Après installation de VMM et d’une machine virtuelle sous debian-10.5.0-amd64-i386-netinst…
… je n’arrive pas à installer Jeedom.
voici mes étapes:
wget https://raw.githubusercontent.com/jeedom/core/stable/install/install.sh
su
chmod +x install.sh
root@.......:/home/......# ./install.sh
Puis ca bloque à l’étape Commence l’étape 3 base de données
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "fr_FR.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("fr_FR.UTF-8").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Ne peut initialiser LC_ALL ? la locale par d?faut: Aucun fichier ou dossier de ce type
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
Reading package lists... Done
Building dependency tree
Reading state information... Done
mariadb-client is already the newest version (1:10.3.23-0+deb10u1).
mariadb-common is already the newest version (1:10.3.23-0+deb10u1).
mariadb-server is already the newest version (1:10.3.23-0+deb10u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
● mariadb.service - MariaDB 10.3.23 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─jeedom.conf
Active: activating (auto-restart) (Result: exit-code) since Thu 2020-09-10 02:05:38 CEST; 763ms ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 5211 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, s
Process: 5212 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited,
Process: 5214 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`cd /usr/bin/
Process: 5420 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code
Main PID: 5420 (code=exited, status=1/FAILURE)
Status: "MariaDB server is down"
