Detecteur de présence lidl (HG07310) fonction anti-sabotage
Je relance le sujet sur le détecteur de présence LIDL HG07310 référencé dans le plugin TY0202.
Je pu réaliser l’association du capteur. La présence fonctionne, par contre, pas de retour de la détection d’anti-sabotage.
J’ai passer le plugin ZIGBEE en mode DEBUG et voici ce qu’il récupère:
[2022-09-23 01:06:54]DEBUG : {"devices":{"2c:11:65:ff:fe:81:91:d4":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports|Tamper|Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2022-09-23 01:06:54]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports|Tamper|Alarm_1 convert to 1
[2022-09-23 01:06:54]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2022-09-23 01:06:54]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2022-09-23 01:06:54]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2022-09-23 01:09:27]DEBUG : {"devices":{"2c:11:65:ff:fe:81:91:d4":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports|Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2022-09-23 01:09:27]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports|Alarm_1 convert to 1
[2022-09-23 01:09:27]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2022-09-23 01:09:27]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2022-09-23 01:09:27]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2022-09-23 01:10:47]DEBUG : {"devices":{"2c:11:65:ff:fe:81:91:d4":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2022-09-23 01:10:47]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports convert to 0
[2022-09-23 01:10:47]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2022-09-23 01:10:47]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2022-09-23 01:10:47]DEBUG : Search command for 2c:11:65:ff:fe:81:91:d4 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
L’information sur les retours d’état est sur le logicalId: 1::1280::cmd::1. Le capteur semble envoyer les différents retours sur ce même logicalId:
1 ère manip (anti-sabotage et détection présence) 01:06:54 → ZoneStatus.Restore_reports|Tamper|Alarm_1
2 ème manip (détection présence) 01:09:27 → ZoneStatus.Restore_reports|Alarm_1
3 ème manip (aucune action, envoi de fin de détection de présence après temporisation) 01:10:47 → ZoneStatus.Restore_reports
Il semblerai que le TAMPER soit en lien avec l’anti-sabotage.
Est-ce qu’il y aurait moyen de récupérer l’information d’anti-sabotage à part de la présence.?
En vous remerciant par avance.
Pour solliciter l’ajout d’un nouveau matériel, il est nécessaire de fournir les éléments suivants :
  • le modèle exact du module avec un lien vers le site d’achat et une image représentative sur fond transparent (png),
  • Sur la page de l’équipement, cliquer sur le bouton bleu Configuration du module puis onglet Informations brutes. Copier le contenu pour le transmettre à l’équipe Jeedom,
  • Mettre le démon en debug depuis la page de configuration du plugin et le redémarrer. Effectuer des actions sur l’équipement (si c’est un capteur de température faire varier la température, si c’est une vanne faire varier la consigne, etc…) et envoyer le log zigbee (pas zigbeed).
→ Source
voila une image
c8eb787d33b4c61fca4d254c4789f3d8-removebg-preview
et voila les infos brutes
    "battery": 100,
    "last_seen": "2022-12-22T15:41:47.706Z",
    "device": {
        "applicationVersion": 67,
        "dateCode": "2021.1.5",
        "friendlyName": "Detecteur garage",
        "hardwareVersion": 1,
        "ieeeAddr": "0x2c1165fffed596f4",
        "manufacturerID": 4619,
        "manufacturerName": "_TZ1800_fcdjzz3s",
        "model": "HG06335/HG07310",
        "networkAddress": 44683,
        "powerSource": "Battery",
        "stackVersion": 2,
        "type": "EndDevice",
        "zclVersion": 1
    "linkquality": 255
et pour moi j’essaie de l'intégrer depuis 4 mois sans succès
merci
Bonsoir.
Des nouvelles quant à la prise en charge de ce matériel par le plugin zigbee ?
Cordialement.
ça marche impeccable avec la combe II.
l’autoprotection = tampered
Bon weekend !
