bonjour
après intégration nouveau détecteur présence, dans le log debug le dps 101 change d’état true/false mais la commande jeedom (sous type: présence 01)correspondante ne change pas d’état…
[2021-04-04 17:54:15][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-04-04 17:54:15][DEBUG] : ** gateway tuya - TuyaCustom2_Hub_V2 @192.168.1.125 - c:1 **
[2021-04-04 17:54:15][DEBUG] : key:0 @192.168.1.125 c:1 d:19
[2021-04-04 17:54:15][DEBUG] : ** PIR - TuyaCustom2_V2 @192.168.1.125 - c:1 **
[2021-04-04 17:54:15][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-04-04 17:54:15][DEBUG] : Memory used :1898 ko 48 o
[2021-04-04 17:54:15][DEBUG] : Receive from:192.168.1.125
[2021-04-04 17:54:15][DEBUG] : Mess: {"dps":{"101":true},"cid":"ec1bbdfffe95432c","t":1617551654} - Read Json OK
[2021-04-04 17:54:15][DEBUG] : gateway tuya @192.168.1.125
[2021-04-04 17:54:15][DEBUG] : Update devices @192.168.1.125 canal:1
[2021-04-04 17:54:15][DEBUG] : No dps states to update
[2021-04-04 17:54:15][DEBUG] : No other states to update
[2021-04-04 17:54:17][DEBUG] : << Ping of: gateway tuya @192.168.1.125 diff:21
[2021-04-04 17:54:17][DEBUG] : Cmd to 192.168.1.125: - Try:192.168.1.125 6668 - Connect OK!
[2021-04-04 17:54:17][DEBUG] : Receive from:192.168.1.125
[2021-04-04 17:54:17][DEBUG] : Mess: Empty
[2021-04-04 17:54:38][DEBUG] : << Ping of: gateway tuya @192.168.1.125 diff:21
[2021-04-04 17:54:38][DEBUG] : Cmd to 192.168.1.125: - Try:192.168.1.125 6668 - Connect OK!
[2021-04-04 17:54:38][DEBUG] : Receive from:192.168.1.125
[2021-04-04 17:54:38][DEBUG] : Mess: Empty
[2021-04-04 17:54:59][DEBUG] : << Ping of: gateway tuya @192.168.1.125 diff:21
[2021-04-04 17:54:59][DEBUG] : Cmd to 192.168.1.125: - Try:192.168.1.125 6668 - Connect OK!
[2021-04-04 17:54:59][DEBUG] : Receive from:192.168.1.125
[2021-04-04 17:55:16][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-04-04 17:55:16][DEBUG] : ** gateway tuya - TuyaCustom2_Hub_V2 @192.168.1.125 - c:1 **
[2021-04-04 17:55:16][DEBUG] : key:0 @192.168.1.125 c:1 d:17
[2021-04-04 17:55:16][DEBUG] : ** PIR - TuyaCustom2_V2 @192.168.1.125 - c:1 **
[2021-04-04 17:55:16][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-04-04 17:55:16][DEBUG] : Memory used :1908 ko 552 o
[2021-04-04 17:55:16][DEBUG] : Receive from:192.168.1.125
[2021-04-04 17:55:16][DEBUG] : Mess: {"dps":{"101":false},"cid":"ec1bbdfffe95432c","t":1617551715} - Read Json OK
[2021-04-04 17:55:16][DEBUG] : gateway tuya @192.168.1.125
[2021-04-04 17:55:16][DEBUG] : Update devices @192.168.1.125 canal:1
[2021-04-04 17:55:16][DEBUG] : No dps states to update
[2021-04-04 17:55:16][DEBUG] : No other states to update
[2021-04-04 17:55:20][DEBUG] : << Ping of: gateway tuya @192.168.1.125 diff:21
[2021-04-04 17:55:20][DEBUG] : Cmd to 192.168.1.125: - Try:192.168.1.125 6668 - Connect OK!
[2021-04-04 17:55:20][DEBUG] : Receive from:192.168.1.125
[2021-04-04 17:55:20][DEBUG] : Mess: Empty
