Depuis quelques jours le démon ne se redémarre pas, j’ai l’impression que c’est lié a un souci avec python
log démon:
[2022-07-08 08:27:59][ERROR] : Fatal error : 1
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaacd.py", line 207, in <module>
ToshibaApp.init_connection()
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaconnect/toshibaac.py", line 42, in init_connection
return self.exec_async_fx(self.__async__init_connection)
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaconnect/toshibaac.py", line 39, in exec_async_fx
return asyncio.run_coroutine_threadsafe(fonction(), self.loop).result()
File "/usr/lib/python3.7/concurrent/futures/_base.py", line 432, in result
return self.__get_result()
File "/usr/lib/python3.7/concurrent/futures/_base.py", line 384, in __get_result
raise self._exception
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaconnect/toshibaac.py", line 62, in __async__init_connection
self.equipmentChanged(device)
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshibaconnect/toshibaac.py", line 112, in equipmentChanged
res["AcFeatureMeritB"] = data.fcu_state.ac_merit_b.name
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshiba_ac/device/fcu_state.py", line 420, in ac_merit_b
return ToshibaAcFcuState.AcMeritB.from_raw(self._ac_merit_b)
File "/var/www/html/plugins/toshibaac/resources/toshibaacd/toshiba_ac/device/fcu_state.py", line 182, in from_raw
}[raw]
KeyError: 1
Log install démon
* Launch install of dependencies *
Fri Jul 8 08:27:07 CEST 2022
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
Get:5 https://download.docker.com/linux/debian buster InRelease [54.0 kB]
Fetched 54.0 kB in 0s (114 kB/s)
Reading package lists...
Install modules using apt-get
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5).
python3 is already the newest version (3.7.3-1).
python3-requests is already the newest version (2.21.0-1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up mosquitto (1.5.7-1+deb10u1) ...
Job for mosquitto.service failed because the control process exited with error code.
See "systemctl status mosquitto.service" and "journalctl -xe" for details.
invoke-rc.d: initscript mosquitto, action "start" failed.
* mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; disabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2022-07-08 08:27:09 CEST; 4ms ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 18757 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 18757 (code=exited, status=1/FAILURE)
dpkg: error processing package mosquitto (--configure):
installed mosquitto package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
mosquitto
E: Sub-process /usr/bin/dpkg returned an error code (1)
Install the required python libraries
/usr/lib/python3/dist-packages/secretstorage/dhcrypto.py:15: CryptographyDeprecationWarning: int_from_bytes is deprecated, use int.from_bytes instead
from cryptography.utils import int_from_bytes
/usr/lib/python3/dist-packages/secretstorage/util.py:19: CryptographyDeprecationWarning: int_from_bytes is deprecated, use int.from_bytes instead
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (62.6.0)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Requirement already satisfied: azure-iot-device==2.9.0 in /usr/local/lib/python3.7/dist-packages (2.9.0)
Requirement already satisfied: requests<3.0.0,>=2.20.0 in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (2.28.0)
Requirement already satisfied: six<2.0.0,>=1.12.0 in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (1.16.0)
Requirement already satisfied: janus in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (1.0.0)
Requirement already satisfied: deprecation<3.0.0,>=2.1.0 in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (2.1.0)
Requirement already satisfied: urllib3<1.27,>=1.26.5 in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (1.26.9)
Requirement already satisfied: paho-mqtt<2.0.0,>=1.4.0 in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (1.6.1)
Requirement already satisfied: requests-unixsocket<1.0.0,>=0.1.5 in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (0.3.0)
Requirement already satisfied: PySocks in /usr/local/lib/python3.7/dist-packages (from azure-iot-device==2.9.0) (1.7.1)
Requirement already satisfied: packaging in /usr/local/lib/python3.7/dist-packages (from deprecation<3.0.0,>=2.1.0->azure-iot-device==2.9.0) (21.3)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests<3.0.0,>=2.20.0->azure-iot-device==2.9.0) (2022.6.15)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests<3.0.0,>=2.20.0->azure-iot-device==2.9.0) (3.3)
Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.7/dist-packages (from requests<3.0.0,>=2.20.0->azure-iot-device==2.9.0) (2.0.12)
Requirement already satisfied: typing-extensions>=3.7.4.3 in /usr/local/lib/python3.7/dist-packages (from janus->azure-iot-device==2.9.0) (4.2.0)
Requirement already satisfied: pyparsing!=3.0.5,>=2.0.2 in /usr/local/lib/python3.7/dist-packages (from packaging->deprecation<3.0.0,>=2.1.0->azure-iot-device==2.9.0) (3.0.9)
Requirement already satisfied: aiohttp==3.8.1 in /usr/local/lib/python3.7/dist-packages (3.8.1)
Requirement already satisfied: typing-extensions>=3.7.4 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (4.2.0)
Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (4.0.2)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (1.7.2)
Requirement already satisfied: charset-normalizer<3.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (2.0.12)
Requirement already satisfied: asynctest==0.13.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (0.13.0)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (6.0.2)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (1.2.0)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (21.4.0)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.7/dist-packages (from aiohttp==3.8.1) (1.3.0)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp==3.8.1) (3.3)
Fri Jul 8 08:27:12 CEST 2022
* Install ended *
Merci d’avance pour les retours
(cf tous les posts sur
