Me voilà aux prises avec le plugin ZwaveJS qui subitement ne fonctionne plus.
Personnellement, je n’y comprends rien mais voici les logs dans lesquels figurent des erreurs :
zwavejsd
|___ / \ \ / / | |/ ____| | | | |_ _|
/ /____\ \ /\ / /_ ___ _____ | | (___ | | | | | |
/ /______\ \/ \/ / _' \ \ / / _ \ _ | |\___ \ | | | | | |
/ /__ \ /\ / (_| |\ V / __/ | |__| |____) | | |__| |_| |_
/_____| \/ \/ \__,_| \_/ \___| \____/|_____/ \____/|_____|
e[90m2024-04-12 09:25:04.646e[39m e[33mWARNe[39m e[1mSTOREe[22m: scenes.json not found
e[90m2024-04-12 10:18:16.797e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Error while writing 0 on 98-0-targetMode: Failed to send the command after 5 attempts (ZW0202)
e[90m2024-04-12 10:18:16.801e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Unable to write 0 on 98-0-targetMode: Fail
e[90m2024-04-12 11:22:45.728e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Error while writing 0 on 98-0-targetMode: Failed to send the command after 5 attempts (ZW0202)
e[90m2024-04-12 11:22:45.731e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Unable to write 0 on 98-0-targetMode: Fail
e[90m2024-04-12 11:22:59.034e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Unable to write 0 on 98-0-targetMode: Fail
e[90m2024-04-12 12:15:22.308e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Unable to write 0 on 98-0-targetMode: Fail
e[90m2024-04-12 12:17:37.075e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Unable to write 0 on 98-0-targetMode: Fail
e[90m2024-04-12 12:20:22.169e[39m e[31mERRORe[39m e[1mZ-WAVEe[22m: Unable to write 0 on 98-0-targetMode: Fail
zwavejs
[2024-04-12 09:24:58] INFO : Arrêt du démon ZwaveJS
[2024-04-12 09:24:58] DEBUG : [configureSettings] Informations reçues de MQTT Manager : {"ip":"127.0.0.1","port":"1883","user":"XXXXXX","password":"XXXXXX"}
[2024-04-12 09:24:58] INFO : Démarrage du démon ZwaveJS : STORE_DIR=/var/www/html/plugins/zwavejs/data/store KEY_S0_Legacy=XXXXXX KEY_S2_Unauthenticated=XXXXXX KEY_S2_Authenticated=XXXXXX KEY_S2_AccessControl=XXXXXX SESSION_SECRET=jeedomSession yarn start
[2024-04-12 09:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 09:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 09:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 09:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 09:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 09:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
[2024-04-12 10:00:52] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 10:00:52] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 10:00:52] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 10:00:52] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 10:00:52] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 10:00:52] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
[2024-04-12 10:18:12] DEBUG : [refreshIfNeeded] 98/0/targetMode 0
[2024-04-12 10:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 10:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 10:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 10:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 10:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 10:30:26] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
[2024-04-12 11:00:40] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 11:00:40] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 11:00:40] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 11:00:40] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 11:00:40] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 11:00:40] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
[2024-04-12 11:05:36] DEBUG : [refreshIfNeeded] 38/1/targetValue 0
[2024-04-12 11:05:41] DEBUG : [refreshIfNeeded] 37/0/targetValue false
[2024-04-12 11:22:41] DEBUG : [refreshIfNeeded] 98/0/targetMode 0
[2024-04-12 11:22:44] DEBUG : [refreshIfNeeded] 98/0/targetMode 0
[2024-04-12 11:22:51] DEBUG : [refreshIfNeeded] 98/0/targetMode 0
[2024-04-12 11:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 11:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 11:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 11:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 11:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 11:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
[2024-04-12 12:00:47] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 12:00:47] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 12:00:47] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 12:00:47] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 12:00:47] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 12:00:47] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
[2024-04-12 12:15:20] DEBUG : [refreshIfNeeded] 98/0/targetMode 0
[2024-04-12 12:17:35] DEBUG : [refreshIfNeeded] 98/0/targetMode 0
[2024-04-12 12:20:20] DEBUG : [refreshIfNeeded] 98/0/targetMode 0
[2024-04-12 12:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 12:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 12:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 12:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 12:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 12:30:23] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
[2024-04-12 12:51:57] DEBUG : [refreshIfNeeded] 37/0/targetValue true
[2024-04-12 13:00:42] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":1,"property":"value","propertyKey":65537}]}
[2024-04-12 13:00:42] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":2,"property":"value","propertyKey":65537}]}
[2024-04-12 13:00:42] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":3,"property":"value","propertyKey":65537}]}
[2024-04-12 13:00:42] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":4,"property":"value","propertyKey":65537}]}
[2024-04-12 13:00:42] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":5,"property":"value","propertyKey":65537}]}
[2024-04-12 13:00:42] DEBUG : [Salon][Multiprise GreenWave][pollValue] {"args":[{"nodeId":58,"commandClass":50,"endpoint":6,"property":"value","propertyKey":65537}]}
Merci d’avance de votre aide.
Informations Jeedom
Core : 4.4.3 (V4-stable)
DNS Jeedom : non
Plugin : Z-Wave JS
Version : 2024-02-27 11:01:50 (stable)
Statut Démon : Démarré - (2024-04-12 09:20:52)
Clé Aeotec Z-Stick 7 - Firmware 7.20.2
