je cherche de l’aide.
Installation neuve et qu oimarche parfaitement sauf que à l’installation du plugin zwave j’ai cette erreur ci :
Lancement de l’installation/mise à jour des dépendances openzwave
Reading package lists...
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
g++ is already the newest version (4:8.3.0-1).
gcc is already the newest version (4:8.3.0-1).
git is already the newest version (1:2.20.1-2+deb10u3).
libjpeg-dev is already the newest version (1:1.5.2-2+deb10u1).
python-louie is already the newest version (1.1-4).
make is already the newest version (4.2.1-1.2).
python-serial is already the newest version (3.4-4).
python-dev is already the newest version (2.7.16-1).
python-setuptools is already the newest version (40.8.0-1).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.21.0-1).
libudev-dev is already the newest version (241-7~deb10u7).
unzip is already the newest version (6.0-23+deb10u2).
python-lxml is already the newest version (4.3.2-1+deb10u3).
python-pip is already the newest version (18.1-5+rpt1).
The following package was automatically installed and is no longer required:
raspi-gpio
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
Installation des dependances Python
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting urwid
Exception:
File "/usr/lib/python2.7/dist-packages/pip/_internal/cli/base_command.py", line 143, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py", line 338, in run
resolver.resolve(requirement_set)
File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 102, in resolve
self._resolve_one(requirement_set, req)
File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 256, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
self.require_hashes
File "/usr/lib/python2.7/dist-packages/pip/_internal/operations/prepare.py", line 218, in prepare_linked_requirement
req.populate_link(finder, upgrade_allowed, require_hashes)
File "/usr/lib/python2.7/dist-packages/pip/_internal/req/req_install.py", line 164, in populate_link
self.link = finder.find_requirement(self, upgrade)
File "/usr/lib/python2.7/dist-packages/pip/_internal/index.py", line 572, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File "/usr/lib/python2.7/dist-packages/pip/_internal/index.py", line 530, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File "/usr/lib/python2.7/dist-packages/pip/_internal/index.py", line 675, in _get_pages
page = self._get_page(location)
File "/usr/lib/python2.7/dist-packages/pip/_internal/index.py", line 793, in _get_page
return _get_html_page(link, session=self.session)
File "/usr/lib/python2.7/dist-packages/pip/_internal/index.py", line 144, in _get_html_page
"Cache-Control": "max-age=0",
File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 396, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 841, in _validate_conn
conn.connect()
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/connection.py", line 344, in connect
ssl_context=context)
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/util/ssl_.py", line 321, in ssl_wrap_socket
context.load_verify_locations(ca_certs, ca_cert_dir)
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 428, in load_verify_locations
self._ctx.load_verify_locations(cafile, capath)
File "/usr/lib/python2.7/dist-packages/OpenSSL/SSL.py", line 776, in load_verify_locations
_raise_current_error()
File "/usr/lib/python2.7/dist-packages/OpenSSL/_util.py", line 54, in exception_from_error_queue
raise exception_type(errors)
Error: [('x509 certificate routines', 'X509_load_cert_crl_file', 'no certificate or crl found')]
could not install - abort
Visiblement il me manquerait un certificat SSL.
j'ai exactement la meme erreur sur l'installation des packages PIP2 (fastener et future) à partir de la configuration système / verification des packages ces deux là sont les seuls non OK.
Si quelqu'un a une astuce j'aimerais finaliser l'intsallation du plugin Zwave afin de finir ma configuration
Merci beaucoup
