Bonjour à tous
je n’arrive pas a installer les dépendances voici le message d’erreur
pi : j’avais le même souci sur webos tv et la commande:
sudo python2 -m pip install --upgrade --force pip avait réglé mon souci
Cordialement CARI
* Installation des dépendances *
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
Collecting git+https://github.com/Lawouach/WebSocket-for-Python.git
Cloning https://github.com/Lawouach/WebSocket-for-Python.git to /tmp/pip-req-build-hlEK4v
Running command git clone -q https://github.com/Lawouach/WebSocket-for-Python.git /tmp/pip-req-build-hlEK4v
Building wheels for collected packages: ws4py
Building wheel for ws4py (setup.py): started
Building wheel for ws4py (setup.py): finished with status 'done'
Created wheel for ws4py: filename=ws4py-0.5.1-py2-none-any.whl size=41374 sha256=XXXXXXXXXX
Stored in directory: /tmp/pip-ephem-wheel-cache-suHh2O/wheels/99/1f/0d/dXXXXXXXXXXX
Successfully built ws4py
Installing collected packages: ws4py
Attempting uninstall: ws4py
Found existing installation: ws4py 0.5.1
Uninstalling ws4py-0.5.1:
Successfully uninstalled ws4py-0.5.1
ERROR: pip's legacy dependency resolver does not consider dependency conflicts when selecting packages. This behaviour is the source of the following dependency conflicts.
lgtv 0.1.2 requires wakeonlan==0.2.2, but you'll have wakeonlan 1.1.6 which is incompatible.
Successfully installed ws4py-0.5.1
WARNING: You are using pip version 20.3.4; however, version 23.1.2 is available.
You should consider upgrading via the '/usr/bin/python2 -m pip install --upgrade pip' command.
Requirement already up-to-date: wakeonlan in /usr/local/lib/python2.7/dist-packages (1.1.6)
* Installation terminée *
