Depuis la mie à jour du RFPlayer d’hier, plus aucun de mes modules ne répond. Tout semble ok sur la page config du RFPLyer, Daemon OK et réinstallation des dépendances réalisée avec succès.
Quoi que je fasse, celui ci n’émet rien. Ni en association ni en on off par exemple
voici un exemple de log
4-12-28 09:09:08] DEBUG : Received a Visonic frame
[2024-12-28 09:09:08] DEBUG : type2
[2024-12-28 09:09:08] DEBUG : Send to jeedom: {'devices': {'89227730': {'data': {'subTypeMeaning': 'Detector/Sensor', 'subType': '0', 'qualifier': '8', 'dBm': '-54'}, 'id': '8922', 'subid': '7730', 'protocol': 'VISONIC', 'raw': {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-54', 'floorNoise': '-97', 'rfQuality': '10', 'protocol': '2', 'protocolMeaning': 'VISONIC', 'infoType': '2', 'frequency': '433920'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '2300737328', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}}}}, 'learn': False}}}
[2024-12-28 09:09:08] DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-12-28 09:09:08] INFO : API RfPlayer solicité
[2024-12-28 09:09:08] DEBUG : http://127.0.0.1:80 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=f4TsxVMyymyr2ZMOMjg4mHZ1xmxBSTgM HTTP/1.1" 200 0
[2024-12-28 09:18:12] DEBUG : Execute Action > Off / OFF / BLYSS / 0
[2024-12-28 09:18:12] INFO : Client connected to [127.0.0.1:45926]
[2024-12-28 09:18:12] INFO : Message read from socket: b'{"apikey":"f4TsxVMyymyr2ZMOMjg4mHZ1xmxBSTgM","cmd":"send","id":"2","action":"OFF","type":"BLYSS","qualifier":"0"}'
[2024-12-28 09:18:12] INFO : Client disconnected from [127.0.0.1:45926]
[2024-12-28 09:18:12] DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-28 09:18:12] DEBUG : Commande SEND
[2024-12-28 09:18:12] DEBUG : OFF 2 BLYSS
[2024-12-28 09:18:12] DEBUG : Sending message ZIA++OFF 2 BLYSS
[2024-12-28 09:18:12] DEBUG : ZIA--
[2024-12-28 09:18:12] DEBUG : error request number=0
[2024-12-28 09:18:12] DEBUG : Syntax error: OFF 2 BLYSS
[2024-12-28 09:18:15] DEBUG : Execute Action > On / ON / BLYSS / 0
[2024-12-28 09:18:15] INFO : Client connected to [127.0.0.1:45928]
[2024-12-28 09:18:15] INFO : Message read from socket: b'{"apikey":"f4TsxVMyymyr2ZMOMjg4mHZ1xmxBSTgM","cmd":"send","id":"2","action":"ON","type":"BLYSS","qualifier":"0"}'
[2024-12-28 09:18:15] INFO : Client disconnected from [127.0.0.1:45928]
[2024-12-28 09:18:15] DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-28 09:18:15] DEBUG : Commande SEND
[2024-12-28 09:18:15] DEBUG : ON 2 BLYSS
[2024-12-28 09:18:15] DEBUG : Sending message ZIA++ON 2 BLYSS
[2024-12-28 09:18:15] DEBUG : ZIA--
[2024-12-28 09:18:15] DEBUG : error request number=0
[2024-12-28 09:18:15] DEBUG : Syntax error: ON 2 BLYSS
Pourquoi syntax error …?
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : oui
