Bonsoir ters tous!!
Bon, gros délire dans mon jeedom, j’ai un tas d’erreur dans mes logs cron_execution http.error qui apparement serait toutes lié au PHP enfin j’y connais rien à ce niveau.
Je tourne sur un Odroid N2 avec Buster et jeedom en v4.1.17
Voici les différents logs et les erreurs les plus
cron_execution:
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1085
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1090
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1094
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1097
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1164
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1165
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1217
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1084
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1089
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1093
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1096
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1163
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1166
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1209
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1212
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1216
http.error:
Le log condesé j’y ai mis le principal de erreurs le log complet est en dessous
[Tue Jan 12 18:56:47.026901 2021] [php7:warn] [pid 12340] [client 127.0.0.1:45426] PHP Warning: A non-numeric value encountered in /var/www/html/plugins/phone_detection/core/class/phone_detection.class.php on line 68
[Tue Jan 12 18:43:13.573771 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1084, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.573921 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1089, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.573951 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1093, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.573975 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1096, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.574038 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1163, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.574099 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1165, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.574121 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1166, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.574375 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1209, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.574426 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1212, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:13.574484 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1216, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:16.142658 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1093, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:16.142681 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1096, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 18:43:16.142760 2021] [php7:notice] [pid 12351] [client 192.168.0.1:59645] PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1164, referer: https://www.xxxxxx.ovh/index.php?v=d&p=Monitoring&m=Monitoring&id=1215
[Tue Jan 12 16:00:28.984204 2021] [php7:notice] [pid 6646] [client xx.1xx.1x.1x7x:43952] PHP Notice: Undefined index: field in /var/www/html/plugins/discordlink/core/class/discordlink.class.php on line 690, referer: https://www.xxxxx.ovh/index.php?v=m&p=home
[Tue Jan 12 16:02:54.026918 2021] [php7:warn] [pid 26217] [client xx.1xx.123.1xx:43966] PHP Warning: file_get_contents(/tmp/jeedom/camera/1127.jpeg): failed to open stream: No such file or directory in /var/www/html/plugins/camera/core/class/camera.class.php on line 815, referer: https://www.xxxxx.ovh/index.php?v=m&p=home
[Tue Jan 12 16:02:54.027035 2021] [php7:warn] [pid 26217] [client xx.1xx.123.1xx:43966] PHP Warning: unlink(/tmp/jeedom/camera/1127.jpeg): No such file or directory in /var/www/html/plugins/camera/core/class/camera.class.php on line 816, referer: https://www.xxxx.ovh/index.php?v=m&p=home
[Tue Jan 12 18:06:32.132885 2021] [php7:notice] [pid 23224] [client xx.xx.xxx.xx:53963] PHP Notice: Undefined index: thermostatMode in /var/www/html/plugins/gsh/core/class/gsh_TemperatureSetting.class.php on line 258
[Tue Jan 12 17:48:12.549678 2021] [php7:warn] [pid 23224] [client 127.0.0.1:54788] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Tue Jan 12 17:45:17.345508 2021] [access_compat:error] [pid 8493] [client xx.xxx.xxx.108:36734] AH01797: client denied by server configuration: /var/www/html/vendor/phpunit
[Tue Jan 12 17:45:23.502094 2021] [access_compat:error] [pid 18749] [client xx.xxx.xxx.108:45494] AH01797: client denied by server configuration: /var/www/html/vendor/phpunit
Log Complet
Http-error.txt (91,1 Ko)
J’ai vraiment besoin de vos avis et votre expertise car la c’est totalement hors de mes compétence.
Désolé pour le bordel Lol
