J’ai fait la mise à jour du plugin ce matin, puis une autre dans la journée, lancé la réinstallation des dépendances et tout fonctionne… Mais le démon s’arrête tout seul !
Si je le relance à la main, il se lance, peut lancer quelques commande, puis se coupe à nouveau.
Je vois rien de spécial dans le log :
[2020-11-26 16:31:21][INFO] : Démon RFXcom lancé
[2020-11-26 16:31:21][DEBUG] : Message read from socket: b'{"apikey":"tlssqQGMTjwS3LrCP861uGnQ7s0OpGHnGJiLeA4BamRGbRS2","cmd":"add","device":{"id":"1F04"}}'
[2020-11-26 16:31:21][DEBUG] : Client disconnected from [127.0.0.1:33964]
[2020-11-26 16:31:21][DEBUG] : Client connected to [127.0.0.1:33966]
[2020-11-26 16:31:21][DEBUG] : Message read from socket: b'{"apikey":"tlssqQGMTjwS3LrCP861uGnQ7s0OpGHnGJiLeA4BamRGbRS2","cmd":"add","device":{"id":"2F9E38"}}'
[2020-11-26 16:31:21][DEBUG] : Client disconnected from [127.0.0.1:33966]
[2020-11-26 16:31:21][DEBUG] : Client connected to [127.0.0.1:33968]
[2020-11-26 16:31:21][DEBUG] : Message read from socket: b'{"apikey":"tlssqQGMTjwS3LrCP861uGnQ7s0OpGHnGJiLeA4BamRGbRS2","cmd":"add","device":{"id":"35E933"}}'
[2020-11-26 16:31:21][DEBUG] : Client disconnected from [127.0.0.1:33968]
[2020-11-26 16:31:21][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-11-26 16:31:21][DEBUG] : Add device : {'id': '3D83D1'}
[2020-11-26 16:31:21][DEBUG] : Add device : {'id': '782BBA'}
[2020-11-26 16:31:21][DEBUG] : Add device : {'id': '1F04'}
[2020-11-26 16:31:21][DEBUG] : Add device : {'id': '2F9E38'}
[2020-11-26 16:31:21][DEBUG] : Add device : {'id': '35E933'}
[2020-11-26 16:31:46][ERROR] : Timeout waiting status
[2020-11-26 16:31:46][DEBUG] : Shutdown
[2020-11-26 16:31:46][DEBUG] : Removing PID file /tmp/jeedom/rfxcom/deamon.pid
[2020-11-26 16:31:46][DEBUG] : LoopNetServer Thread stopped
[2020-11-26 16:31:46][DEBUG] : Close serial port
[2020-11-26 16:31:46][DEBUG] : Serial port closed
[2020-11-26 16:31:46][DEBUG] : Exit 0
Bonsoir.
Cet échange a attiré mon attention.
Mon matériel RFXtrx433XL est sous firmware 1029: tu as utilisé la procédure sous Linux pour la mise à jour ou celle sous windows ?
En effet j’ai tenté l’installation Linux à partir de mon RPI ( mais est ce possible ? ) selon les informations du site RFX.com (chargé application Mono + librairie libmono-microsoft-visualbasic10.0-cil la version 8 n’étant plus disponible + firmware dédié + rfxflash) mais l’instruction « sudo mono rfxflash.exe » est refusée avec motif « Cannot open assembly ‹ RFXflash ›: Aucun fichier ou dossier de ce type »: où serait mon erreur ?
Si tu as utilisé windows les instructions du site sont elles suffisantes ?
Merci d’avance.
Tu peux faire le flash sous windows c’est super simple.
Tu ouvres le logiciel, tu connectes ton rfxcom tu choisis le fichier hex, ça le charge ensuitre writte puis normal mode.
fini
J’ai utilisé windows pour le faire !
Et c’est effectivement super simple…Domadoo a fait un article là dessus, aucune difficulté particulière. J’ai galéré avec une DLL manquante mais c’était pour RFXmng qui n’est pas utile dans ce cas.
Bonsoir.
Un consensus se dégage pour une mise à jour avec un ordinateur windows.
Mais le fait d’utiliser mon RPI pour cette mise à jour selon la procédure Linux décrite sur Rfxcom aurait été plus tentante d’autant plus que je voulais le faire à distance.
Tant pis cela attendra le prochain déconfinement.
