Bonjour, Je vous confirme la version de 2.7.16 pour python.
J’ai réussi à faire passer le demon au vert (désinstallation-réinstallation et relancer les dépendances)
Mais il doit y avoir encore un problème, je n’arrive pas à faire dialoguer mon purificateur Xiaomi 3H avec ce pluging.
[2022-02-02 14:09:55.942][DEBUG] : refreshing {'apikey': 'ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L', 'type': 'wifi', 'cmd': 'refresh', 'model': 'purifier2', 'dest': '192.168.1.100', 'token': '8e0f1c219a89b82b846ec407cabf8c36', 'devtype': '13e7', 'serial': 'e37b'}
[2022-02-02 14:09:56.895][DEBUG] : params {"id":5609,"error":{"code":-5001,"message":"command error"},"exe_time":180}
[2022-02-02 14:09:56.896][ERROR] : SOCKET-READ------Exception on socket : 'result'
[2022-02-02 14:10:10][DEBUG] : Rafraîchissement de XiaomiWifi : Purificateur Air
[2022-02-02 14:10:10][DEBUG] : Envoi : {"apikey":"ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L","type":"wifi","cmd":"refresh","model":"purifier2","dest":"192.168.1.100","token":"8e0f1c219a89b82b846ec407dabf8c36","devtype":"13e7","serial":"e37b"}
[2022-02-02 14:10:10.295][DEBUG] : Client connected to [127.0.0.1:39822]
[2022-02-02 14:10:10.296][DEBUG] : Message read from socket: b'{"apikey":"ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L","type":"wifi","cmd":"refresh","model":"purifier2","dest":"192.168.1.100","token":"8e0f1c219a89b82b846ec407dabf8c36","devtype":"13e7","serial":"e37b"}'
[2022-02-02 14:10:10.296][DEBUG] : Client disconnected from [127.0.0.1:39822]
[2022-02-02 14:10:10.425][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-02-02 14:10:10.425][DEBUG] : SOCKET-READ------Received command from jeedom : refresh
[2022-02-02 14:10:10.426][DEBUG] : SOCKET-READ------Refreshing : purifier2
[2022-02-02 14:10:10.426][DEBUG] : refreshing {'apikey': 'ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L', 'type': 'wifi', 'cmd': 'refresh', 'model': 'purifier2', 'dest': '192.168.1.100', 'token': '8e0f1c219a89b82b846ec407dabf8c36', 'devtype': '13e7', 'serial': 'e37b'}
[2022-02-02 14:10:10.902][DEBUG] : params {"id":48145,"error":{"code":-5001,"message":"command error"},"exe_time":310}
[2022-02-02 14:10:10.902][ERROR] : SOCKET-READ------Exception on socket : 'result'
[2022-02-02 14:13:56.199][DEBUG] : Signal 15 caught, exiting...
[2022-02-02 14:13:56.200][DEBUG] : Shutdown
[2022-02-02 14:13:56.200][DEBUG] : Removing PID file /tmp/jeedom/xiaomihome/deamon.pid
[2022-02-02 14:20:10][INFO] : Lancement démon xiaomihome : /usr/bin/python3 /var/www/html/plugins/xiaomihome/resources/xiaomihomed/xiaomihomed.py --loglevel debug --socketport 55019 --callback http://127.0.0.1:80/plugins/xiaomihome/core/php/jeeXiaomiHome.php --apikey ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L --cycle 0.05 --pid /tmp/jeedom/xiaomihome/deamon.pid
[2022-02-02 14:20:12.323][INFO] : Start xiaomihomed
[2022-02-02 14:20:12.323][INFO] : Log level : debug
[2022-02-02 14:20:12.324][INFO] : Socket port : 55019
[2022-02-02 14:20:12.324][INFO] : Socket host : 127.0.0.1
[2022-02-02 14:20:12.324][INFO] : PID file : /tmp/jeedom/xiaomihome/deamon.pid
[2022-02-02 14:20:12.325][INFO] : Apikey : ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L
[2022-02-02 14:20:12.325][INFO] : Callback : http://127.0.0.1:80/plugins/xiaomihome/core/php/jeeXiaomiHome.php
[2022-02-02 14:20:12.325][INFO] : Cycle : 0.05
[2022-02-02 14:20:12.326][DEBUG] : Writing PID 22285 to /tmp/jeedom/xiaomihome/deamon.pid
[2022-02-02 14:20:12.330][DEBUG] : Init request module v2.27.1
[2022-02-02 14:20:12.360][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2022-02-02 14:20:12][DEBUG] : Format Invalide
[2022-02-02 14:20:12.388][DEBUG] : http://127.0.0.1:80 "GET /plugins/xiaomihome/core/php/jeeXiaomiHome.php?apikey=ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L HTTP/1.1" 200 0
[2022-02-02 14:20:12.392][DEBUG] : Socket interface started
[2022-02-02 14:20:12.400][DEBUG] : LoopNetServer Thread started
[2022-02-02 14:20:12.400][DEBUG] : Listening on: [127.0.0.1:55019]
[2022-02-02 14:20:12.403][INFO] : Start listening...
[2022-02-02 14:20:12.404][DEBUG] : Read Socket Thread Launched
[2022-02-02 14:20:12.411][DEBUG] : Aquara Thread Launched
[2022-02-02 14:26:29][DEBUG] : execute : action wifi refresh
[2022-02-02 14:26:29][DEBUG] : Envoi : {"apikey":"ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L","type":"wifi","cmd":"refresh","model":"purifier2","dest":"192.168.1.100","token":"8e0f1c219a89b82b846ec407dabf8c36","devtype":"13e7","serial":"e37b"}
[2022-02-02 14:26:29.149][DEBUG] : Client connected to [127.0.0.1:45636]
[2022-02-02 14:26:29.150][DEBUG] : Message read from socket: b'{"apikey":"ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L","type":"wifi","cmd":"refresh","model":"purifier2","dest":"192.168.1.100","token":"8e0f1c219a89b82b846ec407dabf8c36","devtype":"13e7","serial":"e37b"}'
[2022-02-02 14:26:29.150][DEBUG] : Client disconnected from [127.0.0.1:45636]
[2022-02-02 14:26:29.186][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-02-02 14:26:29.186][DEBUG] : SOCKET-READ------Received command from jeedom : refresh
[2022-02-02 14:26:29.186][DEBUG] : SOCKET-READ------Refreshing : purifier2
[2022-02-02 14:26:29.186][DEBUG] : refreshing {'apikey': 'ZLHmGw4rJuEH6alqXTjmnVbcLyRFxkYhYvDen7BU6DkyPWYeE8LV0PQFe3m9Tr2L', 'type': 'wifi', 'cmd': 'refresh', 'model': 'purifier2', 'dest': '192.168.1.100', 'token': '8e0f1c219a89b82b846ec407dabf8c36', 'devtype': '13e7', 'serial': 'e37b'}
[2022-02-02 14:26:29.856][DEBUG] : params {"id":8857,"error":{"code":-5001,"message":"command error"},"exe_time":250}
[2022-02-02 14:26:29.856][ERROR] : SOCKET-READ------Exception on socket : 'result'
Merci pour votre aide
