Après 6 ans de bons et loyaux services, mon RFplayer me donne des soucis.
Premier soucis je dois relancer le demon de temps en temps.
Deuxième soucis un de mes micromodule on/off (DIO) ne fonctionne qu’une fois sur deux (indépendamment du soucis du demon)
saisissez ou collez du code ici[2024-09-29 08:11:08.600] ERROR : Error in read_rfplayer: read failed: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
[2024-09-29 08:11:08.801] ERROR : Error in read_rfplayer: read failed: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
[2024-09-29 10:11:11] INFO : Lancement démon rfplayer2 : sudo /usr/bin/python3 /var/www/html/plugins/rfplayer2/resources/rfplayer2/rfplayer2d.py --device=auto --loglevel=info --socketport=55020 --callback=http://127.0.0.1:80/plugins/rfplayer2/core/php/jeeRfplayer2.php --apikey=vxKtxDCL1VqONvN85wKf8jMv6XQpnecQ --cycle 0.3 --pid /tmp/jeedom/rfplayer2/deamon.pid
[2024-09-29 08:11:11.973] INFO : Start rfplayerd
[2024-09-29 08:11:11.975] INFO : Log level : info
[2024-09-29 08:11:11.975] INFO : Socket port : 55020
[2024-09-29 08:11:11.975] INFO : Socket host : localhost
[2024-09-29 08:11:11.975] INFO : PID file : /tmp/jeedom/rfplayer2/deamon.pid
[2024-09-29 08:11:11.976] INFO : Apikey : vxKtxDCL1VqONvN85wKf8jMv6XQpnecQ
[2024-09-29 08:11:11.976] INFO : Callback : http://127.0.0.1:80/plugins/rfplayer2/core/php/jeeRfplayer2.php
[2024-09-29 08:11:11.976] INFO : Cycle : 0.3
[2024-09-29 08:11:12.000] INFO : Find device : /dev/ttyUSB0
[2024-09-29 08:11:12.037] INFO : LOADER------Import de la configuration rfplayer.devices.blyss
[2024-09-29 08:11:12.041] INFO : LOADER------Import de la configuration rfplayer.devices.chacon
[2024-09-29 08:11:12.043] INFO : LOADER------Import de la configuration rfplayer.devices.domia
[2024-09-29 08:11:12.045] INFO : LOADER------Import de la configuration rfplayer.devices.edisio
[2024-09-29 08:11:12.047] INFO : LOADER------Import de la configuration rfplayer.devices.jamming
[2024-09-29 08:11:12.050] INFO : LOADER------Import de la configuration rfplayer.devices.kd101
[2024-09-29 08:11:12.052] INFO : LOADER------Import de la configuration rfplayer.devices.oregon
[2024-09-29 08:11:12.054] INFO : LOADER------Import de la configuration rfplayer.devices.owl
[2024-09-29 08:11:12.056] INFO : LOADER------Import de la configuration rfplayer.devices.parrot
[2024-09-29 08:11:12.058] INFO : LOADER------Import de la configuration rfplayer.devices.rfplayer
[2024-09-29 08:11:12.060] INFO : LOADER------Import de la configuration rfplayer.devices.rts
[2024-09-29 08:11:12.062] INFO : LOADER------Import de la configuration rfplayer.devices.tic
[2024-09-29 08:11:12.064] INFO : LOADER------Import de la configuration rfplayer.devices.types
[2024-09-29 08:11:12.064] INFO : LOADER------Import de la configuration rfplayer.devices.visionic
[2024-09-29 08:11:12.066] INFO : LOADER------Import de la configuration rfplayer.devices.visonic
[2024-09-29 08:11:12.068] INFO : LOADER------Import de la configuration rfplayer.devices.x10
[2024-09-29 08:11:12.070] INFO : LOADER------Import de la configuration rfplayer.devices.x2d
[2024-09-29 10:11:12] INFO : API RfPlayer solicité
[2024-09-29 10:11:12] INFO : Learn désactivé
[2024-09-29 11:46:52] INFO : API RfPlayer solicité
[2024-09-29 11:59:34] INFO : API RfPlayer solicité
[2024-09-29 12:04:19] INFO : API RfPlayer solicité
[2024-09-29 16:32:01] INFO : API RfPlayer solicité
[2024-09-29 16:46:29] INFO : API RfPlayer solicité
[2024-09-30 10:12:04] INFO : API RfPlayer solicité
