Suite au changement de mon eMMC, mes dépendances blea ne veulent pas s’installer correctement.
Voici mes log lors de l’installation :
* Installation des dépendances *
Hit:1 http://www.deb-multimedia.org buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:4 http://ftp.uk.debian.org/debian buster InRelease
Hit:5 http://ftp.uk.debian.org/debian buster-updates InRelease
Ign:6 https://oph.mdrjr.net/meveric all InRelease
Ign:7 https://oph.mdrjr.net/meveric buster InRelease
Err:8 https://oph.mdrjr.net/meveric all Release
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 216.155.132.189 443]
Err:9 https://oph.mdrjr.net/meveric buster Release
Err:3 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.178.69.128 443]
Reading package lists...
E: The repository 'https://oph.mdrjr.net/meveric all Release' no longer has a Release file.
E: The repository 'https://oph.mdrjr.net/meveric buster Release' no longer has a Release file.
Building dependency tree...
Reading state information...
libatlas-base-dev is already the newest version (3.10.3-8).
bluetooth is already the newest version (5.50-1.2~deb10u2).
libbluetooth-dev is already the newest version (5.50-1.2~deb10u2).
build-essential is already the newest version (12.6).
libffi-dev is already the newest version (3.2.1-9).
libopenjp2-7 is already the newest version (2.3.0-2+deb10u2).
libssl-dev is already the newest version (1.1.1n-0+deb10u3).
python3-serial is already the newest version (3.4-4).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1).
libtiff5 is already the newest version (4.1.0+git191117-2~deb10u4).
rfkill is already the newest version (2.33.1-0.1).
0 upgraded, 0 newly installed, 0 to remove and 214 not upgraded.
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 0 newly installed, 3 reinstalled, 0 to remove and 214 not upgraded.
Need to get 0 B/1188 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 77841 files and directories currently installed.)
Preparing to unpack .../python3_3.7.3-1_arm64.deb ...
running python pre-rtupdate hooks for python3.7...
Unpacking python3 (3.7.3-1) over (3.7.3-1) ...
Preparing to unpack .../bluez_5.50-1.2~deb10u2_arm64.deb ...
Unpacking bluez (5.50-1.2~deb10u2) over (5.50-1.2~deb10u2) ...
Preparing to unpack .../python3-pip_18.1-5_all.deb ...
Unpacking python3-pip (18.1-5) over (18.1-5) ...
Setting up python3 (3.7.3-1) ...
running python rtupdate hooks for python3.7...
running python post-rtupdate hooks for python3.7...
Setting up bluez (5.50-1.2~deb10u2) ...
Setting up python3-pip (18.1-5) ...
Processing triggers for dbus (1.12.16-1) ...
Processing triggers for systemd (241-7~deb10u4) ...
Requirement already up-to-date: setuptools in /usr/local/lib/python3.7/dist-packages (65.4.0)
git is already the newest version (1:2.20.1-2+deb10u3).
libglib2.0-dev is already the newest version (2.58.3-2+deb10u4).
Requirement already satisfied: pyudev in /usr/lib/python3/dist-packages (0.21.0)
Requirement already satisfied: pyserial in /usr/lib/python3/dist-packages (3.4)
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.28.1)
Requirement already satisfied: charset-normalizer<3,>=2 in /usr/local/lib/python3.7/dist-packages (from requests) (2.1.1)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (1.26.12)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests) (3.4)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests) (2022.9.24)
Collecting pybluez
Using cached https://files.pythonhosted.org/packages/08/9f/e9d93b266d2d1ea988780a52a696073ba0a65df65a532165fdf6ff90d0ed/PyBluez-0.23.tar.gz
Complete output from command python setup.py egg_info:
error in PyBluez setup command: use_2to3 is invalid.
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-v61lu1hn/pybluez/
Collecting pillow
Using cached https://files.pythonhosted.org/packages/8c/92/2975b464d9926dc667020ed1abfa6276e68c3571dcb77e43347e15ee9eed/Pillow-9.2.0.tar.gz
Building wheels for collected packages: pillow
Running setup.py bdist_wheel for pillow: started
Running setup.py bdist_wheel for pillow: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-2uk18ayt/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-pxexal_j --python-tag cp37:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for pillow
Running setup.py clean for pillow
Failed to build pillow
Installing collected packages: pillow
Running setup.py install for pillow: started
Running setup.py install for pillow: still running...
Running setup.py install for pillow: finished with status 'done'
Successfully installed pillow
Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.21.6)
Collecting bluepy
Using cached https://files.pythonhosted.org/packages/27/91/6cfca10bee9862f93015413cf9e6a52c3081a71f1518963396a055128f8e/bluepy-1.3.0.tar.gz
Building wheels for collected packages: bluepy
Running setup.py bdist_wheel for bluepy: started
Running setup.py bdist_wheel for bluepy: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-6tyt42t2/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-38xgok5_ --python-tag cp37:
/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:774: UserWarning: Usage of dash-separated 'description-file' will not be supported in future versions. Please use the underscore name 'description_file' instead
% (opt, underscore_opt)
or: -c cmd --help
Failed building wheel for bluepy
Running setup.py clean for bluepy
Failed to build bluepy
Installing collected packages: bluepy
Running setup.py install for bluepy: started
Running setup.py install for bluepy: finished with status 'done'
Successfully installed bluepy
Cloning into 'bluepy'...
running build
running build_py
creating build
creating build/lib
creating build/lib/bluepy
copying bluepy/blescan.py -> build/lib/bluepy
copying bluepy/sensortag.py -> build/lib/bluepy
copying bluepy/scanner.py -> build/lib/bluepy
copying bluepy/get_services.py -> build/lib/bluepy
copying bluepy/scan_fuzz.py -> build/lib/bluepy
copying bluepy/__init__.py -> build/lib/bluepy
copying bluepy/thingy52.py -> build/lib/bluepy
copying bluepy/btle.py -> build/lib/bluepy
copying bluepy/uuids.json -> build/lib/bluepy
copying bluepy/bluez-src.tgz -> build/lib/bluepy
copying bluepy/bluepy-helper.c -> build/lib/bluepy
copying bluepy/Makefile -> build/lib/bluepy
running install
Working dir is /tmp/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
running build
running build_py
copying bluepy/bluepy-helper -> build/lib/bluepy
running install_lib
copying build/lib/bluepy/blescan.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluez-src.tgz -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/uuids.json -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/sensortag.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scanner.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/get_services.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper.c -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scan_fuzz.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/__init__.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/thingy52.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/btle.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/Makefile -> /usr/lib/python3.7/site-packages/bluepy
byte-compiling /usr/lib/python3.7/site-packages/bluepy/blescan.py to blescan.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/sensortag.py to sensortag.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/scanner.py to scanner.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/get_services.py to get_services.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/scan_fuzz.py to scan_fuzz.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/__init__.py to __init__.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/thingy52.py to thingy52.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/btle.py to btle.cpython-37.pyc
running install_egg_info
running egg_info
creating bluepy.egg-info
writing bluepy.egg-info/PKG-INFO
writing dependency_links to bluepy.egg-info/dependency_links.txt
writing entry points to bluepy.egg-info/entry_points.txt
writing top-level names to bluepy.egg-info/top_level.txt
writing manifest file 'bluepy.egg-info/SOURCES.txt'
reading manifest file 'bluepy.egg-info/SOURCES.txt'
adding license file 'LICENSE.txt'
removing '/usr/lib/python3.7/site-packages/bluepy-1.1.4-py3.7.egg-info' (and everything under it)
Copying bluepy.egg-info to /usr/lib/python3.7/site-packages/bluepy-1.1.4-py3.7.egg-info
running install_scripts
Installing blescan script to /usr/bin
Installing sensortag script to /usr/bin
Installing thingy52 script to /usr/bin
/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
Requirement already satisfied: cryptography==2.6.1 in /usr/local/lib/python3.7/dist-packages (2.6.1)
Collecting cffi!=1.11.3,>=1.8 (from cryptography==2.6.1)
Using cached https://files.pythonhosted.org/packages/2b/a8/050ab4f0c3d4c1b8aaa805f70e26e84d0e27004907c5b8ecc1d31815f92a/cffi-1.15.1.tar.gz
Requirement already satisfied: asn1crypto>=0.21.0 in /usr/local/lib/python3.7/dist-packages (from cryptography==2.6.1) (1.5.1)
Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography==2.6.1) (1.12.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi!=1.11.3,>=1.8->cryptography==2.6.1) (2.21)
Building wheels for collected packages: cffi
Running setup.py bdist_wheel for cffi: started
Running setup.py bdist_wheel for cffi: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ja4j_jvt/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-04ltoxgb --python-tag cp37:
/usr/local/lib/python3.7/dist-packages/setuptools/config/setupcfg.py:508: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
warnings.warn(msg, warning_class)
or: -c cmd --help
Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cffi
Installing collected packages: cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'done'
Successfully installed cffi
Collecting pycrypto
Using cached https://files.pythonhosted.org/packages/60/db/645aa9af249f059cc3a368b118de33889219e0362141e75d4eaf6f80f163/pycrypto-2.6.1.tar.gz
Building wheels for collected packages: pycrypto
Running setup.py bdist_wheel for pycrypto: started
Running setup.py bdist_wheel for pycrypto: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ru2kpxk_/pycrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-35u3e3s5 --python-tag cp37:
or: -c cmd --help
Failed building wheel for pycrypto
Running setup.py clean for pycrypto
Failed to build pycrypto
Installing collected packages: pycrypto
Running setup.py install for pycrypto: started
Running setup.py install for pycrypto: finished with status 'done'
Successfully installed pycrypto
* Installation terminée *
Après un tour sur différent sujet ici, j’ai passer la commande
sudo pip3 install setuptools==58
et voici les log en suivant
502 Bad Gateway [IP: 51.210.253.116 443]
Collecting pybluez
File "<string>", line 1, in <module>
File "/tmp/pip-install-tijidnmz/pybluez/setup.py", line 6, in <module>
from setuptools import setup, Extension
ImportError: cannot import name 'setup' from 'setuptools' (/usr/local/lib/python3.7/dist-packages/setuptools/__init__.py)
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-tijidnmz/pybluez/
Collecting pillow
File "/tmp/pip-install-t1k6nn5l/pillow/setup.py", line 18, in <module>
from setuptools import Extension, setup
ImportError: cannot import name 'Extension' from 'setuptools' (/usr/local/lib/python3.7/dist-packages/setuptools/__init__.py)
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-t1k6nn5l/pillow/
Collecting bluepy
File "/tmp/pip-install-w_r1h8wr/bluepy/setup.py", line 3, in <module>
from setuptools.command.build_py import build_py
ImportError: cannot import name 'build_py' from 'setuptools.command.build_py' (/usr/local/lib/python3.7/dist-packages/setuptools/command/build_py.py)
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-w_r1h8wr/bluepy/
File "setup.py", line 3, in <module>
from setuptools.command.install import install
ImportError: cannot import name 'install' from 'setuptools.command.install' (/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py)
File "/tmp/pip-install-m9riym8x/cffi/setup.py", line 165, in <module>
from setuptools import setup, Distribution, Extension
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-m9riym8x/cffi/
Collecting pycrypto
or: -c cmd --help
error: invalid command 'egg_info'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-nez32fyz/pycrypto/
Bref, je n’arrive pas à me débrouiller de ce problème et surtout, je ne sais plus quoi faire.
Jeedom en 4.2.21.
Si vous avez une idée, merci pour votre aide
