"jc","name":"shutter50.png","shadow":false}},{"index":2,"condition":"#1510# == 1","image":{"source":"jc","name":"shutter0.png","shadow":false}}],"moreWidgets":[],"display":"miniWidget","hideControlDevice":false,"allowOnUnlock":false,"type":"frontgate","blockDetail":false,"visibilityCond":"Porte Garage","enable":true,"room":2,"moreInfos":[{"type":"cmd","id":"1517","name":"Ouverture En cours","unit":"","index":0},{"type":"cmd","id":"815","name":"contact","unit":"","index":1},{"type":"cmd","id":"1510","name":"contact","unit":"","index":2}],"id":9}]
Pouvez vous m’aider à résoudre ce problème
Merci d’avance
Je suis moyennement la partie iOS mais il me semble qu’il y a une version plus récente que la 1.18.0 non ?
Oui, la 1.20.0 et les problèmes de connexions sont résolus avec la 1.19.0
Il aurait fallut lire les derniers posts quoi.
salut
peu importe les versions, là n est pas la question…
il y a au moins 10 anciens sujets qui repondent a comment traiter ce « problème » !
