Je ne peux plus utiliser google cast depuis que je suis passé sous stretch car il refuse d’installer les dépendances.
(pip 9.0.1 (/usr/lib/python3/dist-packages), Requirement.parse(‹ pip==1.5.6 ›))
Le plugin réclame PIP en 1.5.6.
Par avance merci e votre aide.
Launch install of googlecast dependancies
-- Updating repo...
Get:1 http://security.debian.org stretch/updates InRelease [94.3 kB]
Ign:2 http://ftp2.fr.debian.org/debian stretch InRelease
Hit:3 http://packages.dotdeb.org wheezy-php55 InRelease
Get:4 http://ftp2.fr.debian.org/debian stretch-updates InRelease [91.0 kB]
Hit:5 http://ftp2.fr.debian.org/debian stretch Release
Get:6 http://security.debian.org stretch/updates/main Sources [190 kB]
Get:7 https://deb.nodesource.com/node_12.x stretch InRelease [4585 B]
Get:8 http://security.debian.org stretch/updates/main amd64 Packages [500 kB]
Get:10 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages [765 B]
Fetched 881 kB in 1s (532 kB/s)
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
python-dev is already the newest version (2.7.13-2).
python3 is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
-- Installed version of Python :
Python 3.5.3
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (9.0.1-2+deb9u1).
python3-dev is already the newest version (3.5.3-1).
python-requests is already the newest version (2.12.4-1).
-- Installation of TTS libraries
sox is already the newest version (14.4.1-5+deb9u2).
libttspico-utils is already the newest version (1.0+git20130326-5).
-- Installation of libav/ffmpeg libraries
libav-tools is already the newest version (7:3.2.14-1~deb9u1).
libavcodec-extra is already the newest version (7:3.2.14-1~deb9u1).
-- Upgrade setuptools with command pip3.4 if not up to date
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 583, in _build_master
ws.require(__requires__)
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 900, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 791, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.VersionConflict: (pip 9.0.1 (/usr/lib/python3/dist-packages), Requirement.parse('pip==1.5.6'))
During handling of the above exception, another exception occurred:
File "/usr/local/bin/pip3.4", line 5, in <module>
from pkg_resources import load_entry_point
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 3250, in <module>
@_call_aside
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 3234, in _call_aside
f(*args, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 3263, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 585, in _build_master
return cls._build_from_requirements(__requires__)
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 598, in _build_from_requirements
dists = ws.resolve(reqs, Environment())
File "/usr/local/lib/python3.5/dist-packages/pkg_resources/__init__.py", line 786, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'pip==1.5.6' distribution was not found and is required by the application
-- Installed version of pip :
@_call_aside
f(*args, **kwargs)
-- Installation of python library 'netifaces' with command pip3.4
@_call_aside
f(*args, **kwargs)
-- Installation of python library 'requests' with command pip3.4
@_call_aside
f(*args, **kwargs)
-- Installation of python library 'protobuf' with command pip3.4
@_call_aside
f(*args, **kwargs)
-- Installation of python library 'zeroconf' with command pip3.4
@_call_aside
f(*args, **kwargs)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3.4
@_call_aside
f(*args, **kwargs)
-- Installation of python library 'tqdm, websocket-client' for plex with command pip3.4
@_call_aside
f(*args, **kwargs)
-- Installation of dependencies is done !
