Je ne comprends pas ce que vous faites mais vous n’avez pas suivi les étapes décrites dans le post donné par @Tonio16 donc ca ne risque pas de tomber en marche
je lance les 3 commande comme indiqué dans la procedure sauf la la dernire comme in demande de repondre
Do you want to continue? [Y/n] Abort.
j’ai inclus dans la commande le y
sudo apt upgrade -y
mais c’est certainement une erreur
si je met simplement sudo apt upgrade a la dernire commande, voivi le resultat:
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
The following packages were automatically installed and are no longer required:
libicu64 php7.3 php7.3-curl php7.3-dev php7.3-imap php7.3-ldap
php7.3-mbstring php7.3-mysql php7.3-soap php7.3-xml php7.3-xmlrpc php7.3-zip
php7.4-common php7.4-gd
Use 'sudo apt autoremove' to remove them.
libapache2-mod-php8.0 libicu65 libonig5 linux-image-4.19.0-23-amd64 php8.0
php8.0-cli php8.0-common php8.0-curl php8.0-dev php8.0-gd php8.0-imap
php8.0-ldap php8.0-mbstring php8.0-mysql php8.0-opcache php8.0-readline
php8.0-soap php8.0-ssh2 php8.0-xml php8.0-xmlrpc php8.0-zip xdg-dbus-proxy
The following packages have been kept back:
libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev
The following packages will be upgraded:
apache2 apache2-bin apache2-data apache2-utils aspell avahi-daemon
base-files bind9-host blueman bluez-obexd bzip2 bzip2-doc dbus
dbus-user-session dbus-x11 debconf debconf-i18n dirmngr distro-info-data
dnsmasq dnsmasq-base dpkg dpkg-dev e2fsprogs enchant espeak-data
espeak-ng-data exim4-base exim4-config exim4-daemon-light file file-roller
firefox-esr firefox-esr-l10n-fr fonts-opensymbol fuse geoclue-2.0
gir1.2-gst-plugins-base-1.0 gir1.2-javascriptcoregtk-4.0
gir1.2-lokdocview-0.1 gir1.2-pango-1.0 gir1.2-webkit2-4.0 git-man
glib-networking glib-networking-common glib-networking-services gnupg
gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf
gpgsm gpgv groff-base gstreamer1.0-gl gstreamer1.0-gtk3 gstreamer1.0-libav
gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good
gstreamer1.0-plugins-ugly gstreamer1.0-pulseaudio gstreamer1.0-x gzip
hostapd iproute2 iputils-ping isc-dhcp-client isc-dhcp-common klibc-utils
krb5-locales libapache2-mod-php libapache2-mod-php7.0 libapache2-mod-php7.3
libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap libapt-inst2.0
libapt-pkg5.0 libarchive13 libaspell15 libavahi-client3 libavahi-common-data
libavahi-common3 libavahi-core7 libavahi-glib1 libavahi-gobject0
libavahi-ui-gtk3-0 libbind9-161 libbluray2 libboost-atomic1.67.0
libboost-chrono1.67.0 libboost-date-time1.67.0 libboost-filesystem1.67.0
libboost-iostreams1.67.0 libboost-locale1.67.0 libboost-system1.67.0
libboost-thread1.67.0 libbrlapi0.6 libbrotli1 libbsd0 libburn4 libbz2-1.0
libbz2-dev libc-bin libc-dev-bin libc-l10n libc6 libc6-dbg libc6-dev
libcairo-gobject2 libcairo2 libcom-err2 libcups2 libcurl3-gnutls libdbi-perl
libdbus-1-3 libde265-0 libdns-export1104 libdns1104 libdpkg-perl libefiboot1
libefivar1 libegl-mesa0 libenchant1c2a libespeak-ng1 libespeak1 libexif12
libexiv2-14 libext2fs2 libfaad2 libflac8 libfluidsynth1 libfreerdp2-2
libfreetype6 libfribidi0 libfuse2 libgbm1 libgcrypt20 libgif7 libgit2-27
libgl1-mesa-dri libglapi-mesa libglib2.0-data libglx-mesa0 libgmp10
libgnutls-dane0 libgnutls30 libgrilo-0.3-0 libgssapi-krb5-2 libgssdp-1.0-3
libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0
libgstreamer-plugins-base1.0-0 libgupnp-1.0-4 libhogweed4
libhttp-daemon-perl libhttp-parser2.8 libicu63 libidn2-0 libimobiledevice6
libinput-bin libinput10 libisc-export1100 libisc1100 libisccc161
libisccfg163 libjavascriptcoregtk-4.0-18 libjpeg62-turbo libjs-jquery
libjs-underscore libjson-c3 libk5crypto3 libklibc libkrb5-3 libkrb5support0
libksba8 libldap-2.4-2 libldap-common libldb1 liblibreofficekitgtk
liblirc-client0 libllvm7 liblwres161 liblz4-1 liblzma5 libmagic-mgc
libmagic1 libmariadb3 libmbedcrypto3 libmbedtls12 libmbedx509-0 libmysofa0
libncurses6 libncursesw6 libnet-ssleay-perl libnettle6 libnm0 libnss-systemd
libnss3 libntfs-3g883 libopenexr23 libopenmpt0 libp11-kit0 libpam-systemd
libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0
libpcap0.8 libpcaudio0 libpcre16-3 libpcre3 libpcre3-dev libpcre32-3
libpcrecpp0v5 libperl4-corelibs-perl libperl5.28 libpixman-1-0
libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0
libpoppler-glib8 libpoppler82 libportaudio2 libproxy1-plugin-gsettings
libproxy1-plugin-networkmanager libproxy1-plugin-webkit libproxy1v5
libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib
libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5
libqt5widgets5 libraptor2-0 libraw19 libreoffice-avmedia-backend-gstreamer
libreoffice-base-core libreoffice-calc libreoffice-common libreoffice-core
libreoffice-draw libreoffice-gnome libreoffice-gtk3 libreoffice-help-common
libreoffice-help-fr libreoffice-impress libreoffice-l10n-fr libreoffice-math
libreoffice-style-colibre libreoffice-style-elementary
libreoffice-style-tango libreoffice-writer libreofficekit-data librsvg2-2
librsvg2-common libsasl2-2 libsasl2-modules libsasl2-modules-db
libsdl1.2debian libsdl2-2.0-0 libsndfile1 libsodium23 libsox-fmt-alsa
libsox-fmt-base libsox-fmt-mp3 libsox3 libspeechd2 libsqlite3-0 libss2
libssh-gcrypt-4 libssl-dev libssl1.1 libsystemd0 libtag1v5 libtag1v5-vanilla
libtagc0 libtasn1-6 libtiff5 libtimedate-perl libtinfo6 libudev1 libunbound8
libunwind8 libvpx5 libwavpack1 libwebkit2gtk-4.0-37 libwebp6 libwebpdemux2
libwinpr2-2 libx11-6 libx11-data libx11-xcb1 libxatracker2 libxml2
libxslt1.1 libzip4 libzmq5 libzstd1 linux-image-4.19.0-6-amd64
linux-image-amd64 linux-libc-dev locales mariadb-client mariadb-client-10.3
mariadb-client-core-10.3 mariadb-common mariadb-server mariadb-server-10.3
mariadb-server-core-10.3 mesa-va-drivers mesa-vdpau-drivers mokutil mplayer
ncurses-base ncurses-bin ncurses-term network-manager ntfs-3g opensc
opensc-pkcs11 openssh-client openssh-server openssh-sftp-server openssl
openvpn orca perl perl-base perl-modules-5.28 php php-common php-curl
php-dev php-gd php-imap php-json php-ldap php-mbstring php-mysql php-pear
php-soap php-ssh2 php-xml php-xmlrpc php-zip php7.0 php7.0-cli php7.0-common
php7.0-curl php7.0-dev php7.0-gd php7.0-imap php7.0-json php7.0-ldap
php7.0-mbstring php7.0-mcrypt php7.0-mysql php7.0-opcache php7.0-readline
php7.0-soap php7.0-xml php7.0-xmlrpc php7.0-zip php7.3 php7.3-cli
php7.3-common php7.3-curl php7.3-dev php7.3-gd php7.3-imap php7.3-json
php7.3-ldap php7.3-mbstring php7.3-mysql php7.3-opcache php7.3-readline
php7.3-soap php7.3-xml php7.3-xmlrpc php7.3-zip php7.4-common php7.4-gd
policykit-1 ppp proftpd-basic proftpd-doc psmisc publicsuffix
python-apt-common python-cryptography python-ldb python-pil python2.7
python2.7-dev python2.7-minimal python3-apt python3-brlapi
python3-cryptography python3-debconf python3-mako python3-speechd
python3-uno python3.7 python3.7-dev python3.7-minimal python3.7-venv
qt5-gtk-platformtheme rsyslog shim-helpers-amd64-signed shim-signed
shim-signed-common shim-unsigned sox speech-dispatcher
speech-dispatcher-audio-plugins speech-dispatcher-espeak-ng systemd
systemd-sysv tor tor-geoipdb transmission-common transmission-gtk tzdata
udev uno-libs3 ure wpasupplicant xbrlapi xdg-utils xserver-common
xserver-xorg-core xserver-xorg-legacy xvfb xxd xz-utils zlib1g zlib1g-dev
450 upgraded, 22 newly installed, 0 to remove and 4 not upgraded.
Need to get 314 MB/635 MB of archives.
After this operation, 409 MB of additional disk space will be used.
Vous avez cliquez sur « Y » ? si pas il faut le faire
comme j’ai lancé les commandes sous jeedom dans Administration systeme,
j’ai tape
-y
dans la barre de commande
ok,
et donc vous aviez tapez chaque commande une à une?
oui c’est ça
pour la commande sudo apt-get --allow-releaseinfo-change update, je me demande s’il ne faut pas aussi confirmer ou ajouter -y
que dis le log d’install à présent?
les 4 logs sont au vert et voici le retour du blea update
saisissez ou collez du code ici
* Installation des dépendances *
Réception de :1 http://security.debian.org/debian-security buster/updates InRelease [34,8 kB]
Réception de :2 http://deb.debian.org/debian buster InRelease [122 kB]
Réception de :3 http://deb.debian.org/debian buster-updates InRelease [56,6 kB]
Réception de :4 https://packages.sury.org/php buster InRelease [7 559 B]
Atteint :5 https://deb.nodesource.com/node_18.x nodistro InRelease
Atteint :6 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
Err :4 https://packages.sury.org/php buster InRelease
Les signatures suivantes ne sont pas valables : EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
Lecture des listes de paquets…
E: Le dépôt « http://security.debian.org/debian-security buster/updates InRelease » a modifié sa valeur « Suite » de « oldstable » à « oldoldstable »
E: Le dépôt « http://deb.debian.org/debian buster InRelease » a modifié sa valeur « Suite » de « oldstable » à « oldoldstable »
E: Le dépôt « http://deb.debian.org/debian buster-updates InRelease » a modifié sa valeur « Suite » de « oldstable-updates » à « oldoldstable-updates »
W: Une erreur s'est produite lors du contrôle de la signature. Le dépôt n'est pas mis à jour et les fichiers d'index précédents seront utilisés. Erreur de GPG : https://packages.sury.org/php buster InRelease : Les signatures suivantes ne sont pas valables : EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
Construction de l'arbre des dépendances…
Lecture des informations d'état…
libatlas-base-dev est déjà la version la plus récente (3.10.3-8).
build-essential est déjà la version la plus récente (12.6).
libffi-dev est déjà la version la plus récente (3.2.1-9).
libopenjp2-7 est déjà la version la plus récente (2.3.0-2+deb10u2).
python3-setuptools est déjà la version la plus récente (40.8.0-1).
python3-dev est déjà la version la plus récente (3.7.3-1).
python3-pyudev est déjà la version la plus récente (0.21.0-1).
python3-requests est déjà la version la plus récente (2.21.0-1).
rfkill est déjà la version la plus récente (2.33.1-0.1).
bluetooth est déjà la version la plus récente (5.50-1.2~deb10u3).
libbluetooth-dev est déjà la version la plus récente (5.50-1.2~deb10u3).
Les paquets supplémentaires suivants seront installés :
libssl1.1
Paquets suggérés :
libssl-doc python3-wxgtk3.0 | python3-wxgtk
Les NOUVEAUX paquets suivants seront installés :
python3-serial
Les paquets suivants seront mis à jour :
libssl-dev libssl1.1 libtiff5
3 mis à jour, 1 nouvellement installés, 0 à enlever et 451 non mis à jour.
Il est nécessaire de prendre 3 634 ko/3 701 ko dans les archives.
Après cette opération, 390 ko d'espace disque supplémentaires seront utilisés.
Err :1 http://security.debian.org/debian-security buster/updates/main amd64 libssl-dev amd64 1.1.1n-0+deb10u4
404 Not Found [IP : 199.232.170.132 80]
Err :2 http://security.debian.org/debian-security buster/updates/main amd64 libssl1.1 amd64 1.1.1n-0+deb10u4
Err :3 http://security.debian.org/debian-security buster/updates/main amd64 libtiff5 amd64 4.1.0+git191117-2~deb10u7
E: Impossible de récupérer http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl-dev_1.1.1n-0+deb10u4_amd64.deb 404 Not Found [IP : 199.232.170.132 80]
E: Impossible de récupérer http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1n-0+deb10u4_amd64.deb 404 Not Found [IP : 199.232.170.132 80]
E: Impossible de récupérer http://security.debian.org/debian-security/pool/updates/main/t/tiff/libtiff5_4.1.0+git191117-2~deb10u7_amd64.deb 404 Not Found [IP : 199.232.170.132 80]
E: Impossible de récupérer certaines archives, peut-être devrez-vous lancer apt-get update ou essayer avec --fix-missing ?
0 mis à jour, 0 nouvellement installés, 3 réinstallés, 0 à enlever et 454 non mis à jour.
Il est nécessaire de prendre 1 033 ko/1 265 ko dans les archives.
Après cette opération, 0 o d'espace disque supplémentaires seront utilisés.
Err :1 http://security.debian.org/debian-security buster/updates/main amd64 bluez amd64 5.50-1.2~deb10u3
E: Impossible de récupérer http://security.debian.org/debian-security/pool/updates/main/b/bluez/bluez_5.50-1.2~deb10u3_amd64.deb 404 Not Found [IP : 199.232.170.132 80]
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (68.0.0)
DEPRECATION: reportbug 7.5.3-deb10u1 has a non-standard version number. pip 24.1 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of reportbug or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
git est déjà la version la plus récente (1:2.20.1-2+deb10u8).
libglib2.0-dev est déjà la version la plus récente (2.58.3-2+deb10u4).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 454 non mis à jour.
Requirement already satisfied: pyudev in /usr/local/lib/python3.7/dist-packages (0.24.1)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.7/dist-packages (from requests) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests) (3.7)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (1.26.18)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests) (2024.2.2)
Collecting pybluez
Using cached PyBluez-0.23.tar.gz (97 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'error'
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [1 lines of output]
error in PyBluez setup command: use_2to3 is invalid.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Requirement already satisfied: pillow in /usr/local/lib/python3.7/dist-packages (9.5.0)
Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.21.6)
Requirement already satisfied: bluepy in /usr/local/lib/python3.7/dist-packages (1.3.0)
Clonage dans 'bluepy'...
running build
running build_py
creating build
creating build/lib
creating build/lib/bluepy
copying bluepy/scan_fuzz.py -> build/lib/bluepy
copying bluepy/thingy52.py -> build/lib/bluepy
copying bluepy/scanner.py -> build/lib/bluepy
copying bluepy/__init__.py -> build/lib/bluepy
copying bluepy/btle.py -> build/lib/bluepy
copying bluepy/blescan.py -> build/lib/bluepy
copying bluepy/get_services.py -> build/lib/bluepy
copying bluepy/sensortag.py -> build/lib/bluepy
copying bluepy/uuids.json -> build/lib/bluepy
copying bluepy/bluez-src.tgz -> build/lib/bluepy
copying bluepy/bluepy-helper.c -> build/lib/bluepy
copying bluepy/Makefile -> build/lib/bluepy
/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:745: SetuptoolsDeprecationWarning: Invalid dash-separated options
Usage of dash-separated 'description-file' will not be supported in future
versions. Please use the underscore name 'description_file' instead.
This deprecation is overdue, please update your project and remove deprecated
calls to avoid build errors in the future.
See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
opt = self.warn_dash_deprecation(opt, section)
running install
Working dir is /tmp/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
running build
running build_py
copying bluepy/bluepy-helper -> build/lib/bluepy
running install_lib
copying build/lib/bluepy/bluepy-helper -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/uuids.json -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scan_fuzz.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/thingy52.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scanner.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/__init__.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/btle.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/Makefile -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/blescan.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluez-src.tgz -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/get_services.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/sensortag.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper.c -> /usr/lib/python3.7/site-packages/bluepy
byte-compiling /usr/lib/python3.7/site-packages/bluepy/scan_fuzz.py to scan_fuzz.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/thingy52.py to thingy52.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/scanner.py to scanner.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/__init__.py to __init__.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/btle.py to btle.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/blescan.py to blescan.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/get_services.py to get_services.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/sensortag.py to sensortag.cpython-37.pyc
running install_egg_info
running egg_info
creating bluepy.egg-info
writing bluepy.egg-info/PKG-INFO
writing dependency_links to bluepy.egg-info/dependency_links.txt
writing entry points to bluepy.egg-info/entry_points.txt
writing top-level names to bluepy.egg-info/top_level.txt
writing manifest file 'bluepy.egg-info/SOURCES.txt'
reading manifest file 'bluepy.egg-info/SOURCES.txt'
adding license file 'LICENSE.txt'
removing '/usr/lib/python3.7/site-packages/bluepy-1.1.4-py3.7.egg-info' (and everything under it)
Copying bluepy.egg-info to /usr/lib/python3.7/site-packages/bluepy-1.1.4-py3.7.egg-info
running install_scripts
Installing blescan script to /usr/bin
Installing sensortag script to /usr/bin
Installing thingy52 script to /usr/bin
/usr/local/lib/python3.7/dist-packages/setuptools/_distutils/cmd.py:66: SetuptoolsDeprecationWarning: setup.py install is deprecated.
Please avoid running ``setup.py`` directly.
Instead, use pypa/build, pypa/installer or other
standards-based tools.
See https://blog.ganssle.io/articles/2021/10/setup-py-deprecated.html for details.
self.initialize_options()
Requirement already satisfied: cryptography in /usr/local/lib/python3.7/dist-packages (42.0.5)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.7/dist-packages (from cryptography) (1.15.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography) (2.21)
Requirement already satisfied: pycrypto in /usr/lib/python3/dist-packages (2.6.1)
* Installation terminée *
par contre losque le lance
sudo apt update
j’ai des erreurs:
Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Get:2 http://deb.debian.org/debian buster InRelease [122 kB]
Get:3 http://deb.debian.org/debian buster-updates InRelease [56.6 kB]
Get:4 https://packages.sury.org/php buster InRelease [7559 B]
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
Err:4 https://packages.sury.org/php buster InRelease
The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://deb.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://deb.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.sury.org/php buster InRelease: The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
Apparemment il faut taper en ssh :
apt install debsuryorg-archive-keyring
il repond:
`WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?``
Avec sudo évidemment.
Sinon sur le forum : Installation dépendance impossible: buster InRelease » a modifié sa valeur « Suite » de « oldstable - #7 par akenad
effectivement mais même avec sudo cela ne fonctionne pas
voici le retour:
E: Unable to locate package debsuryorg-archive-keyring
Alors le lien que j’ai donné ou le support jeedup (c’est une de leur sources)
Ok je vais regarder
Merci pour ces échanges
Même plugin : blea , même symptôme : dépendance NOK , depuis le passage en 4.4.3 de ma smart .
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://www.deb-multimedia.org buster InRelease
Get:3 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:5 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
Hit:6 https://oph.mdrjr.net/meveric all InRelease
Hit:7 https://oph.mdrjr.net/meveric buster InRelease
Fetched 178 kB in 3s (60.0 kB/s)
libatlas-base-dev is already the newest version (3.10.3-8).
build-essential is already the newest version (12.6).
libffi-dev is already the newest version (3.2.1-9).
libopenjp2-7 is already the newest version (2.3.0-2+deb10u2).
python3-serial is already the newest version (3.4-4).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
bluetooth is already the newest version (5.50-1.2~deb10u4).
libbluetooth-dev is already the newest version (5.50-1.2~deb10u4).
libssl-dev is already the newest version (1.1.1n-0+deb10u6).
python3-requests is already the newest version (2.21.0-1+deb10u1).
libtiff5 is already the newest version (4.1.0+git191117-2~deb10u9).
rfkill is already the newest version (2.33.1-0.1+deb10u1).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up rtl8821cu-dkms (5.12.0.4) ...
Removing old rtl8821cu-5.12.0.4 DKMS files...
Deleting module version: 5.12.0.4
completely from the DKMS tree.
Done.
Loading new rtl8821cu-5.12.0.4 DKMS files...
It is likely that 3.14.79-94 belongs to a chroot's host
Building for 3.14.79+, 3.14.79-94 and 3.16.85+
Building for architecture aarch64
Building initial module for 3.14.79+
Error! Bad return status for module build on kernel: 3.14.79+ (aarch64)
Consult /var/lib/dkms/rtl8821cu/5.12.0.4/build/make.log for more information.
dpkg: error processing package rtl8821cu-dkms (--configure):
installed rtl8821cu-dkms package post-installation script subprocess returned error exit status 10
Errors were encountered while processing:
rtl8821cu-dkms
E: Sub-process /usr/bin/dpkg returned an error code (1)
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 0 newly installed, 3 reinstalled, 0 to remove and 3 not upgraded.
Need to get 0 B/1192 kB of archives.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 83213 files and directories currently installed.)
Preparing to unpack .../python3_3.7.3-1_arm64.deb ...
running python pre-rtupdate hooks for python3.7...
Unpacking python3 (3.7.3-1) over (3.7.3-1) ...
Preparing to unpack .../bluez_5.50-1.2~deb10u4_arm64.deb ...
Unpacking bluez (5.50-1.2~deb10u4) over (5.50-1.2~deb10u4) ...
Preparing to unpack .../python3-pip_18.1-5_all.deb ...
Unpacking python3-pip (18.1-5) over (18.1-5) ...
Setting up python3 (3.7.3-1) ...
running python rtupdate hooks for python3.7...
running python post-rtupdate hooks for python3.7...
Setting up bluez (5.50-1.2~deb10u4) ...
Done.
Setting up python3-pip (18.1-5) ...
Processing triggers for dbus (1.12.28-0+deb10u1) ...
Processing triggers for systemd (241-7~deb10u10) ...
rtl8821cu-dkms
Requirement already up-to-date: setuptools in /usr/local/lib/python3.7/dist-packages (68.0.0)
git is already the newest version (1:2.20.1-2+deb10u8).
libglib2.0-dev is already the newest version (2.58.3-2+deb10u5).
Done.
rtl8821cu-dkms
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.7)
Collecting pybluez
Using cached https://files.pythonhosted.org/packages/08/9f/e9d93b266d2d1ea988780a52a696073ba0a65df65a532165fdf6ff90d0ed/PyBluez-0.23.tar.gz
Complete output from command python setup.py egg_info:
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-0v2ank4f/pybluez/
Collecting pillow
Using cached https://files.pythonhosted.org/packages/00/d5/4903f310765e0ff2b8e91ffe55031ac6af77d982f0156061e20a4d1a8b2d/Pillow-9.5.0.tar.gz
Building wheels for collected packages: pillow
Running setup.py bdist_wheel for pillow: started
Running setup.py bdist_wheel for pillow: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-2jnsxqom/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-1kaka3eh --python-tag cp37:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for pillow
Running setup.py clean for pillow
Failed to build pillow
Installing collected packages: pillow
Running setup.py install for pillow: started
Running setup.py install for pillow: still running...
Running setup.py install for pillow: finished with status 'done'
Successfully installed pillow
Collecting bluepy
Using cached https://files.pythonhosted.org/packages/27/91/6cfca10bee9862f93015413cf9e6a52c3081a71f1518963396a055128f8e/bluepy-1.3.0.tar.gz
Building wheels for collected packages: bluepy
Running setup.py bdist_wheel for bluepy: started
Running setup.py bdist_wheel for bluepy: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-t614dkh2/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-jts3p9zo --python-tag cp37:
or: -c cmd --help
Failed building wheel for bluepy
Running setup.py clean for bluepy
Failed to build bluepy
Installing collected packages: bluepy
Running setup.py install for bluepy: started
Running setup.py install for bluepy: finished with status 'done'
Successfully installed bluepy
Cloning into 'bluepy'...
running build
running build_py
creating build
creating build/lib
running install
running build
running build_py
running install_lib
running egg_info
Collecting cryptography
Using cached https://files.pythonhosted.org/packages/13/9e/a55763a32d340d7b06d045753c186b690e7d88780cafce5f88cb931536be/cryptography-42.0.5.tar.gz
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
File "<string>", line 1, in <module>
File "/usr/lib/python3.7/tokenize.py", line 447, in open
buffer = _builtin_open(filename, 'rb')
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/pip-install-vzt88n4e/cryptography/setup.py'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-vzt88n4e/cryptography/
Collecting pycrypto
Using cached https://files.pythonhosted.org/packages/60/db/645aa9af249f059cc3a368b118de33889219e0362141e75d4eaf6f80f163/pycrypto-2.6.1.tar.gz
Building wheels for collected packages: pycrypto
Running setup.py bdist_wheel for pycrypto: started
Running setup.py bdist_wheel for pycrypto: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-wbig_868/pycrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-6aauyxdy --python-tag cp37:
or: -c cmd --help
Failed building wheel for pycrypto
Running setup.py clean for pycrypto
Failed to build pycrypto
Installing collected packages: pycrypto
Running setup.py install for pycrypto: started
Running setup.py install for pycrypto: finished with status 'done'
Successfully installed pycrypto
Si quelqu’un a une idée ? Merci d’avance.
Bonjour Patrick49
au moins je ne suis pas le seul,
Pour l’instant je n’ai pas trouvé la solution,
Je constate un ralentissement de la page web a certains moments, as tu ce phénomène?
As tu d’autre plugins qui dysfonctionnent comme emporia?
Vous n’avez pas du tout le même problème, pas les mêmes symptômes.
Et comme vous n’avez pas la même box, et que vous avez une box officielle, la smart, faites un ticket au support.
