suite à l’achat d’un nouveau module (HAOZEE - Capteur de sol Zigbee HZ-SL04) je devais mettre à jour Z2M. £J’ai donc relancer les dépendances pour prendre la dernière version (passage de 2.5.0 vers 2.13.0). Et depuis impossible d’aboutir les dépendances ne se lancent pas même en forçant la version 2.5.0 qui fonctionnait.
voici la log de Z2md :
Node.js v22.15.0
3588|> zigbee2mqtt@2.13.0 start
3589|> node index.js
3590|Starting Zigbee2MQTT without watchdog.
3591|Building Zigbee2MQTT... (initial build), failed
3592|node:internal/errors:983
3593|const err = new Error(message);
3594|^
3595|Error: Command failed: pnpm run prepack
3596|[WARN] The "pnpm" field in package.json is no longer read by pnpm. The following keys were ignored: "pnpm.overrides", "pnpm.onlyBuiltDependencies". See https://pnpm.io/settings for the new home of each setting.
3597| ERROR Cannot verify the identity of the @pnpm/exe.linux-arm native binary: it is missing from pnpm-lock.yaml.
3598|For help, run: pnpm help run
3599|at genericNodeError (node:internal/errors:983:15)
3600|at wrappedFn (node:internal/errors:537:14)
3601|at ChildProcess.exithandler (node:child_process:414:12)
3602|at ChildProcess.emit (node:events:518:28)
3603|at maybeClose (node:internal/child_process:1101:16)
3604|at ChildProcess._handle.onexit (node:internal/child_process:304:5) {
3605|code: 1,
3606|killed: false,
3607|signal: null,
3608|cmd: 'pnpm run prepack'
3609|}
3610|Node.js v22.15.0
fin de log de z2m_packages :
run `npm fund` for details
0028|+ pnpm i --frozen-lockfile
0029|[WARN] The "pnpm" field in package.json is no longer read by pnpm. The following keys were ignored: "pnpm.overrides", "pnpm.onlyBuiltDependencies". See https://pnpm.io/settings for the new home of each setting.
0030| ERROR Cannot verify the identity of the @pnpm/exe.linux-arm native binary: it is missing from pnpm-lock.yaml.
0031|For help, run: pnpm help install
0032|+ pnpm run build
0033|[WARN] The "pnpm" field in package.json is no longer read by pnpm. The following keys were ignored: "pnpm.overrides", "pnpm.onlyBuiltDependencies". See https://pnpm.io/settings for the new home of each setting.
0034| ERROR Cannot verify the identity of the @pnpm/exe.linux-arm native binary: it is missing from pnpm-lock.yaml.
0035|For help, run: pnpm help run
0036|+ chown www-data:www-data -R /var/www/html/plugins/z2m/resources/zigbee2mqtt
0037|+ echo 4
0038|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end z2m
0039|rm: invalid option -- '/'
0040|Try 'rm --help' for more information.
0041|+ echo 5
0042|+ rm /tmp/jeedom_install_in_progress_z2m
0043|+ echo '*******************End of package installation******************'
0044|*******************End of package installation******************
et dans la cron_execution je viens de voir tous ces messages de warning : (extrait car il y en a des pages)
0847|Enable scenario : OK
0848|Enable task : OK
0849|Check Network Conf : OK
0850|sudo: iptables: command not found
0851|sudo: iptables: command not found
0852|sudo: iptables: command not found
0853|ls: cannot access '/tmp/jeedom_install_in_progress*': No such file or directory
0854|warning: commands will be executed using /bin/sh
0855|job 175 at Sat Aug 15 03:00:00 2026
0856|rm: invalid option -- '/'
0857|Try 'rm --help' for more information.
0858|ls: cannot access '/tmp/jeedom_install_in_progress*': No such file or directory
Informations Jeedom
Core : 4.6.1 (master)
DNS Jeedom : oui
Plugin : JeeZigbee
Version : 2026-04-13 01:01:55 (stable)
Statut Démon : Stoppé - (2026-08-15 08:50:06)
Si quelqu’un a une idée de ce qui m’arrive et peut m’aider merci.
Là c’est la panne totale.
merci à vous d’avance
Santé
🟢 Matériel : RPI 3 B+
🟢 Système à jour : OK
🟢 Cron actif : OK
🟢 Scénario actif : OK
🟢 Démarré : OK 2026-04-16 15:27:03
🟢 Date système (dernière heure enregistrée) : OK 2026-08-15 08:53:19 (2026-08-15 07:57:02)
🟢 Droits sudo : OK
🟢 Version Jeedom : 4.6.1
🟢 Version OS : debian 11.11
🟢 Version PHP : 7.4.33
🟢 Nombre de processus Apache : 14
🟢 Version OS : Linux domotikmillot 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux [11.11]
🟢 Version database : 10.5.29-MariaDB-0+deb11u1
🟢 Espace disque libre : 87 %
🟢 Connexion active/max/autorisée : 13/18/151
🟢 Taille base de données : 24.09 MB
🟢 Espace disque libre tmp : 98 %
🟢 Mémoire disponible : 55 % (Total 922 Mo)
🟢 Mémoire suffisante : 0
🟢 Erreur I/O : 0
🟢 Swap disponible : 100 % (Total 1024 Mo)
🟢 Swappiness : 10 %
🟢 Charge : 0.35 - 0.56 - 0.48
🟢 Node : v22.15.0
🟢 Python : Python 3.9.2
🟢 Python 3 : Python 3.9.2
🟢 Persistance du cache : OK
🟢 Apache private tmp : OK
