Bonjour @Loic,
Merci de votre retour rapide (et désolé du mien un peu moins rapide).
Voici les logs lors du déclenchement (donc il y a bien qqch qui remonte contrairement à ce que je disais, je débute un peu pas encore le reflexe du mode debug) :
[2022-06-13 18:48:04][DEBUG] : {"devices":{"84:2e:14:ff:fe:f8:0c:ee":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Restore_reports","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2022-06-13 18:48:04][DEBUG] : Search command for 84:2e:14:ff:fe:f8:0c:ee logicalId : 1::1280::cmd::1 => ZoneStatus.Restore_reports convert to 0
[2022-06-13 18:48:04][DEBUG] : Search command for 84:2e:14:ff:fe:f8:0c:ee logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2022-06-13 18:48:04][DEBUG] : Search command for 84:2e:14:ff:fe:f8:0c:ee logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2022-06-13 18:48:04][DEBUG] : Search command for 84:2e:14:ff:fe:f8:0c:ee logicalId : 1::1280::cmd::1.3 => 0 convert to 0
Voici les logs à l’ajout de l’appareil à toute fin utile:
0436|[2022-06-13 18:44:36][DEBUG] : [{"ieee":"00:15:8d:00:06:79:44:a3","nwk":"0x37a1","lqi":105,"rssi":0,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.vibration.aq1","offline":false,"neighbours":[]},{"ieee":"84:71:27:ff:fe:0c:7c:f3","nwk":"0xeed6","lqi":102,"rssi":0,"device_type":"EndDevice","manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","offline":false,"neighbours":[]},{"ieee":"84:71:27:ff:fe:16:69:24","nwk":"0x8d2a","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","offline":false,"neighbours":[]},{"ieee":"84:2e:14:ff:fe:f8:0c:ee","nwk":"0xa538","lqi":135,"rssi":0,"device_type":"EndDevice","manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:b0:ff:ed","nwk":"0x61e3","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:c5:71:66","nwk":"0xf678","lqi":168,"rssi":0,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:b0:ff:b3","nwk":"0x0d7b","lqi":135,"rssi":0,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:d4:1b:3c","nwk":"0xb7d3","lqi":57,"rssi":0,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:d4:1c:6a","nwk":"0x449c","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:d3:f0:bc","nwk":"0x51c3","lqi":150,"rssi":0,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"8c:f6:81:ff:fe:e9:09:37","nwk":"0x7702","lqi":96,"rssi":0,"device_type":"Router","manufacturer":"_TZ3000_5k5vh43t","model":"TS0207","offline":false,"neighbours":[{"ieee":"00:15:8d:00:00:4d:67:ad","nwk":"0x0000","lqi":172,"rssi":null,"pan_id":"14:85:51:e6:85:d0:35:66","device_type":"unknown","rx_on_when_idle":"On","relation":"Parent","new_joins_accepted":"Unknown","depth":0,"model":"ZiGate USB-TTL 3.1d","manufacturer":"ZiGate","offline":false,"supported":true}]},{"ieee":"00:15:8d:00:00:4d:67:ad","nwk":"0x0000","lqi":null,"rssi":null,"device_type":"unknown","manufacturer":"ZiGate","model":"ZiGate USB-TTL 3.1d","offline":false,"neighbours":[]}]
0437|[2022-06-13 18:44:36][DEBUG] : [{"ieee":"00:15:8d:00:06:79:44:a3","nwk":14241,"status":2,"lqi":"105","rssi":"0","last_seen":"1655137147.256705","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":10,"profile_id":260,"manufacturer":"LUMI","model":"lumi.vibration.aq1","output_clusters":[{"id":0,"name":"VibrationBasicCluster","attributes":[]},{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"VibrationBasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":8},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":3},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.vibration.aq1"},{"id":6,"name":"date_code","value":"20180130"},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.1},{"id":33,"name":"battery_percentage_remaining","value":139}]},{"id":2,"name":"Device Temperature","attributes":[{"id":0,"name":"current_temperature","value":2600}]},{"id":3,"name":"Identify","attributes":[]},{"id":1280,"name":"IAS Zone","attributes":[{"id":0,"name":"zone_state","value":0},{"id":16,"name":"cie_addr","value":"00:15:8d:00:00:4d:67:ad"}]},{"id":25,"name":"Ota","attributes":[]},{"id":257,"name":"MultistateInputCluster","attributes":[{"id":85,"name":"present_value","value":1}]}]},{"id":2,"status":1,"device_type":24322,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":18,"name":"MultistateInput","attributes":[]}],"input_clusters":[{"id":3,"name":"Identify","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.vibration.aq1","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":10,"input_clusters":[0,1,2,3,1280,25,257],"output_clusters":[0,3,4,5,25]},"2":{"profile_id":260,"device_type":24322,"input_clusters":[3],"output_clusters":[3,4,5,18]}}},"class":"zhaquirks.xiaomi.aqara.vibration_aq1"},{"ieee":"84:71:27:ff:fe:0c:7c:f3","nwk":61142,"status":2,"lqi":"102","rssi":"0","last_seen":"1655138642.156229","node_descriptor":"02:40:80:0b:12:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":1026,"profile_id":260,"manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":2},{"id":1,"name":"app_version","value":17},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":16},{"id":4,"name":"manufacturer","value":"HEIMAN"},{"id":5,"name":"model","value":"SmokeSensor-EF-3.0"},{"id":6,"name":"date_code","value":"2019.8.29"},{"id":7,"name":"power_source","value":3}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30},{"id":33,"name":"battery_percentage_remaining","value":200}]},{"id":3,"name":"Identify","attributes":[]},{"id":1280,"name":"IAS Zone","attributes":[{"id":16,"name":"cie_addr","value":[173,103,77,0,0,141,21,0]}]},{"id":1282,"name":"IAS Warning Device","attributes":[]},{"id":2821,"name":"Diagnostic","attributes":[]}]}],"signature":{"manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4619,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":1026,"input_clusters":[0,1,3,1280,1282,2821],"output_clusters":[25]}}},"class":"zigpy.device"},{"ieee":"84:71:27:ff:fe:16:69:24","nwk":36138,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:0b:12:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":1026,"profile_id":260,"manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":2},{"id":1,"name":"app_version","value":17},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":16},{"id":4,"name":"manufacturer","value":"HEIMAN"},{"id":5,"name":"model","value":"SmokeSensor-EF-3.0"},{"id":6,"name":"date_code","value":"2019.8.29"},{"id":7,"name":"power_source","value":3}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30},{"id":33,"name":"battery_percentage_remaining","value":196}]},{"id":3,"name":"Identify","attributes":[]},{"id":1280,"name":"IAS Zone","attributes":[{"id":16,"name":"cie_addr","value":"00:15:8d:00:00:4d:67:ad"}]},{"id":1282,"name":"IAS Warning Device","attributes":[]},{"id":2821,"name":"Diagnostic","attributes":[]}]}],"signature":{"manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4619,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":1026,"input_clusters":[0,1,3,1280,1282,2821],"output_clusters":[25]}}},"class":"zigpy.device"},{"ieee":"84:2e:14:ff:fe:f8:0c:ee","nwk":42296,"status":2,"lqi":"135","rssi":"0","last_seen":"1655133331.430944","node_descriptor":"02:40:80:0b:12:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":1026,"profile_id":260,"manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":2},{"id":1,"name":"app_version","value":17},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":16},{"id":4,"name":"manufacturer","value":"HEIMAN"},{"id":5,"name":"model","value":"SmokeSensor-EF-3.0"},{"id":6,"name":"date_code","value":"2019.8.29"},{"id":7,"name":"power_source","value":3}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30},{"id":33,"name":"battery_percentage_remaining","value":200}]},{"id":3,"name":"Identify","attributes":[]},{"id":1280,"name":"IAS Zone","attributes":[]},{"id":1282,"name":"IAS Warning Device","attributes":[]},{"id":2821,"name":"Diagnostic","attributes":[]}]}],"signature":{"manufacturer":"HEIMAN","model":"SmokeSensor-EF-3.0","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4619,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":1026,"input_clusters":[0,1,3,1280,1282,2821],"output_clusters":[25]}}},"class":"zigpy.device"},{"ieee":"00:15:8d:00:06:b0:ff:ed","nwk":25059,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.1},{"id":33,"name":"battery_percentage_remaining","value":139}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2258}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1015}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":4822}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:06:c5:71:66","nwk":63096,"status":2,"lqi":"168","rssi":"0","last_seen":"1655138174.668084","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":1,"name":"app_version","value":5},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.1},{"id":33,"name":"battery_percentage_remaining","value":132}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":1868}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1009.38}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":6688}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:06:b0:ff:b3","nwk":3451,"status":2,"lqi":"135","rssi":"0","last_seen":"1655138459.57733","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.1},{"id":33,"name":"battery_percentage_remaining","value":132}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2338}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1012}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":5335}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:06:d4:1b:3c","nwk":47059,"status":2,"lqi":"57","rssi":"0","last_seen":"1655138501.771632","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":1,"name":"app_version","value":5},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.1},{"id":33,"name":"battery_percentage_remaining","value":132}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2324}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1008.97}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":5280}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:06:d4:1c:6a","nwk":17564,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.1},{"id":33,"name":"battery_percentage_remaining","value":139}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2171}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1011.82}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":5677}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:06:d3:f0:bc","nwk":20931,"status":2,"lqi":"150","rssi":"0","last_seen":"1655138407.39404","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":770,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":1,"name":"app_version","value":5},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.4},{"id":33,"name":"battery_percentage_remaining","value":154}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2165}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":1010.12}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":5691}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":770,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"8c:f6:81:ff:fe:e9:09:37","nwk":30466,"status":2,"lqi":"96","rssi":"0","last_seen":"1655138668.806764","node_descriptor":"01:40:8e:02:10:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":8,"profile_id":260,"manufacturer":"_TZ3000_5k5vh43t","model":"TS0207","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":3},{"id":1,"name":"app_version","value":64},{"id":2,"name":"stack_version","value":0},{"id":3,"name":"hw_version","value":1},{"id":4,"name":"manufacturer","value":"_TZ3000_5k5vh43t"},{"id":5,"name":"model","value":"TS0207"},{"id":6,"name":"date_code","value":""},{"id":7,"name":"power_source","value":1}]},{"id":10,"name":"Time","attributes":[]},{"id":3,"name":"Identify","attributes":[]}]}],"signature":{"manufacturer":"_TZ3000_5k5vh43t","model":"TS0207","node_desc":{"logical_type":1,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":142,"manufacturer_code":4098,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":8,"input_clusters":[0,10,3],"output_clusters":[25]}}},"class":"zigpy.device"},{"ieee":"00:15:8d:00:00:4d:67:ad","nwk":0,"status":0,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":null,"endpoints":[{"id":242,"status":1,"device_type":41440,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[]}],"signature":{"model":"ZiGate USB-TTL 3.1d","endpoints":{"242":{"profile_id":260,"device_type":41440,"input_clusters":[],"output_clusters":[33]}}},"class":"zigpy_zigate.zigbee.application"}]
Merci !
Edit : le log du déclenchement de l’alerte et celui de l’ajout proviennent de deux appareils distincts pour info.
