Différence Backup auto & Manuel
Tout est dans le titre.
Pas bloquant mais bizarre.
Sauvegarde AUTO :
0021|***************Start of Jeedom backup at 2026-06-27 01:22:01***************
0022|Send begin backup event...OK
0023|Checking files rights...OK
0024|Backing up plugin JeedomConnect...OK
0025|Checking  table aprescouchésoleil...OK
0026|Checking  table apreslevésoleil...OK
0027|Checking  table avantcouchésoleil...OK
0028|Checking  table avantlevésoleil...OK
0029|Checking  table cache...OK
0030|Checking  table cmd...OK
0031|Checking  table config...OK
0032|Checking  table cron...OK
0033|Checking  table dataStore...OK
0034|Checking  table eqLogic...OK
0035|Checking  table eqReal...OK
0036|Checking  table history...OK
0037|Checking  table historyArch...OK
0038|Checking  table interactDef...OK
0039|Checking  table interactQuery...OK
0040|Checking  table listener...OK
0041|Checking  table mesVin...OK
0042|Checking  table message...OK
0043|Checking  table note...OK
Sauvegarde MANUELLE :
0000|[START BACKUP]
0001|***************Start of Jeedom backup at 2026-06-27 06:10:29***************
0002|Send begin backup event...OK
0003|Checking files rights...OK
0004|Backing up plugin JeedomConnect...OK
0005|Checking  table aprescouchésoleil...Failed to SHOW CREATE TABLE `aprescouchésoleil`
0006|Error: Table 'jeedom.aprescouchésoleil' doesn't exist
0007|OK
0008|Checking  table apreslevésoleil...Failed to SHOW CREATE TABLE `apreslevésoleil`
0009|Error: Table 'jeedom.apreslevésoleil' doesn't exist
0010|OK
0011|Checking  table avantcouchésoleil...Failed to SHOW CREATE TABLE `avantcouchésoleil`
0012|Error: Table 'jeedom.avantcouchésoleil' doesn't exist
0013|OK
0014|Checking  table avantlevésoleil...Failed to SHOW CREATE TABLE `avantlevésoleil`
0015|Error: Table 'jeedom.avantlevésoleil' doesn't exist
0016|OK
0017|Checking  table cache...OK
0018|Checking  table cmd...OK
0019|Checking  table config...OK
0020|Checking  table cron...OK
0021|Checking  table dataStore...OK
0022|Checking  table eqLogic...OK
0023|Checking  table eqReal...OK
0024|Checking  table history...OK
0025|Checking  table historyArch...OK
0026|Checking  table interactDef...OK
0027|Checking  table interactQuery...OK
0028|Checking  table listener...OK
0029|Checking  table mesVin...OK
0030|Checking  table message...OK
0031|Checking  table note...OK
Et puis c’est quoi ces tables ??
0086|Checking  table aprescouchésoleil...OK
0087|Checking  table apreslevésoleil...OK
0088|Checking  table avantcouchésoleil...OK
0089|Checking  table avantlevésoleil...OK
Tables_in_jeedom
aprescouchésoleil
apreslevésoleil
avantcouchésoleil
avantlevésoleil
Même sujet ici pour les 4 tables
Essai les commandes d’Aurelien pour voir si on retrouve le plugin qui gère mais je pense que ça va être la même chose que le collègue
Je n’avais pas vu ce post. Je suis exactement dans le même cas.
Rien dans les recherches !
ça ressemble donc à un plugin qui avait crée ces tables et que tu as désinstallé depuis (mais qui n’a pas supprimé les DBs).
Donc à part les supprimer à la main je vois pas trop quoi faire d’autre.
Maintenant sjur la base du post à savoir que le comportement est différent entre un backup automatique et manuel, là je ne sais pas
C’est surement cela mauvaise désinstallation d’un plugin.
Pour les backup c’est probablement les caractères accentués qui ne sont pas reconnus.
C’est pas grave.
Pour faire des actions avant et après le coucher du soleil, un plugin de simulation de présence par exemple ?
C’est la Solution
