bonjour @Doubledom ,merci pour le retour.
Voici la page de commande
et voici le log avec le capteur ajoute - demon non redemarré :
`[2021-03-05 17:07:06][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-89", "floorNoise": "-103", "rfQuality": "3", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:07:06][DEBUG] : Received a Chacon frame
[2021-03-05 17:07:06][DEBUG] : type1
[2021-03-05 17:07:06][DEBUG] : Send to jeedom : {'devices': {'43343c0': {'protocol': 'CHACON', 'subid': '3c0', 'raw': {'frame': {'header': {'rfQuality': '3', 'protocol': '4', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-89', 'dataFlag': '0', 'infoType': '1', 'protocolMeaning': 'CHACON'}, 'infos': {'subType': '0', 'id': '70468544', 'subTypeMeaning': 'OFF'}}}, 'learn': False, 'data': {'subType': '0', 'dBm': '-89', 'subTypeMeaning': 'OFF', 'info_3c0': '0'}, 'id': '4334'}}}
[2021-03-05 17:07:06][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2021-03-05 17:07:06][INFO] : API RfPlayer solicité
[2021-03-05 17:07:06][DEBUG] : http://127.0.0.1:43666 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=ubGpsC80MH1qCrVcG0LYDAA5Asb80G27 HTTP/1.1" 200 0
[2021-03-05 17:07:06][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-95", "floorNoise": "-103", "rfQuality": "2", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:07:06][DEBUG] : Send to jeedom : {'devices': {'43343c0': {'protocol': 'CHACON', 'subid': '3c0', 'raw': {'frame': {'header': {'rfQuality': '2', 'protocol': '4', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-95', 'dataFlag': '0', 'infoType': '1', 'protocolMeaning': 'CHACON'}, 'infos': {'subType': '0', 'id': '70468544', 'subTypeMeaning': 'OFF'}}}, 'learn': False, 'data': {'subType': '0', 'dBm': '-95', 'subTypeMeaning': 'OFF', 'info_3c0': '0'}, 'id': '4334'}}}
[2021-03-05 17:07:07][INFO] : API RfPlayer solicité
[2021-03-05 17:07:07][DEBUG] : http://127.0.0.1:43666 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=ubGpsC80MH1qCrVcG0LYDAA5Asb80G27 HTTP/1.1" 200 0
[2021-03-05 17:07:07][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-75", "floorNoise": "-103", "rfQuality": "7", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xEA4C", "id_PHYMeaning": "THC238/268,THWR288,THRN122,THN122/132,AW129/131", "adr_channel": "25345", "adr": "99", "channel": "1", "qualifier": "32", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+18.0", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "0", "unit" : "%"}]}}}
[2021-03-05 17:07:07][DEBUG] : Received an Oregon frame
[2021-03-05 17:07:07][DEBUG] : type4
[2021-03-05 17:07:07][DEBUG] : Send to jeedom : {'devices': {'25345': {'protocol': 'OREGON', 'raw': {'frame': {'header': {'rfQuality': '7', 'protocol': '5', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-75', 'dataFlag': '0', 'infoType': '4', 'protocolMeaning': 'OREGON'}, 'infos': {'id_PHYMeaning': 'THC238/268,THWR288,THRN122,THN122/132,AW129/131', 'adr': '99', 'qualifier': '32', 'id_PHY': '0xEA4C', 'adr_channel': '25345', 'measures': [{'type': 'temperature', 'value': '+18.0', 'unit': 'Celsius'}, {'type': 'hygrometry', 'value': '0', 'unit': '%'}], 'subType': '0', 'lowBatt': '0', 'channel': '1'}}}, 'learn': False, 'model': '0xEA4C', 'data': {'battery': '100', 'batterybinary': '0', 'dBm': '-75', 'hygrometry': '0', 'temperature': '+18.0'}, 'id': '25345'}}}
[2021-03-05 17:07:07][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2021-03-05 17:07:07][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-95", "floorNoise": "-103", "rfQuality": "2", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "1", "id": "70468544", "subTypeMeaning": "ON"}}}
[2021-03-05 17:07:07][DEBUG] : Received a Chacon frame
[2021-03-05 17:07:07][DEBUG] : type1
[2021-03-05 17:07:08][DEBUG] : Send to jeedom : {'devices': {'43343c0': {'protocol': 'CHACON', 'subid': '3c0', 'raw': {'frame': {'header': {'rfQuality': '2', 'protocol': '4', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-95', 'dataFlag': '0', 'infoType': '1', 'protocolMeaning': 'CHACON'}, 'infos': {'subType': '1', 'id': '70468544', 'subTypeMeaning': 'ON'}}}, 'learn': False, 'data': {'subType': '1', 'dBm': '-95', 'subTypeMeaning': 'ON', 'info_3c0': '1'}, 'id': '4334'}}}
[2021-03-05 17:07:08][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2021-03-05 17:07:08][INFO] : API RfPlayer solicité
[2021-03-05 17:07:08][DEBUG] : http://127.0.0.1:43666 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=ubGpsC80MH1qCrVcG0LYDAA5Asb80G27 HTTP/1.1" 200 0
[2021-03-05 17:07:08][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-93", "floorNoise": "-103", "rfQuality": "2", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:07:08][DEBUG] : Received a Chacon frame
[2021-03-05 17:07:08][DEBUG] : type1
[2021-03-05 17:07:08][DEBUG] : Send to jeedom : {'devices': {'43343c0': {'protocol': 'CHACON', 'subid': '3c0', 'raw': {'frame': {'header': {'rfQuality': '2', 'protocol': '4', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-93', 'dataFlag': '0', 'infoType': '1', 'protocolMeaning': 'CHACON'}, 'infos': {'subType': '0', 'id': '70468544', 'subTypeMeaning': 'OFF'}}}, 'learn': False, 'data': {'subType': '0', 'dBm': '-93', 'subTypeMeaning': 'OFF', 'info_3c0': '0'}, 'id': '4334'}}}
[2021-03-05 17:07:09][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-91", "floorNoise": "-103", "rfQuality": "3", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:07:09][DEBUG] : Received a Chacon frame
[2021-03-05 17:07:09][DEBUG] : type1
[2021-03-05 17:07:09][DEBUG] : Send to jeedom : {'devices': {'43343c0': {'protocol': 'CHACON', 'subid': '3c0', 'raw': {'frame': {'header': {'rfQuality': '3', 'protocol': '4', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-91', 'dataFlag': '0', 'infoType': '1', 'protocolMeaning': 'CHACON'}, 'infos': {'subType': '0', 'id': '70468544', 'subTypeMeaning': 'OFF'}}}, 'learn': False, 'data': {'subType': '0', 'dBm': '-91', 'subTypeMeaning': 'OFF', 'info_3c0': '0'}, 'id': '4334'}}}
[2021-03-05 17:07:09][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2021-03-05 17:07:09][INFO] : API RfPlayer solicité
[2021-03-05 17:07:09][DEBUG] : http://127.0.0.1:43666 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=ubGpsC80MH1qCrVcG0LYDAA5Asb80G27 HTTP/1.1" 200 0
[2021-03-05 17:07:10][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-90", "floorNoise": "-103", "rfQuality": "3", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "1", "id": "70468544", "subTypeMeaning": "ON"}}}
[2021-03-05 17:07:10][DEBUG] : Received a Chacon frame
[2021-03-05 17:07:10][DEBUG] : type1
[2021-03-05 17:07:10][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-91", "floorNoise": "-103", "rfQuality": "3", "protocol": "6", "protocolMeaning": "DOMIA", "infoType": "0", "frequency": "433920"},"infos": {"subType": "0", "id": "0", "subTypeMeaning": "OFF", "idMeaning": "A1"}}}
[2021-03-05 17:07:10][DEBUG] : Received a Domia frame
[2021-03-05 17:07:10][DEBUG] : type0
[2021-03-05 17:07:10][DEBUG] : Device with id A1 is not included
[2021-03-05 17:07:10][DEBUG] : Send to jeedom : {'devices': {'43343c0': {'protocol': 'CHACON', 'subid': '3c0', 'raw': {'frame': {'header': {'rfQuality': '3', 'protocol': '4', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-90', 'dataFlag': '0', 'infoType': '1', 'protocolMeaning': 'CHACON'}, 'infos': {'subType': '1', 'id': '70468544', 'subTypeMeaning': 'ON'}}}, 'learn': False, 'data': {'subType': '1', 'dBm': '-90', 'subTypeMeaning': 'ON', 'info_3c0': '1'}, 'id': '4334'}}}
[2021-03-05 17:07:10][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2021-03-05 17:07:10][INFO] : API RfPlayer solicité
[2021-03-05 17:07:10][DEBUG] : http://127.0.0.1:43666 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=ubGpsC80MH1qCrVcG0LYDAA5Asb80G27 HTTP/1.1" 200 0
[2021-03-05 17:07:11][INFO] : API RfPlayer solicité`
ET voici , avec le demon redemarré
`[2021-03-05 17:01:49][DEBUG] : Send to jeedom : {'devices': {'51457': {'protocol': 'OREGON', 'raw': {'frame': {'header': {'rfQuality': '3', 'protocol': '5', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-91', 'dataFlag': '0', 'infoType': '4', 'protocolMeaning': 'OREGON'}, 'infos': {'id_PHYMeaning': 'THC238/268,THWR288,THRN122,THN122/132,AW129/131', 'adr': '201', 'qualifier': '32', 'id_PHY': '0xEA4C', 'adr_channel': '51457', 'measures': [{'type': 'temperature', 'value': '+14.1', 'unit': 'Celsius'}, {'type': 'hygrometry', 'value': '0', 'unit': '%'}], 'subType': '0', 'lowBatt': '0', 'channel': '1'}}}, 'learn': False, 'model': '0xEA4C', 'data': {'battery': '100', 'batterybinary': '0', 'dBm': '-91', 'hygrometry': '0', 'temperature': '+14.1'}, 'id': '51457'}}}
[2021-03-05 17:01:49][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2021-03-05 17:01:49][INFO] : API RfPlayer solicité
[2021-03-05 17:01:49][DEBUG] : http://127.0.0.1:43666 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=ubGpsC80MH1qCrVcG0LYDAA5Asb80G27 HTTP/1.1" 200 0
[2021-03-05 17:01:50][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-68", "floorNoise": "-103", "rfQuality": "8", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x1A2D", "id_PHYMeaning": "THGR122/228/238/268,THGN122/123/132", "adr_channel": "3842", "adr": "15", "channel": "2", "qualifier": "33", "lowBatt": "1", "measures" : [{"type" : "temperature", "value" : "+14.9", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "51", "unit" : "%"}]}}}
[2021-03-05 17:01:50][DEBUG] : Received an Oregon frame
[2021-03-05 17:01:50][DEBUG] : type4
[2021-03-05 17:01:50][DEBUG] : Send to jeedom : {'devices': {'3842': {'protocol': 'OREGON', 'raw': {'frame': {'header': {'rfQuality': '8', 'protocol': '5', 'frameType': '0', 'floorNoise': '-103', 'cluster': '0', 'frequency': '433920', 'rfLevel': '-68', 'dataFlag': '0', 'infoType': '4', 'protocolMeaning': 'OREGON'}, 'infos': {'id_PHYMeaning': 'THGR122/228/238/268,THGN122/123/132', 'adr': '15', 'qualifier': '33', 'id_PHY': '0x1A2D', 'adr_channel': '3842', 'measures': [{'type': 'temperature', 'value': '+14.9', 'unit': 'Celsius'}, {'type': 'hygrometry', 'value': '51', 'unit': '%'}], 'subType': '0', 'lowBatt': '1', 'channel': '2'}}}, 'learn': False, 'model': '0x1A2D', 'data': {'battery': '0', 'batterybinary': '1', 'dBm': '-68', 'hygrometry': '51', 'temperature': '+14.9'}, 'id': '3842'}}}
[2021-03-05 17:01:50][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2021-03-05 17:01:50][INFO] : API RfPlayer solicité
[2021-03-05 17:01:50][DEBUG] : http://127.0.0.1:43666 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=ubGpsC80MH1qCrVcG0LYDAA5Asb80G27 HTTP/1.1" 200 0
[2021-03-05 17:01:51][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-103", "rfQuality": "5", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "1", "id": "70468544", "subTypeMeaning": "ON"}}}
[2021-03-05 17:01:51][DEBUG] : Received a Chacon frame
[2021-03-05 17:01:51][DEBUG] : type1
[2021-03-05 17:01:51][DEBUG] : Device with id 43343c0 is not included
[2021-03-05 17:01:52][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-103", "rfQuality": "5", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:01:52][DEBUG] : Received a Chacon frame
[2021-03-05 17:01:52][DEBUG] : type1
[2021-03-05 17:01:52][DEBUG] : Device with id 43343c0 is not included
[2021-03-05 17:01:54][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-103", "rfQuality": "5", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "1", "id": "70468544", "subTypeMeaning": "ON"}}}
[2021-03-05 17:01:54][DEBUG] : Received a Chacon frame
[2021-03-05 17:01:54][DEBUG] : type1
[2021-03-05 17:01:54][DEBUG] : Device with id 43343c0 is not included
[2021-03-05 17:01:55][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-82", "floorNoise": "-103", "rfQuality": "5", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:01:55][DEBUG] : Received a Chacon frame
[2021-03-05 17:01:55][DEBUG] : type1
[2021-03-05 17:01:55][DEBUG] : Device with id 43343c0 is not included
[2021-03-05 17:01:56][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-103", "rfQuality": "5", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:01:56][DEBUG] : Received a Chacon frame
[2021-03-05 17:01:56][DEBUG] : type1
[2021-03-05 17:01:56][DEBUG] : Device with id 43343c0 is not included
[2021-03-05 17:01:58][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-103", "rfQuality": "5", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "1", "id": "70468544", "subTypeMeaning": "ON"}}}
[2021-03-05 17:01:58][DEBUG] : Received a Chacon frame
[2021-03-05 17:01:58][DEBUG] : type1
[2021-03-05 17:01:58][DEBUG] : Device with id 43343c0 is not included
[2021-03-05 17:01:59][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-82", "floorNoise": "-103", "rfQuality": "5", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "70468544", "subTypeMeaning": "OFF"}}}
[2021-03-05 17:01:59][DEBUG] : Received a Chacon frame
[2021-03-05 17:01:59][DEBUG] : type1
[2021-03-05 17:01:59][DEBUG] : Device with id 43343c0 is not included
[2021-03-05 17:02:06][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-69", "floorNoise": "-103", "rfQuality": "8", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xEA4C", "id_PHYMeaning": "THC238/268,THWR288,THRN122,THN122/132,AW129/131", "adr_channel": "20737", "adr": "81", "channel": "1", "qualifier": "32", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+19.9", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "0", "unit" : "%"}]}}}
[2021-03-05 17:02:06][DEBUG] : Received an Oregon frame
[2021-03-05 17:02:06][DEBUG] : type4`
