1960|[2022-11-01 09:40:09.583][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 11): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1963|[2022-11-01 09:40:09.635][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 12): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1966|[2022-11-01 09:40:09.690][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 13): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1969|[2022-11-01 09:40:09.763][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 14): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1972|[2022-11-01 09:40:09.853][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 15): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1975|[2022-11-01 09:40:09.940][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 16): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1978|[2022-11-01 09:40:09.994][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 17): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1981|[2022-11-01 09:40:10.103][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 18): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1984|[2022-11-01 09:40:10.174][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 19): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1987|[2022-11-01 09:40:10.227][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 20): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1990|[2022-11-01 09:40:10.287][ERROR] : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute management command 'le on' (code: 17, error: Invalid Index)
1991|[2022-11-01 09:40:10.288][INFO] : GLOBAL------Shutting down due to errors
bonjour depuis environ 2 semaine je suis embêter en permanence avec mon antenne principal qui tombe toute les 10 minute environ. (si dessus, mes log et en dessous ma page santé, ou on peut voir la version de mon jeedom et ma page du plugin blea.)
J’ai aussi réhinstallé le core de jeedom aussi que le plugin, j’ai un clée sena( la bonne pourtant) et mon jeedom est sur proxmox et ma clée est toujour vue par la vm même quand les démon sont en nok.
