Échec du téléchargement du ZIP
Salut à tous,
Lors de l’installation du plugin à la dernière version, j’ai ce message d’erreur qui apparait :
J’ai tenté plusieurs fois la réinstall mais toujours le message.
J’ai rien de particulier dans les logs
[2026-06-08 09:23:57] INFO  Début d'activation du plugin
[2026-06-08 09:23:58] INFO  Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2026-06-08 09:23:58] INFO  syncPlugin Status et erreurs réinitialisés pour tous les équipements
[2026-06-08 09:23:59] INFO   ******syncPlugin Homefacility: {"69481b5c162b132eaa080327":{"Home|69481b5c162b132eaa080327":{"naCat":"energy","home_name":"Maison","boiler_anticipating":false,"boiler_status":false,"home_status":true,"naConfigs":{"id":"69481b5c162b132eaa080327","modules":[{"beep_enabled":false,"haptic_enabled":true,"id":"00:03:50:dd:ee:96","rf_stats":false,"screen_brightness":-1,"touch_enabled":true},{"beep_enabled":false,"haptic_enabled":true,"id":"00:03:50:dd:f3:ac","rf_stats":false,"screen_brightness":-1,"touch_enabled":true}]},"temperature_control_mode":"cooling","spm_duration":180,"home_modetech":"away","home_type":"house","therm_heating_energy":"pac","home_size":131,"thermPriority":"eco","anticipation_enabled":true,"home_modesp":false,"reachable":true,"wifi_strength":52,"modules":{"00:03:50:dd:ee:96":{"id":"00:03:50:dd:ee:96","type":"BNS","name":"Etage","setup_date":1772301671,"room_id":"3873675179","reachable":true,"hk_device_id":"4c:76:04:d7:59:18","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1,"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"hardware_version":226,"installation_type":"wall_mounted","outdoor_temperature":19,"sequence_id":1929,"wifi_strength":46,"wifipower":"full"},"0":{"id":"00:03:50:dd:ee:96","type":"BNS","name":"Etage","setup_date":1772301671,"room_id":"3873675179","reachable":true,"hk_device_id":"4c:76:04:d7:59:18","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1},"00:03:50:dd:f3:ac":{"id":"00:03:50:dd:f3:ac","type":"BNS","name":"RdC","setup_date":1772301930,"room_id":"3594115605","reachable":true,"hk_device_id":"dc:9b:fa:a6:49:d9","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1,"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"hardware_version":226,"installation_type":"flush_mounted","outdoor_temperature":19,"sequence_id":2768,"wifi_strength":52,"wifipower":"full"},"1":{"id":"00:03:50:dd:f3:ac","type":"BNS","name":"RdC","setup_date":1772301930,"room_id":"3594115605","reachable":true,"hk_device_id":"dc:9b:fa:a6:49:d9","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1}},"Plugs_Id":["00:03:50:dd:ee:96","00:03:50:dd:f3:ac"],"energie_modules":{"00:03:50:dd:ee:96":{"id":"00:03:50:dd:ee:96","type":"BNS","name":"Etage","setup_date":1772301671,"room_id":"3873675179","reachable":true,"hk_device_id":"4c:76:04:d7:59:18","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1,"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"hardware_version":226,"installation_type":"wall_mounted","outdoor_temperature":19,"sequence_id":1929,"wifi_strength":46,"config":{"beep_enabled":false,"haptic_enabled":true,"id":"00:03:50:dd:ee:96","rf_stats":false,"screen_brightness":-1,"touch_enabled":true}},"00:03:50:dd:f3:ac":{"id":"00:03:50:dd:f3:ac","type":"BNS","name":"RdC","setup_date":1772301930,"room_id":"3594115605","reachable":true,"hk_device_id":"dc:9b:fa:a6:49:d9","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1,"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"hardware_version":226,"installation_type":"flush_mounted","outdoor_temperature":19,"sequence_id":2768,"wifi_strength":52,"config":{"beep_enabled":false,"haptic_enabled":true,"id":"00:03:50:dd:f3:ac","rf_stats":false,"screen_brightness":-1,"touch_enabled":true}}},"eqmodules":"[{\"id\":\"00:03:50:dd:ee:96\",\"type\":\"BNS\",\"name\":\"Etage\",\"room_id\":\"3873675179\",\"reachable\":true,\"hk_device_id\":\"4c:76:04:d7:59:18\",\"firmware_revision\":40,\"therm_heating_algorithm\":\"simple_algo\",\"pid_algo_period\":10,\"simple_heating_algo_deadband\":1,\"boiler_status\":false,\"boiler_valve_comfort_boost\":false,\"cooler_status\":false,\"hardware_version\":226,\"installation_type\":\"wall_mounted\",\"sequence_id\":1929,\"wifi_strength\":46,\"wifipower\":\"full\"},{\"id\":\"00:03:50:dd:f3:ac\",\"type\":\"BNS\",\"name\":\"RdC\",\"room_id\":\"3594115605\",\"reachable\":true,\"hk_device_id\":\"dc:9b:fa:a6:49:d9\",\"firmware_revision\":40,\"therm_heating_algorithm\":\"simple_algo\",\"pid_algo_period\":10,\"simple_heating_algo_deadband\":1,\"boiler_status\":false,\"boiler_valve_comfort_boost\":false,\"cooler_status\":false,\"hardware_version\":226,\"installation_type\":\"flush_mounted\",\"sequence_id\":2768,\"wifi_strength\":52,\"wifipower\":\"full\"}]","modules_types":["BNS"],"listplanning":"69481b5c162b132eaa080328|Chaud(Chauff);694a9c4e28a65ff2f009d609|Chaud \u00e9tage(Chauff);69481b5c162b132eaa080329|Froid(Clim);6978dc53b0680b5ad4071447|Froid \u00e9tage(Clim)","nowplanning":"Froid(Clim)","nowplanid":"69481b5c162b132eaa080329","away_temp":28,"hg_temp":"","plan_type":"cooling","setpointmode_endtime":"Nouvel Ordre","rooms_modes":["away","away"],"roomsCount":2},"ASyncTime":"08-06-2026 09:23","3594115605|69481b5c162b132eaa080327":{"id":"3594115605","name":"RdC","type":"custom","module_ids":["00:03:50:dd:f3:ac"],"modules":[{"id":"00:03:50:dd:f3:ac","type":"BNS","name":"RdC","setup_date":1772301930,"room_id":"3594115605","reachable":true,"hk_device_id":"dc:9b:fa:a6:49:d9","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1,"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"hardware_version":226,"installation_type":"flush_mounted","outdoor_temperature":19,"sequence_id":2768,"wifi_strength":52,"config":{"beep_enabled":false,"haptic_enabled":true,"id":"00:03:50:dd:f3:ac","rf_stats":false,"screen_brightness":-1,"touch_enabled":true},"rfpower":"full"}],"therm_relay":"00:03:50:dd:f3:ac","true_temperature_available":true,"anticipation_type":"optimized","cooling_setpoint_end_time":null,"cooling_setpoint_mode":"home","cooling_setpoint_start_time":0,"humidity":68,"open_window":false,"reachable":true,"A_syncTime":"08-06-2026 09:23","hasStatut":"ok","naCat":"energy","room_modetech":"away","room_modesp":false,"temperature_control_mode":"cooling","modules_types":["BNS"],"relay_type":null,"relay_infos":"||","modulesCount":1,"eqmodules":"[{\"id\":\"00:03:50:dd:f3:ac\",\"type\":\"BNS\",\"name\":\"RdC\",\"setup_date\":1772301930,\"room_id\":\"3594115605\",\"reachable\":true,\"hk_device_id\":\"dc:9b:fa:a6:49:d9\",\"schedule_limits\":[{\"nb_zones\":16,\"nb_timeslots\":150,\"type\":\"therm\"},{\"nb_zones\":16,\"nb_timeslots\":150,\"type\":\"cooling\"}],\"firmware_revision\":40,\"max_modules_nb\":20,\"therm_heating_algorithm\":\"simple_algo\",\"pid_algo_period\":10,\"simple_heating_algo_deadband\":1,\"boiler_status\":false,\"boiler_valve_comfort_boost\":false,\"cooler_status\":false,\"hardware_version\":226,\"installation_type\":\"flush_mounted\",\"outdoor_temperature\":19,\"sequence_id\":2768,\"wifi_strength\":52,\"config\":{\"beep_enabled\":false,\"haptic_enabled\":true,\"id\":\"00:03:50:dd:f3:ac\",\"rf_stats\":false,\"screen_brightness\":-1,\"touch_enabled\":true},\"rfpower\":\"full\"}]","batterie":"","room_rf":"full","listprofil":"Nuit;off|\u00c9co;off|Confort;21","nextprofil":"Aucun-","nowprofil":"Confort","nowprofil_name":"Confort;21","nowprofil_temp":21,"nowprofil_mode":null,"nextprofil_temp":null,"profil_endtime":"15-06-2026 00:00","nextprofil_delay":9516,"nextprofil_tendance":null,"spRoom_starttime":"","spRoom_endtime":"Nouvel Ordre","temperature":22.1,"consigne":28,"room_anticipating":false,"powerRequest":0,"is_boiler_cable":null,"actif":false,"statustr":"Eteint"},"3873675179|69481b5c162b132eaa080327":{"id":"3873675179","name":"Etage","type":"custom","module_ids":["00:03:50:dd:ee:96"],"modules":[{"id":"00:03:50:dd:ee:96","type":"BNS","name":"Etage","setup_date":1772301671,"room_id":"3873675179","reachable":true,"hk_device_id":"4c:76:04:d7:59:18","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1,"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"hardware_version":226,"installation_type":"wall_mounted","outdoor_temperature":19,"sequence_id":1929,"wifi_strength":46,"config":{"beep_enabled":false,"haptic_enabled":true,"id":"00:03:50:dd:ee:96","rf_stats":false,"screen_brightness":-1,"touch_enabled":true},"rfpower":"full"}],"therm_relay":"00:03:50:dd:ee:96","true_temperature_available":true,"anticipation_type":"optimized","cooling_setpoint_end_time":null,"cooling_setpoint_mode":"home","cooling_setpoint_start_time":0,"humidity":56,"open_window":false,"reachable":true,"A_syncTime":"08-06-2026 09:23","hasStatut":"ok","naCat":"energy","room_modetech":"away","room_modesp":false,"temperature_control_mode":"cooling","modules_types":["BNS"],"relay_type":null,"relay_infos":"||","modulesCount":1,"eqmodules":"[{\"id\":\"00:03:50:dd:ee:96\",\"type\":\"BNS\",\"name\":\"Etage\",\"setup_date\":1772301671,\"room_id\":\"3873675179\",\"reachable\":true,\"hk_device_id\":\"4c:76:04:d7:59:18\",\"schedule_limits\":[{\"nb_zones\":16,\"nb_timeslots\":150,\"type\":\"therm\"},{\"nb_zones\":16,\"nb_timeslots\":150,\"type\":\"cooling\"}],\"firmware_revision\":40,\"max_modules_nb\":20,\"therm_heating_algorithm\":\"simple_algo\",\"pid_algo_period\":10,\"simple_heating_algo_deadband\":1,\"boiler_status\":false,\"boiler_valve_comfort_boost\":false,\"cooler_status\":false,\"hardware_version\":226,\"installation_type\":\"wall_mounted\",\"outdoor_temperature\":19,\"sequence_id\":1929,\"wifi_strength\":46,\"config\":{\"beep_enabled\":false,\"haptic_enabled\":true,\"id\":\"00:03:50:dd:ee:96\",\"rf_stats\":false,\"screen_brightness\":-1,\"touch_enabled\":true},\"rfpower\":\"full\"}]","batterie":"","room_rf":"full","listprofil":"Nuit;off|\u00c9co;off|Confort;26","nextprofil":"Aucun-","nowprofil":"Confort","nowprofil_name":"Confort;26","nowprofil_temp":26,"nowprofil_mode":null,"nextprofil_temp":null,"profil_endtime":"15-06-2026 00:00","nextprofil_delay":9516,"nextprofil_tendance":null,"spRoom_starttime":"","spRoom_endtime":"Nouvel Ordre","temperature":24.2,"consigne":28,"room_anticipating":false,"powerRequest":0,"is_boiler_cable":null,"actif":false,"statustr":"Eteint"}},"apiHome":{"69481b5c162b132eaa080327":{"Data":{"capabilities":[{"name":"peak_and_off_peak_electricity_times","available":true}],"id":"69481b5c162b132eaa080327","name":"Maison","altitude":218,"coordinates":[1.668033,45.058887],"country":"FR","timezone":"Europe\/Paris","city":"Collonges-la-Rouge","currency_code":"EUR","nb_users":1,"data_versions":{"users":3},"place_improved":false,"trust_location":true,"home_type":"house","therm_absence_notification":true,"therm_absence_autoaway":false,"rooms":[{"id":"3594115605","name":"RdC","type":"custom","module_ids":["00:03:50:dd:f3:ac"],"modules":["00:03:50:dd:f3:ac"],"therm_relay":"00:03:50:dd:f3:ac","true_temperature_available":true,"anticipation_type":"optimized"},{"id":"3873675179","name":"Etage","type":"custom","module_ids":["00:03:50:dd:ee:96"],"modules":["00:03:50:dd:ee:96"],"therm_relay":"00:03:50:dd:ee:96","true_temperature_available":true,"anticipation_type":"optimized"}],"modules":[{"id":"00:03:50:dd:ee:96","type":"BNS","name":"Etage","setup_date":1772301671,"room_id":"3873675179","reachable":true,"hk_device_id":"4c:76:04:d7:59:18","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1},{"id":"00:03:50:dd:f3:ac","type":"BNS","name":"RdC","setup_date":1772301930,"room_id":"3594115605","reachable":true,"hk_device_id":"dc:9b:fa:a6:49:d9","schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"},{"nb_zones":16,"nb_timeslots":150,"type":"cooling"}],"firmware_revision":40,"max_modules_nb":20,"therm_heating_algorithm":"simple_algo","pid_algo_period":10,"simple_heating_algo_deadband":1}],"temperature_control_mode":"cooling","therm_schedules":[{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":300},{"zone_id":1,"m_offset":1320},{"zone_id":0,"m_offset":1740},{"zone_id":1,"m_offset":2760},{"zone_id":0,"m_offset":3180},{"zone_id":1,"m_offset":4200},{"zone_id":0,"m_offset":4620},{"zone_id":1,"m_offset":5640},{"zone_id":0,"m_offset":6060},{"zone_id":1,"m_offset":7080},{"zone_id":0,"m_offset":7500},{"zone_id":1,"m_offset":8520},{"zone_id":0,"m_offset":8940},{"zone_id":1,"m_offset":9960}],"zones":[{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":16}],"modules":[]},{"name":"Confort","id":0,"type":0,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":19.5}],"modules":[]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":19.5}],"modules":[]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":18.5}],"modules":[]}],"name":"Chaud","default":false,"away_temp":16,"hg_temp":7,"id":"69481b5c162b132eaa080328","type":"therm","selected":true},{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":240},{"zone_id":1,"m_offset":1320},{"zone_id":0,"m_offset":1680},{"zone_id":1,"m_offset":2760},{"zone_id":0,"m_offset":3120},{"zone_id":1,"m_offset":4200},{"zone_id":0,"m_offset":4560},{"zone_id":1,"m_offset":5640},{"zone_id":0,"m_offset":6000},{"zone_id":1,"m_offset":7080},{"zone_id":0,"m_offset":7440},{"zone_id":1,"m_offset":8520},{"zone_id":0,"m_offset":8880},{"zone_id":1,"m_offset":9960}],"zones":[{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":16}],"modules":[]},{"name":"Confort","id":0,"type":0,"rooms_temp":[{"room_id":"3873675179","temp":20},{"room_id":"3594115605","temp":20}],"modules":[]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3873675179","temp":20},{"room_id":"3594115605","temp":20}],"modules":[]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3873675179","temp":19},{"room_id":"3594115605","temp":19}],"modules":[]}],"name":"Chaud \u00e9tage","default":false,"away_temp":16,"hg_temp":7,"id":"694a9c4e28a65ff2f009d609","type":"therm"}],"therm_mode":"schedule","therm_heating_energy":"pac","home_size":131,"therm_setpoint_default_duration":180,"anticipation":true,"outdoor_temperature_source":"station","therm_heating_priority":"eco","open_window_detection":false,"cooling_mode":"away","therm_boost_default_duration":30,"schedules":[{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":300},{"zone_id":1,"m_offset":1320},{"zone_id":0,"m_offset":1740},{"zone_id":1,"m_offset":2760},{"zone_id":0,"m_offset":3180},{"zone_id":1,"m_offset":4200},{"zone_id":0,"m_offset":4620},{"zone_id":1,"m_offset":5640},{"zone_id":0,"m_offset":6060},{"zone_id":1,"m_offset":7080},{"zone_id":0,"m_offset":7500},{"zone_id":1,"m_offset":8520},{"zone_id":0,"m_offset":8940},{"zone_id":1,"m_offset":9960}],"zones":[{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":16}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":16},{"id":"3594115605","therm_setpoint_temperature":16}]},{"name":"Confort","id":0,"type":0,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":19.5}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":16},{"id":"3594115605","therm_setpoint_temperature":19.5}]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":19.5}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":16},{"id":"3594115605","therm_setpoint_temperature":19.5}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":18.5}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":16},{"id":"3594115605","therm_setpoint_temperature":18.5}]}],"name":"Chaud","default":false,"away_temp":16,"hg_temp":7,"id":"69481b5c162b132eaa080328","type":"therm","selected":true},{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":240},{"zone_id":1,"m_offset":1320},{"zone_id":0,"m_offset":1680},{"zone_id":1,"m_offset":2760},{"zone_id":0,"m_offset":3120},{"zone_id":1,"m_offset":4200},{"zone_id":0,"m_offset":4560},{"zone_id":1,"m_offset":5640},{"zone_id":0,"m_offset":6000},{"zone_id":1,"m_offset":7080},{"zone_id":0,"m_offset":7440},{"zone_id":1,"m_offset":8520},{"zone_id":0,"m_offset":8880},{"zone_id":1,"m_offset":9960}],"zones":[{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3873675179","temp":16},{"room_id":"3594115605","temp":16}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":16},{"id":"3594115605","therm_setpoint_temperature":16}]},{"name":"Confort","id":0,"type":0,"rooms_temp":[{"room_id":"3873675179","temp":20},{"room_id":"3594115605","temp":20}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":20},{"id":"3594115605","therm_setpoint_temperature":20}]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3873675179","temp":20},{"room_id":"3594115605","temp":20}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":20},{"id":"3594115605","therm_setpoint_temperature":20}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3873675179","temp":19},{"room_id":"3594115605","temp":19}],"modules":[],"rooms":[{"id":"3873675179","therm_setpoint_temperature":19},{"id":"3594115605","therm_setpoint_temperature":19}]}],"name":"Chaud \u00e9tage","default":false,"away_temp":16,"hg_temp":7,"id":"694a9c4e28a65ff2f009d609","type":"therm"},{"timetable":[{"zone_id":0,"m_offset":0}],"zones":[{"name":"Nuit","id":1,"type":1,"rooms":[{"id":"3873675179","cooling_setpoint_mode":"off"},{"id":"3594115605","cooling_setpoint_mode":"off"}],"modules":[]},{"name":"\u00c9co","id":2,"type":5,"rooms":[{"id":"3873675179","cooling_setpoint_mode":"off"},{"id":"3594115605","cooling_setpoint_mode":"off"}],"modules":[]},{"name":"Confort","id":0,"type":0,"rooms":[{"id":"3873675179","cooling_setpoint_temperature":26},{"id":"3594115605","cooling_setpoint_temperature":21}],"modules":[]}],"name":"Froid","default":false,"cooling_away_temp":28,"id":"69481b5c162b132eaa080329","type":"cooling","selected":true},{"timetable":[{"zone_id":0,"m_offset":0}],"zones":[{"name":"Nuit","id":1,"type":1,"rooms":[{"id":"3873675179","cooling_setpoint_mode":"off"},{"id":"3594115605","cooling_setpoint_mode":"off"}],"modules":[]},{"name":"\u00c9co","id":2,"type":5,"rooms":[{"id":"3873675179","cooling_setpoint_mode":"off"},{"id":"3594115605","cooling_setpoint_mode":"off"}],"modules":[]},{"name":"Confort","id":0,"type":0,"rooms":[{"id":"3873675179","cooling_setpoint_temperature":21},{"id":"3594115605","cooling_setpoint_temperature":21}],"modules":[]}],"name":"Froid \u00e9tage","default":false,"cooling_away_temp":28,"id":"6978dc53b0680b5ad4071447","type":"cooling"}]},"Status":{"id":"69481b5c162b132eaa080327","modules":[{"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"firmware_revision":40,"hardware_version":226,"id":"00:03:50:dd:ee:96","installation_type":"wall_mounted","outdoor_temperature":19,"sequence_id":1929,"type":"BNS","wifi_strength":46},{"boiler_status":false,"boiler_valve_comfort_boost":false,"cooler_status":false,"firmware_revision":40,"hardware_version":226,"id":"00:03:50:dd:f3:ac","installation_type":"flush_mounted","outdoor_temperature":19,"sequence_id":2768,"type":"BNS","wifi_strength":52}],"rooms":[{"anticipating":false,"cooling_setpoint_end_time":null,"cooling_setpoint_mode":"home","cooling_setpoint_start_time":0,"cooling_setpoint_temperature":28,"heating_power_request":0,"humidity":56,"id":"3873675179","open_window":false,"reachable":true,"therm_measured_temperature":24.2},{"anticipating":false,"cooling_setpoint_end_time":null,"cooling_setpoint_mode":"home","cooling_setpoint_start_time":0,"cooling_setpoint_temperature":28,"heating_power_request":0,"humidity":68,"id":"3594115605","open_window":false,"reachable":true,"therm_measured_temperature":22.1}]}}}}
[2026-06-08 09:23:59] INFO   ** syncPlugin Home Found: Maison(69481b5c162b132eaa080327) nb Relai: 4 **
[2026-06-08 09:23:59] INFO          makeCmd started ********* Maison
[2026-06-08 09:23:59] INFO          makeCmd started ********* RdC
[2026-06-08 09:23:59] INFO          makeCmd started ********* Etage
[2026-06-08 09:24:00]WARNING 		_Meteofacility Aucun équipement Météo trouvé !
Merci pour votre aide
Ce fichier installe des widgets supplémentaires qui ne sont pas indispensables au fonctionnement du plugin pour l’instant.
Il y a des soucis avec github en ce moment.
