tout d’abord je débute sur ce blog donc je vais surement faire des erreurs dans ma façon de communiquer. Je m’en excuse.
Je viens d’installer un RF Player et je n’arrive pas à passer les dépendances et le démon en ok. Le port RFPlayer est en Auto. Voici la config du plugin
Log dépendance sur RPI4
0000|********************************************************
0001|* Installation des dépendances *
0002|********************************************************
0003|Hit:1 Index of /debian buster InRelease
0004|Hit:2 Index of /debian buster InRelease
0005|Hit:3 Index of /debian-security buster/updates InRelease
0006|Hit:4 Index of /debian buster-updates InRelease
0007|Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
0008|Reading package lists…
0009|Reading package lists…
0010|Building dependency tree…
0011|Reading state information…
0012|E: Unable to locate package python3-enum
0013|Reading package lists…
0014|Building dependency tree…
0015|Reading state information…
0016|python3-serial is already the newest version (3.4-4).
0017|python3-pyudev is already the newest version (0.21.0-1).
0018|python3-requests is already the newest version (2.21.0-1).
0019|The following package was automatically installed and is no longer required:
0020|libva-wayland2
0021|Use ‹ sudo apt autoremove › to remove it.
0022|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0023|Looking in indexes: Simple index, piwheels - Simple index
0024|Requirement already satisfied: enum-compat in /usr/local/lib/python3.7/dist-packages (0.0.3)
0025|WARNING: Running pip as the ‹ root › user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: 12. Virtual Environments and Packages — Python 3.11.5 documentation
0026|********************************************************
0027|* Installation terminée *
0028|********************************************************
Et peux tu faire un update et upgrade sur ton RPI4 .
Et fixer le port du Rfplayer
Conjecture à deux balles : est-ce que ça ne pourrait pas venir de la dernière MÀJ du plugin ? En effet l’erreur parle de Python3 et le motif de cette MÀJ était d’apporter la compatibilité avec Debian 11 si j’ai bien lu. De plus, il me semble avoir lu qu’en Python3 la librairie « enum » est intégrée dans une autre.
Bref, si c’était possible d’installer une ancienne version du plugin je t’aurais proposé de le faire, mais là… est-ce qu’en transférant le dossier du plugin RFPlayer d’une ancienne version ça marcherait ?
La config réseau externe a toujours été nok mais cela ne m’empèche pas de me connecter de l’exterieur avec une ipfixe.
Tu proposes de faire un update des packages apt par la commande : sudo apt update et un upgrade par : sudo apt upgrade , c’est bien ça ?
Oui j’ai vu ça dans Jeedom/System/Centre de mise à jour/« OS/Packages » mais il y a un avertissement disant « Êtes-vous sûr de vouloir mettre à jour les packages de type : apt ? Attention cette opération est toujours risquée et peut prendre plusieurs dizaines de minutes. »
As tu déjà fait ça ? Il n’y a pas de risque ?
Pour info ce n’est pas ce qui empêche de fonctionner avec le Rfplayer…
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian-security buster/updates InRelease
Hit:4 http://deb.debian.org/debian buster-updates InRelease
Reading package lists...
Building dependency tree...
Reading state information...
libva-wayland2
Use 'sudo apt autoremove' to remove it.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
