Ce matin, demande de réinstaller les dépendances et j’ai ce message :
== Jeedom 4.3.22 diy in Debian GNU/Linux 10 (buster) on x86_64/amd64/64bits
== Python 3.7.3 (default, Oct 11 2023, 09:51:27) [GCC 8.3.0]
== jMQTT v23.11.3 (2023-12-01 19:57:55) branch:stable previously:v22
== 25/02/2024 11:54:15 == Dependencies installation for jMQTT
[ 0% ] : Synchronize the package index...
[ 9% ] : Synchronize the package index : [ERROR]
[ 10% ] : Purge dynamic contents...
[ 19% ] : Purge dynamic contents : [ OK ]
[ 20% ] : Install Composer...
[ 29% ] : Install Composer : [ OK ]
[ 30% ] : Install JsonPath-PHP library...
[ 39% ] : Install JsonPath-PHP library : [ OK ]
[ 40% ] : Remove Composer...
[ 49% ] : Remove Composer : [ OK ]
[ 50% ] : Install python3 venv and pip debian packages...
[ 59% ] : Install python3 venv and pip debian packages : [ OK ]
[ 60% ] : Create a python3 Virtual Environment...
[ 69% ] : Create a python3 Virtual Environment : [ERROR]
[ 70% ] : Install required python3 libraries in venv...
[ 99% ] : Install required python3 libraries in venv : [ERROR]
[100% ] : Finished !
== KO == Installation Error
== ANALYSING ERRORS...
== NO KNOWN ERROR DETECTED
== Error in step : Synchronize the package index
== Line 13
== Command `sudo apt-get update' have an issue
== Return code is 100
== Error message :
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://ftp.fr.debian.org/debian buster-updates InRelease
Get:3 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_18.x buster InRelease
Get:6 http://security.debian.org/debian-security buster/updates/main Sources [370 kB]
Get:7 http://security.debian.org/debian-security buster/updates/main amd64 Packages [585 kB]
Get:8 http://security.debian.org/debian-security buster/updates/main Translation-en [318 kB]
Ign:7 http://security.debian.org/debian-security buster/updates/main amd64 Packages
Get:7 http://security.debian.org/debian-security buster/updates/main amd64 Packages [762 kB]
Ign:8 http://security.debian.org/debian-security buster/updates/main Translation-en
Err:8 http://security.debian.org/debian-security buster/updates/main Translation-en
Write error - write (28: No space left on device)
Reading package lists...
E: Failed to fetch http://security.debian.org/debian-security/dists/buster/updates/main/i18n/Translation-en Write error - write (28: No space left on device)
E: Some index files failed to download. They have been ignored, or old ones used instead.
== Error in step : Create a python3 Virtual Environment
== Line 36
== Command `sudo -u www-data python3 -m venv /var/www/html/plugins/jMQTT/resources/jmqttd/venv' have an issue
== Return code is 1
== Error message :
The virtual environment was not created successfully because ensurepip is not
available. On Debian/Ubuntu systems, you need to install the python3-venv
package using the following command.
apt-get install python3-venv
You may need to use sudo with that command. After installing the python3-venv
package, recreate your virtual environment.
Failing command: ['/var/www/html/plugins/jMQTT/resources/jmqttd/venv/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
== Error in step : Install required python3 libraries in venv
== Line 39
== Command `sudo -u www-data /var/www/html/plugins/jMQTT/resources/jmqttd/venv/bin/pip3 install --no-cache-dir -r /var/www/html/plugins/jMQTT/resources/python-requirements/requirements.txt' have an issue
== Return code is 1
== Error message :
sudo: /var/www/html/plugins/jMQTT/resources/jmqttd/venv/bin/pip3: command not found
