J’ai testé la migration vers la V3, j’ai suivi le tuto, installé SSH-manager, recréer tous les équipements, et il arrive aléatoirement que j’ai des remontées diverses et variées.
Hello, navré du manque de détail. J’ai des erreurs aléatoires que je ne comprends pas du fait que ça fonctionne 8 fois sur 10, les serveurs sont donc joignables et ok (ssh, linux, etc).
Mais génère pas mal d’erreur (une cinquantaine par jour).
Comment résoudre les erreurs aléatoires :
DistriBits SSHException :: Unable to fulfill channel request
ARMv Cmd Exception :: An integer was expected.
DistriName SSHException :: Please close the channel (1) before trying to open it again
uname SSHException :: Please close the channel (1) before trying to open it again
NetworkCard SSHException :: Please close the channel (1) before trying to open it again
Exception (Line 2300) :: Aucune commande distante disponible pour cette architecture
sshmanager :
0000|[2024-11-02 21:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0001|[2024-11-02 22:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0002|[2024-11-02 22:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0003|[2024-11-02 23:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0004|[2024-11-02 23:46:01] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0005|[2024-11-03 00:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0006|[2024-11-03 01:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0007|[2024-11-03 01:46:22] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0008|[2024-11-03 02:01:35] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0009|[2024-11-03 02:15:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0010|[2024-11-03 02:16:03] ERROR : [Docker - SSH] SSH2 Login Exception :: Cannot connect to XX.XX.XX.XX:XX. Error 110. Connection timed out
0011|[2024-11-03 02:30:35] ERROR : [Docker - SSH] SSH2 Login Exception :: Cannot connect to XX.XX.XX.XX:XX. Error 110. Connection timed out
0012|[2024-11-03 02:46:03] ERROR : [Avado - SSH] CPUFreq-1 :: Timeout
0013|[2024-11-03 02:46:38] ERROR : [Avado - SSH] CPUFreq-2 :: Timeout
0014|[2024-11-03 02:47:13] ERROR : [Avado - SSH] CPUTemp-1 :: Timeout
0015|[2024-11-03 02:47:48] ERROR : [Avado - SSH] CPUTemp-2 :: Timeout
0016|[2024-11-03 02:48:24] ERROR : [Avado - SSH] CPUTemp-3 :: Timeout
0017|[2024-11-03 02:48:59] ERROR : [Avado - SSH] CPUTemp-4 :: Timeout
0018|[2024-11-03 02:49:34] ERROR : [Avado - SSH] CPUTemp-5 :: Timeout
0019|[2024-11-03 02:50:45] ERROR : [Docker - SSH] SSH2 Login Exception :: Connection closed due to timeout
0020|[2024-11-03 03:01:40] ERROR : [Docker - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0021|[2024-11-03 03:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0022|[2024-11-03 03:17:11] ERROR : [Docker - SSH] ARMv Exception :: An integer was expected.
0023|[2024-11-03 03:17:11] ERROR : [Docker - SSH] DistriName RunTimeEx :: Please close the channel (1) before trying to open it again
0024|[2024-11-03 03:17:11] ERROR : [Docker - SSH] uname RunTimeEx :: Please close the channel (1) before trying to open it again
0025|[2024-11-03 03:17:11] ERROR : [Docker - SSH] NetworkCard RunTimeEx :: Please close the channel (1) before trying to open it again
0026|[2024-11-03 03:30:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0027|[2024-11-03 03:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0028|[2024-11-03 04:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0029|[2024-11-03 04:16:10] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0030|[2024-11-03 04:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0031|[2024-11-03 05:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0032|[2024-11-03 05:46:09] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0033|[2024-11-03 06:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0034|[2024-11-03 06:15:55] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0035|[2024-11-03 06:31:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0036|[2024-11-03 06:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0037|[2024-11-03 07:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0038|[2024-11-03 08:31:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0039|[2024-11-03 08:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0040|[2024-11-03 09:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0041|[2024-11-03 09:16:34] ERROR : [Docker - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0042|[2024-11-03 09:30:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0043|[2024-11-03 09:45:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0044|[2024-11-03 10:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0045|[2024-11-03 10:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0046|[2024-11-03 10:31:12] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0047|[2024-11-03 10:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0048|[2024-11-03 11:01:35] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0049|[2024-11-03 11:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0050|[2024-11-03 11:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0051|[2024-11-03 12:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0052|[2024-11-03 12:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0053|[2024-11-03 12:31:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0054|[2024-11-03 12:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0055|[2024-11-03 13:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0056|[2024-11-03 13:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0057|[2024-11-03 13:30:47] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0058|[2024-11-03 13:45:50] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0059|[2024-11-03 14:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0060|[2024-11-03 14:16:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0061|[2024-11-03 14:45:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0062|[2024-11-03 15:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0063|[2024-11-03 16:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0064|[2024-11-03 16:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0065|[2024-11-03 16:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0066|[2024-11-03 17:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0067|[2024-11-03 17:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0068|[2024-11-03 17:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0069|[2024-11-03 18:16:04] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0070|[2024-11-03 18:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0071|[2024-11-03 19:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0072|[2024-11-03 19:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0073|[2024-11-03 19:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0074|[2024-11-03 20:01:35] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0075|[2024-11-03 20:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0076|[2024-11-03 20:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0077|[2024-11-03 20:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0078|[2024-11-03 21:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0079|[2024-11-03 21:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0080|[2024-11-03 21:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0081|[2024-11-03 21:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0082|[2024-11-03 22:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0083|[2024-11-03 22:31:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0084|[2024-11-03 22:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0085|[2024-11-03 23:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0086|[2024-11-03 23:31:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0087|[2024-11-03 23:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0088|[2024-11-04 00:01:35] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0089|[2024-11-04 00:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0090|[2024-11-04 00:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0091|[2024-11-04 01:31:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0092|[2024-11-04 01:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0093|[2024-11-04 02:01:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0094|[2024-11-04 02:16:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0095|[2024-11-04 02:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0096|[2024-11-04 02:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0097|[2024-11-04 03:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0098|[2024-11-04 03:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0099|[2024-11-04 03:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0100|[2024-11-04 04:01:00] ERROR : [Avado - SSH] DistriName :: Timeout
0101|[2024-11-04 04:01:16] ERROR : [Avado - SSH] DistriBits RunTimeEx :: Unable to fulfill channel request
0102|[2024-11-04 04:01:16] ERROR : [Avado - SSH] OsVersion :: Disconnected
0103|[2024-11-04 04:01:16] ERROR : [Avado - SSH] Uptime :: Disconnected
0104|[2024-11-04 04:01:16] ERROR : [Avado - SSH] LoadAverage :: Disconnected
0105|[2024-11-04 04:01:16] ERROR : [Avado - SSH] Memory :: Disconnected
0106|[2024-11-04 04:01:16] ERROR : [Avado - SSH] Swap :: Disconnected
0107|[2024-11-04 04:01:16] ERROR : [Avado - SSH] HDD :: Disconnected
0108|[2024-11-04 04:01:16] ERROR : [Avado - SSH] ReseauRXTX :: Disconnected
0109|[2024-11-04 04:01:16] ERROR : [Avado - SSH] ReseauIP :: Disconnected
0110|[2024-11-04 04:01:16] ERROR : [Avado - SSH] NbCPU :: Disconnected
0111|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUFreq-1 :: Disconnected
0112|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUFreq-2 :: Disconnected
0113|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUTemp-1 :: Disconnected
0114|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUTemp-2 :: Disconnected
0115|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUTemp-3 :: Disconnected
0116|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUTemp-4 :: Disconnected
0117|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUTemp-5 :: Disconnected
0118|[2024-11-04 04:01:16] ERROR : [Avado - SSH] CPUTemp-6 :: Disconnected
0119|[2024-11-04 04:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0120|[2024-11-04 05:01:35] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0121|[2024-11-04 05:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0122|[2024-11-04 05:31:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0123|[2024-11-04 05:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0124|[2024-11-04 06:01:35] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0125|[2024-11-04 06:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0126|[2024-11-04 06:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0127|[2024-11-04 07:00:52] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0128|[2024-11-04 07:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0129|[2024-11-04 07:31:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0130|[2024-11-04 07:46:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0131|[2024-11-04 08:01:34] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0132|[2024-11-04 08:46:32] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0133|[2024-11-04 09:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
0134|[2024-11-04 09:30:40] ERROR : [Avado - SSH] ARMv Exception :: An integer was expected.
0135|[2024-11-04 09:30:40] ERROR : [Avado - SSH] DistriName RunTimeEx :: Please close the channel (1) before trying to open it again
0136|[2024-11-04 09:30:40] ERROR : [Avado - SSH] uname RunTimeEx :: Please close the channel (1) before trying to open it again
0137|[2024-11-04 09:30:40] ERROR : [Avado - SSH] NetworkCard RunTimeEx :: Please close the channel (1) before trying to open it again
0138|[2024-11-04 09:46:00] ERROR : [Avado - SSH] SSH2 Login Exception :: Connection closed due to timeout
0139|[2024-11-04 10:16:33] ERROR : [Avado - SSH] SSH2 Login Exception :: Error reading SSH identification string; are you sure you're connecting to an SSH server?
monitoring :
0000|[2024-11-02 21:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0001|[2024-11-02 22:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0002|[2024-11-02 22:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0003|[2024-11-02 23:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0004|[2024-11-02 23:46:01] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0005|[2024-11-03 00:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0006|[2024-11-03 01:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0007|[2024-11-03 01:46:22] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0008|[2024-11-03 02:01:35] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0009|[2024-11-03 02:15:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0010|[2024-11-03 02:16:03] ERROR : [Stats_Docker][SSH-CNX] Connection :: KO
0011|[2024-11-03 02:30:35] ERROR : [Stats_Docker][SSH-CNX] Connection :: KO
0012|[2024-11-03 02:50:45] ERROR : [Stats_Docker][SSH-CNX] Connection :: KO
0013|[2024-11-03 03:01:40] ERROR : [Stats_Docker][SSH-CNX] Connection :: KO
0014|[2024-11-03 03:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0015|[2024-11-03 03:17:11] ERROR : [Stats_Docker][SSH-EXEC] ARMv Cmd Exception :: An integer was expected.
0016|[2024-11-03 03:17:11] ERROR : [Stats_Docker][SSH-EXEC] DistriName SSHException :: Please close the channel (1) before trying to open it again
0017|[2024-11-03 03:17:11] ERROR : [Stats_Docker][SSH-EXEC] uname SSHException :: Please close the channel (1) before trying to open it again
0018|[2024-11-03 03:17:11] ERROR : [Stats_Docker][SSH-EXEC] NetworkCard SSHException :: Please close the channel (1) before trying to open it again
0019|[2024-11-03 03:17:11] ERROR : [Stats_Docker][getInformations] Exception (Line 2300) :: Aucune commande distante disponible pour cette architecture
0020|[2024-11-03 03:30:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0021|[2024-11-03 03:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0022|[2024-11-03 04:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0023|[2024-11-03 04:16:10] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0024|[2024-11-03 04:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0025|[2024-11-03 05:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0026|[2024-11-03 05:46:09] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0027|[2024-11-03 06:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0028|[2024-11-03 06:15:55] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0029|[2024-11-03 06:31:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0030|[2024-11-03 06:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0031|[2024-11-03 07:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0032|[2024-11-03 08:31:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0033|[2024-11-03 08:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0034|[2024-11-03 09:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0035|[2024-11-03 09:16:34] ERROR : [Stats_Docker][SSH-CNX] Connection :: KO
0036|[2024-11-03 09:30:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0037|[2024-11-03 09:45:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0038|[2024-11-03 10:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0039|[2024-11-03 10:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0040|[2024-11-03 10:31:12] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0041|[2024-11-03 10:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0042|[2024-11-03 11:01:35] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0043|[2024-11-03 11:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0044|[2024-11-03 11:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0045|[2024-11-03 12:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0046|[2024-11-03 12:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0047|[2024-11-03 12:31:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0048|[2024-11-03 12:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0049|[2024-11-03 13:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0050|[2024-11-03 13:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0051|[2024-11-03 13:30:47] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0052|[2024-11-03 13:45:50] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0053|[2024-11-03 14:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0054|[2024-11-03 14:16:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0055|[2024-11-03 14:45:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0056|[2024-11-03 15:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0057|[2024-11-03 16:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0058|[2024-11-03 16:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0059|[2024-11-03 16:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0060|[2024-11-03 17:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0061|[2024-11-03 17:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0062|[2024-11-03 17:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0063|[2024-11-03 18:16:04] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0064|[2024-11-03 18:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0065|[2024-11-03 19:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0066|[2024-11-03 19:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0067|[2024-11-03 19:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0068|[2024-11-03 20:01:35] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0069|[2024-11-03 20:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0070|[2024-11-03 20:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0071|[2024-11-03 20:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0072|[2024-11-03 21:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0073|[2024-11-03 21:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0074|[2024-11-03 21:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0075|[2024-11-03 21:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0076|[2024-11-03 22:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0077|[2024-11-03 22:31:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0078|[2024-11-03 22:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0079|[2024-11-03 23:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0080|[2024-11-03 23:31:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0081|[2024-11-03 23:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0082|[2024-11-04 00:01:35] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0083|[2024-11-04 00:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0084|[2024-11-04 00:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0085|[2024-11-04 01:31:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0086|[2024-11-04 01:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0087|[2024-11-04 02:01:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0088|[2024-11-04 02:16:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0089|[2024-11-04 02:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0090|[2024-11-04 02:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0091|[2024-11-04 03:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0092|[2024-11-04 03:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0093|[2024-11-04 03:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0094|[2024-11-04 04:01:16] ERROR : [Stats_Avado][SSH-EXEC] DistriBits SSHException :: Unable to fulfill channel request
0095|[2024-11-04 04:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0096|[2024-11-04 05:01:35] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0097|[2024-11-04 05:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0098|[2024-11-04 05:31:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0099|[2024-11-04 05:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0100|[2024-11-04 06:01:35] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0101|[2024-11-04 06:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0102|[2024-11-04 06:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0103|[2024-11-04 07:00:52] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0104|[2024-11-04 07:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0105|[2024-11-04 07:31:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0106|[2024-11-04 07:46:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0107|[2024-11-04 08:01:34] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0108|[2024-11-04 08:46:32] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0109|[2024-11-04 09:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0110|[2024-11-04 09:30:40] ERROR : [Stats_Avado][SSH-EXEC] ARMv Cmd Exception :: An integer was expected.
0111|[2024-11-04 09:30:40] ERROR : [Stats_Avado][SSH-EXEC] DistriName SSHException :: Please close the channel (1) before trying to open it again
0112|[2024-11-04 09:30:40] ERROR : [Stats_Avado][SSH-EXEC] uname SSHException :: Please close the channel (1) before trying to open it again
0113|[2024-11-04 09:30:40] ERROR : [Stats_Avado][SSH-EXEC] NetworkCard SSHException :: Please close the channel (1) before trying to open it again
0114|[2024-11-04 09:30:40] ERROR : [Stats_Avado][getInformations] Exception (Line 2300) :: Aucune commande distante disponible pour cette architecture
0115|[2024-11-04 09:46:00] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
0116|[2024-11-04 10:16:33] ERROR : [Stats_Avado][SSH-CNX] Connection :: KO
Et on voit que les remontées fonctionnent car j’ai la data quand il n’y a pas d’erreurs :
ok je vois
c’est qd même beaucoup avec « stats-avado » qui est en fait plus que surchargé: 100 de charge!
ca ne m’étonne pas que ca soit compliqué d’établir une connexion ssh avec cette machine => il faudrait régler ce problème de charge
Pourrais tu remettre les infos sur les versions des plugins monitoring et sshmanager ? (Tu peux avoir le tout en utilisant le bouton assistance dans jeedom sur la page du plugin, sinon à la mano
Les erreurs que tu indiques sont des erreurs ssh de communication avec l’équipement en question.
Les raisins peuvent être multiples : instabilité du réseau (perte aléatoire de connexion quelque part en jeedom et l’équipement), saturation de l’équipement en face et du coup qui ne répond pas aux demandes du plugin, et lorsqu’une commande ne répond pas correctement toutes celles qui sont en attentes derrière plantent c’est ce qu’on voit lorsqu’il te dit qu’il faut fermer le channel avant d’en ouvrir un autre.
Mais il me semblait avoir intercepté ces erreurs justement, d’où ma question sur les versions utilisés
100 de LoadAverage ne veut rien dire si la machine à 100 cores Il faut voir ce qu’il y’a en face.
L’accès SSH fonctionne bien j’y ai accès en permanence la journée que je monitore en live (c’est un node de production), et je n’ai pas eu de soucis avec les précédentes versions.
Top merci pour le retour. Normalement la machine est niquel et j’ai bien accès en SSH comme je disais car j’y suis en monitoring.
De plus je n’avais pas de logs erreurs en V2 et les datas étaient bonnes. Est-ce que le cron a été rapproché ? Je peux toujours tenter de le mettre en */5 si cela peut aider.
Non un Xeon de 32 core donc le ratio est pas si déconnant.
I know mais on apprend en formation que pour un core il faut un ratio de 1 LA équivalent (car les bridges gèrent une quantité dédiée de mémoire, et donc de R/W qui transitent également). Un 32 core avec 32 LA à donc « raisonnablement » la même charge qu’un mono quad core à 4 de LA. Ce qui est effectivement en charge mais pour des machines de prod c’est rarement light le LA
Toujours est-il que ce n’est pas la source du soucis (ou alors la méthode v2 vs v3 à complètement changée et énormément consommatrice de ressources), car encore une fois aucun soucis de connexion SSH (ni aucune coupure sur mes monitorings), et des relevés à la même heure me montrent que l’accès à la machine est bien valide en externe, pour ces données (grafana, prometheus) et donc je cherche une piste lié plutôt à la méthodologie du plugin
Car j’ai dupliqué (j’ai des dizaines de serveurs en surveillance, pas pratique de customiser un par un), je ferais cela plus tard une fois tout fonctionnel.
Attention, la commande last ne remonte que les connexions interactives ! Une connexion ssh portée par ssh manager ne remontera pas par la commande last
plutot aller voir dans le fichier /var/log/auth.log pour voir les connexions non interactives (ex : ssh jeedom@monserveur.com ‹ ma super commande ›)
Tu auras aussi tout le processus d’authentification dans ce fichier. Si pas d’entrée dans ce fichier, c’ets que la demande de connexion n’arrive pas jusqu’au serveur
Pour en savoir plus, il faudrait également passer les logs en « débug » à la fois côté Monitoring et côté SSH-Manager, tu en sauras beaucoup plus sur ce qu’il peut se passer et sans doute la raison de ces erreurs.
Il faut savoir également qu’il y a eu beaucoup de changements entre la v2.5 et la v3.x, et entre autre au niveau des logs : beaucoup de logs ont été ajoutées (pour faciliter le debug justement).
A l’inverse, beaucoup d’erreurs en v2.5 n’étaient pas loggées, donc on pouvait « croire » que cela fonctionnait, mais au final, il pouvait y avoir quelques loupés des connexions SSH sans que cela ne remonte dans les logs
Et attention, je ne dis pas qu’il n’y a pas un soucis quelque part j’essaie juste d’expliquer que le code a été totalement revu entre la v2.5 et la v3.x avec ses avantages, mais sûrement aussi quelques inconvénients que l’on découvrira au fil du temps
Je vais voir pour passer en debug et faire le retour.
Je suis par ailleurs passé en cron 15 min et ça semble mieux. Pourrait-il y’avoir par exemple avant un cron minute et un timeout de 70 sec qui ferait que ça se marche dessus et cafouille ?
Intéressant alors peut être que j’avais des erreurs sans le savoir alors ^^ Merci du retour, je mets ça en debug, j’analyse, et je vire mon */15 au besoin pour voir le comportement une fois rapproché
