J’ai fait une installation avec la création d’un conteneur Docker avec l’image jeedom/jeedom:4.4-bullseye
il y a des logs concernant les droits du répertoire /tmp/jeedom/cache/
0000|2025-07-06 17:47:02 starting Jeedommkdir: cannot create directory '/tmp/jeedom/cache': File exists
0001|chmod: changing permissions of '/tmp/jeedom/cache/bf': Operation not permitted
0002|chmod: changing permissions of '/tmp/jeedom/cache/db': Operation not permitted
0003|chmod: changing permissions of '/tmp/jeedom/cache/db/5b63726f6e43616368654174747231395d5b315d.doctrinecache.data': Operation not permitted
0004|chmod: changing permissions of '/tmp/jeedom/cache/c4': Operation not permitted
0005|chmod: changing permissions of '/tmp/jeedom/cache/c4/5b63726f6e43616368654174747231385d5b315d.doctrinecache.data': Operation not permitted
0006|chmod: changing permissions of '/tmp/jeedom/cache/fc': Operation not permitted
0007|chmod: changing permissions of '/tmp/jeedom/cache/fc/5b63726f6e43616368654174747231375d5b315d.doctrinecache.data': Operation not permitted
0008|chmod: changing permissions of '/tmp/jeedom/cache/fd': Operation not permitted
0009|chmod: changing permissions of '/tmp/jeedom/cache/fd/5b63726f6e43616368654174747231365d5b315d.doctrinecache.data': Operation not permitted
0010|chmod: changing permissions of '/tmp/jeedom/cache/4a': Operation not permitted
0011|chmod: changing permissions of '/tmp/jeedom/cache/4a/5b63726f6e43616368654174747231355d5b315d.doctrinecache.data': Operation not permitted
0012|chmod: changing permissions of '/tmp/jeedom/cache/45': Operation not permitted
0013|chmod: changing permissions of '/tmp/jeedom/cache/45/5b63726f6e43616368654174747231345d5b315d.doctrinecache.data': Operation not permitted
0014|chmod: changing permissions of '/tmp/jeedom/cache/d8': Operation not permitted
0015|chmod: changing permissions of '/tmp/jeedom/cache/d8/5b63726f6e43616368654174747231335d5b315d.doctrinecache.data': Operation not permitted
0016|chmod: changing permissions of '/tmp/jeedom/cache/09': Operation not permitted
0017|chmod: changing permissions of '/tmp/jeedom/cache/09/5b63726f6e43616368654174747231325d5b315d.doctrinecache.data': Operation not permitted
0018|chmod: changing permissions of '/tmp/jeedom/cache/54': Operation not permitted
0019|chmod: changing permissions of '/tmp/jeedom/cache/68': Operation not permitted
0020|chmod: changing permissions of '/tmp/jeedom/cache/11': Operation not permitted
0021|chmod: changing permissions of '/tmp/jeedom/cache/11/5b63726f6e436163686541747472395d5b315d.doctrinecache.data': Operation not permitted
0022|chmod: changing permissions of '/tmp/jeedom/cache/f2': Operation not permitted
0023|chmod: changing permissions of '/tmp/jeedom/cache/f2/5b63726f6e436163686541747472385d5b315d.doctrinecache.data': Operation not permitted
0024|chmod: changing permissions of '/tmp/jeedom/cache/4d': Operation not permitted
0025|chmod: changing permissions of '/tmp/jeedom/cache/41': Operation not permitted
0026|chmod: changing permissions of '/tmp/jeedom/cache/41/5b63726f6e436163686541747472365d5b315d.doctrinecache.data': Operation not permitted
0027|chmod: changing permissions of '/tmp/jeedom/cache/17': Operation not permitted
0028|chmod: changing permissions of '/tmp/jeedom/cache/17/5b63726f6e436163686541747472355d5b315d.doctrinecache.data': Operation not permitted
0029|chmod: changing permissions of '/tmp/jeedom/cache/96': Operation not permitted
0030|chmod: changing permissions of '/tmp/jeedom/cache/96/5b63726f6e436163686541747472345d5b315d.doctrinecache.data': Operation not permitted
0031|chmod: changing permissions of '/tmp/jeedom/cache/c1': Operation not permitted
0032|chmod: changing permissions of '/tmp/jeedom/cache/c1/5b63726f6e436163686541747472335d5b315d.doctrinecache.data': Operation not permitted
0033|chmod: changing permissions of '/tmp/jeedom/cache/7e': Operation not permitted
0034|chmod: changing permissions of '/tmp/jeedom/cache/7e/5b63726f6e436163686541747472325d5b315d.doctrinecache.data': Operation not permitted
0035|chmod: changing permissions of '/tmp/jeedom/cache/67': Operation not permitted
0036|chmod: changing permissions of '/tmp/jeedom/cache/67/5b63726f6e436163686541747472315d5b315d.doctrinecache.data': Operation not permitted
0037|Enable scenario : OK
0038|Enable task : OK
0039|Check Network Conf : OK
Je pense qu’il manque des droits d’acces ?
root@jeedom:/var/www/html# namei -l /tmp/jeedom/cache
f: /tmp/jeedom/cache
drwxr-xr-x root root /
drwxrwxrwx root root tmp
drwxrwxrwx www-data www-data jeedom
drwxrwxr-- www-data www-data cache
