OK, solution trouvée sur ce post !
Je me demande si je pourrai un jour faire remonter les pièces dans Jeedom pour cet aspirateur
Quand on regarde le JSON, d’après vous pourrait-on commander un nettoyage dans une pièce en particulier via une commande custom?
JSON {"vacuum:status":13,"vacuum:fault":0,"vacuum:mode":1,"battery:battery-level":100,"battery:charging-state":1,"brush-cleaner:brush-left-time":114,"brush-cleaner:brush-life-level":57,"filter:filter-life-level":43,"filter:filter-left-time":64,"vacuum-extend:work-mode":14,"vacuum-extend:cleaning-time":107,"vacuum-extend:cleaning-area":93,"vacuum-extend:cleaning-mode":1,"vacuum-extend:mop-mode":2,"vacuum-extend:waterbox-status":1,"vacuum-extend:task-status":0,"vacuum-extend:break-point-restart":1,"vacuum-extend:carpet-press":1,"vacuum-extend:serial-number":"R221602B2EU0022201","vacuum-extend:clean-rags-tip":0,"vacuum-extend:keep-sweeper-time":0,"vacuum-extend:faults":"","vacuum-extend:nation-matched":"unknown","vacuum-extend:relocation-status":0,"do-not-disturb:enable":true,"do-not-disturb:start-time":"22:00","do-not-disturb:end-time":"08:00","map:mult-map-state":1,"map:mult-map-info":"{\"object_name\":\"8155383719\/638554088\/9\",\"md5\":\"3534a8c981222ffc2edb8aa6cf9a7e5b\"}","audio:volume":22,"audio:voice-packet-id":"FR","audio:voice-change-state":"{\\\"id\\\":\\\"\\\",\\\"state\\\":\\\"idle\\\",\\\"progress\\\":0}","time:time-zone":"Europe\/Paris","time:timer-clean":"","time:timer-cancle":0,"clean-logs:first-clean-time":1701986672,"clean-logs:total-clean-time":5112,"clean-logs:total-clean-times":78,"clean-logs:total-clean-area":4713}
Merci à tous !
