Depuis la MAJ du plugin broadlink, il ne fonctionne plus du tout, les dépendances sont NOK (j’ai essayé de relancer l’installation des dépendances, du plugin, rien n’y fait.)
Je suis sous Jeedom atlas avec tout à jour.
J’imagine que je poste un message imprecis mais c’est la première fois que je m’y essaye.
Merci par avance pour votre aide
le log :
> + echo '*******************Begin of package installation******************'
> + touch /tmp/jeedom_install_in_progress_broadlink
> + echo 1
> + echo 2
> + sudo apt update
> WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
> Hit:1 http://security.debian.org buster/updates InRelease
> Hit:2 http://deb.debian.org/debian buster InRelease
> Hit:3 http://deb.debian.org/debian buster-updates InRelease
> Hit:4 http://deb.debian.org/debian buster-backports InRelease
> Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
> Hit:6 https://armbian.site-meganet.com/apt buster InRelease
> Reading package lists...
> Building dependency tree...
> Reading state information...
> 157 packages can be upgraded. Run 'apt list --upgradable' to see them.
> + echo 3
> + sudo apt install -o Dpkg::Options::=--force-confdef -y python3-serial
> You might want to run 'apt --fix-broken install' to correct these.
> The following packages have unmet dependencies:
> libttspico-utils:armhf : Depends: libc6:armhf (>= 2.4) but it is not going to be installed
> Depends: libpopt0:armhf (>= 1.14) but it is not going to be installed
> Depends: libttspico0:armhf (>= 1.0) but it is not going to be installed
> E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
> + echo 4
> + php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end broadlink
> + rm /tmp/jeedom_install_in_progress_broadlink
> + echo '*******************End of package installation******************'
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
Merci pour la réponse, désolé pour le temps de réponse de mon côté.
J’ai le résultat suivant :
Correcting dependencies... Done
The following additional packages will be installed:
gcc-8-base:armhf libc-dev-bin libc6 libc6:armhf libc6-dev libgcc1:armhf
libpopt0:armhf libttspico0:armhf
Suggested packages:
glibc-doc glibc-doc:armhf locales:armhf manpages-dev
Recommended packages:
manpages manpages-dev libidn2-0:armhf
gcc-8-base:armhf libc6:armhf libgcc1:armhf libpopt0:armhf libttspico0:armhf
The following packages will be upgraded:
libc-dev-bin libc6 libc6-dev
3 upgraded, 5 newly installed, 0 to remove and 154 not upgraded.
1 not fully installed or removed.
Need to get 7899 kB of archives.
After this operation, 9378 kB of additional disk space will be used.
Do you want to continue? [Y/n] Abort.
Je me sens con, je ne sais pas où dire « Y » pour continuer…
