Dépendance BLEA NOK
bonjour,
J’ai pourtant lu et relu les logs d’installation des dépendances, cherché sur le forum mais je ne trouve pas la solution et les dépendances BLEA restent NOK
D’avance merci pour votre support
Ci-dessous les logs :
0000|********************************************************
0001|*			 Installation des dépendances			 *
0002|********************************************************
0003|Hit:1 http://phoscon.de/apt/deconz buster-beta InRelease
0004|Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
0005|Get:3 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
0006|Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
0007|Reading package lists...
0008|E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldoldstable'
0009|E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldoldstable'
0010|Reading package lists...
0011|Building dependency tree...
0012|Reading state information...
0013|build-essential is already the newest version (12.6).
0014|libffi-dev is already the newest version (3.2.1-9).
0015|python3-dev is already the newest version (3.7.3-1).
0016|python3-pyudev is already the newest version (0.21.0-1).
0017|python3-requests is already the newest version (2.21.0-1).
0018|python3-setuptools is already the newest version (40.8.0-1).
0019|rfkill is already the newest version (2.33.1-0.1).
0020|rfkill set to manually installed.
0021|The following additional packages will be installed:
0022|libatlas3-base libbluetooth3 libssl1.1
0023|Suggested packages:
0024|bluez-cups bluez-obexd libatlas-doc liblapack-doc libssl-doc
0025|python3-wxgtk3.0 | python3-wxgtk
0026|The following NEW packages will be installed:
0027|bluetooth libatlas-base-dev libatlas3-base libbluetooth-dev libbluetooth3
0028|python3-serial
0029|The following packages will be upgraded:
0030|libopenjp2-7 libssl-dev libssl1.1 libtiff5
0031|4 upgraded, 6 newly installed, 0 to remove and 283 not upgraded.
0032|Need to get 250 kB/9,009 kB of archives.
0033|After this operation, 33.4 MB of additional disk space will be used.
0034|Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf libtiff5 armhf 4.1.0+git191117-2~deb10u2
0035|404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
0036|E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/t/tiff/libtiff5_4.1.0+git191117-2~deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
0037|E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
0038|Reading package lists...
0039|Building dependency tree...
0040|Reading state information...
0041|debconf: unable to initialize frontend: Dialog
0042|debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
0043|debconf: falling back to frontend: Readline
0044|debconf: unable to initialize frontend: Readline
0045|debconf: (This frontend requires a controlling tty.)
0046|debconf: falling back to frontend: Teletype
0047|dpkg-preconfigure: unable to re-open stdin:
0048|0 upgraded, 0 newly installed, 3 reinstalled, 0 to remove and 287 not upgraded.
0049|Need to get 0 B/1,003 kB of archives.
0050|After this operation, 0 B of additional disk space will be used.
0051|(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 73773 files and directories currently installed.)
0052|Preparing to unpack .../python3_3.7.3-1_armhf.deb ...
0053|running python pre-rtupdate hooks for python3.7...
0054|Unpacking python3 (3.7.3-1) over (3.7.3-1) ...
0055|Preparing to unpack .../bluez_5.50-1.2~deb10u2+rpt1_armhf.deb ...
0056|Unpacking bluez (5.50-1.2~deb10u2+rpt1) over (5.50-1.2~deb10u2+rpt1) ...
0057|Preparing to unpack .../python3-pip_18.1-5+rpt1_all.deb ...
0058|Unpacking python3-pip (18.1-5+rpt1) over (18.1-5+rpt1) ...
0059|Setting up python3 (3.7.3-1) ...
0060|running python rtupdate hooks for python3.7...
0061|running python post-rtupdate hooks for python3.7...
0062|Setting up bluez (5.50-1.2~deb10u2+rpt1) ...
0063|Setting up python3-pip (18.1-5+rpt1) ...
0064|Processing triggers for man-db (2.8.5-2) ...
0065|Processing triggers for dbus (1.12.16-1) ...
0066|Processing triggers for systemd (241-7~deb10u2+rpi1) ...
0067|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0068|Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (68.0.0)
0069|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0070|Reading package lists...
0071|Building dependency tree...
0072|Reading state information...
0073|git is already the newest version (1:2.20.1-2+deb10u3).
0074|The following additional packages will be installed:
0075|libblkid-dev libglib2.0-dev-bin libmount-dev libpcre16-3 libpcre3-dev
0076|libpcre32-3 libpcrecpp0v5 libselinux1-dev libsepol1-dev uuid-dev
0077|Suggested packages:
0078|libglib2.0-doc libxml2-utils
0079|The following NEW packages will be installed:
0080|libblkid-dev libglib2.0-dev libglib2.0-dev-bin libmount-dev libpcre16-3
0081|libpcre3-dev libpcre32-3 libpcrecpp0v5 libselinux1-dev libsepol1-dev
0082|uuid-dev
0083|0 upgraded, 11 newly installed, 0 to remove and 287 not upgraded.
0084|Need to get 1,527 kB/3,679 kB of archives.
0085|After this operation, 14.5 MB of additional disk space will be used.
0086|Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf libglib2.0-dev-bin armhf 2.58.3-2+deb10u2
0087|404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
0088|Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf libglib2.0-dev armhf 2.58.3-2+deb10u2
0089|404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
0090|E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/glib2.0/libglib2.0-dev-bin_2.58.3-2+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
0091|E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/glib2.0/libglib2.0-dev_2.58.3-2+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
0092|E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
0093|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0094|Requirement already satisfied: pyudev in /usr/local/lib/python3.7/dist-packages (0.21.0)
0095|Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (from pyudev) (1.16.0)
0096|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0097|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0098|Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
0099|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0100|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0101|Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.31.0)
0102|Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.7/dist-packages (from requests) (3.3.2)
0103|Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests) (3.6)
0104|Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.7)
0105|Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests) (2023.11.17)
0106|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0107|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0108|Requirement already satisfied: pybluez in /usr/local/lib/python3.7/dist-packages (0.23)
0109|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0110|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0111|Requirement already satisfied: pillow in /usr/local/lib/python3.7/dist-packages (8.2.0)
0112|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0113|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0114|Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.20.3)
0115|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0116|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0117|Requirement already satisfied: bluepy in /usr/local/lib/python3.7/dist-packages (1.3.0)
0118|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0119|Cloning into 'bluepy'...
0120|running build
0121|running build_py
0122|creating build
0123|creating build/lib
0124|creating build/lib/bluepy
0125|copying bluepy/scan_fuzz.py -> build/lib/bluepy
0126|copying bluepy/get_services.py -> build/lib/bluepy
0127|copying bluepy/__init__.py -> build/lib/bluepy
0128|copying bluepy/blescan.py -> build/lib/bluepy
0129|copying bluepy/thingy52.py -> build/lib/bluepy
0130|copying bluepy/btle.py -> build/lib/bluepy
0131|copying bluepy/sensortag.py -> build/lib/bluepy
0132|copying bluepy/scanner.py -> build/lib/bluepy
0133|copying bluepy/uuids.json -> build/lib/bluepy
0134|copying bluepy/bluez-src.tgz -> build/lib/bluepy
0135|copying bluepy/bluepy-helper.c -> build/lib/bluepy
0136|copying bluepy/Makefile -> build/lib/bluepy
0137|/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:745: SetuptoolsDeprecationWarning: Invalid dash-separated options
0138|!!
0139|********************************************************************************
0140|Usage of dash-separated 'description-file' will not be supported in future
0141|versions. Please use the underscore name 'description_file' instead.
0142|This deprecation is overdue, please update your project and remove deprecated
0143|calls to avoid build errors in the future.
0144|See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
0145|********************************************************************************
0146|!!
0147|opt = self.warn_dash_deprecation(opt, section)
0148|running install
0149|/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:745: SetuptoolsDeprecationWarning: Invalid dash-separated options
0150|!!
0151|********************************************************************************
0152|Usage of dash-separated 'description-file' will not be supported in future
0153|versions. Please use the underscore name 'description_file' instead.
0154|This deprecation is overdue, please update your project and remove deprecated
0155|calls to avoid build errors in the future.
0156|See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
0157|********************************************************************************
0158|!!
0159|opt = self.warn_dash_deprecation(opt, section)
0160|/usr/local/lib/python3.7/dist-packages/setuptools/_distutils/cmd.py:66: SetuptoolsDeprecationWarning: setup.py install is deprecated.
0161|!!
0162|********************************************************************************
0163|Please avoid running ``setup.py`` directly.
0164|Instead, use pypa/build, pypa/installer or other
0165|standards-based tools.
0166|See https://blog.ganssle.io/articles/2021/10/setup-py-deprecated.html for details.
0167|********************************************************************************
0168|!!
0169|self.initialize_options()
0170|Working dir is /tmp/bluepy
0171|execute make -C ./bluepy clean
0172|execute make -C bluepy -j1
0173|Failed to compile bluepy-helper. Exiting install.
0174|Command was 'make -C bluepy -j1' in /tmp/bluepy
0175|Return code was 2
0176|Output was:
0177|b"make: Entering directory '/tmp/bluepy/bluepy'
0178|tar xzf bluez-src.tgz
0179|touch ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c
0180|Package glib-2.0 was not found in the pkg-config search path.
0181|Perhaps you should add the directory containing `glib-2.0.pc'
0182|to the PKG_CONFIG_PATH environment variable
0183|Package 'glib-2.0', required by 'virtual:world', not found
0184|Package glib-2.0 was not found in the pkg-config search path.
0185|Perhaps you should add the directory containing `glib-2.0.pc'
0186|to the PKG_CONFIG_PATH environment variable
0187|Package 'glib-2.0', required by 'virtual:world', not found
0188|cc -L. -g -Wall  -Os -DHAVE_CONFIG_H -I./bluez-5.47/attrib -I./bluez-5.47 -I./bluez-5.47/lib -I./bluez-5.47/src -I./bluez-5.47/gdbus -I./bluez-5.47/btio -I./bluez-5.47/sys  -o bluepy-helper bluepy-helper.c ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c
0189|bluepy-helper.c:33:10: fatal error: glib.h: No such file or directory
0190|#include <glib.h>
0191|^~~~~~~~
0192|compilation terminated.
0193|./bluez-5.47/attrib/att.c:33:10: fatal error: glib.h: No such file or directory
0194|#include <glib.h>
0195|^~~~~~~~
0196|compilation terminated.
0197|./bluez-5.47/attrib/gatt.c:32:10: fatal error: glib.h: No such file or directory
0198|#include <glib.h>
0199|^~~~~~~~
0200|compilation terminated.
0201|./bluez-5.47/attrib/gattrib.c:34:10: fatal error: glib.h: No such file or directory
0202|#include <glib.h>
0203|^~~~~~~~
0204|compilation terminated.
0205|./bluez-5.47/attrib/utils.c:30:10: fatal error: glib.h: No such file or directory
0206|#include <glib.h>
0207|^~~~~~~~
0208|compilation terminated.
0209|./bluez-5.47/btio/btio.c:37:10: fatal error: glib.h: No such file or directory
0210|#include <glib.h>
0211|^~~~~~~~
0212|compilation terminated.
0213|./bluez-5.47/src/log.c:38:10: fatal error: glib.h: No such file or directory
0214|#include <glib.h>
0215|^~~~~~~~
0216|compilation terminated.
0217|./bluez-5.47/src/shared/io-glib.c:30:10: fatal error: glib.h: No such file or directory
0218|#include <glib.h>
0219|^~~~~~~~
0220|compilation terminated.
0221|./bluez-5.47/src/shared/timeout-glib.c:22:10: fatal error: glib.h: No such file or directory
0222|#include <glib.h>
0223|^~~~~~~~
0224|compilation terminated.
0225|make: *** [Makefile:30: bluepy-helper] Error 1
0226|make: Leaving directory '/tmp/bluepy/bluepy'
0227|"
0228|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0229|Requirement already satisfied: cryptography in /usr/local/lib/python3.7/dist-packages (42.0.1)
0230|Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.7/dist-packages (from cryptography) (1.15.1)
0231|Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography) (2.21)
0232|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0233|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0234|Requirement already satisfied: pycrypto in /usr/lib/python3/dist-packages (2.6.1)
0235|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0236|********************************************************
0237|*			 Installation terminée					*
0238|********************************************************
Il va falloir songer à passer à Debian 11. Avec lequel BLEA n’est pas compatible.
bonjour Madcow,
j ai tapé la commande : sudo apt-get update --allow-releaseinfo-change
et la lumiere fut!, ca marche!
Un grand merci pour ton retour et ton assistance!
Super !
Mais il faut cocher Solution sur mon post et non le tien.
Il y avait pourtant un tuto :wink:
Je suis désolé j’ai pris le 1er lien qui venait…
Merci pour ton super tuto !
