voici les log de Z2m
[2024-04-29 11:30:27] INFO : Arrêt du démon z2m
[2024-04-29 11:35:03] INFO : Arrêt du démon z2m
[2024-04-29 11:35:06] INFO : Démarrage du démon Z2M : ZIGBEE2MQTT_DATA=/var/www/html/plugins/z2m/core/class/../../data npm start --prefix /var/www/html/plugins/z2m/resources/zigbee2mqtt
[2024-04-29 13:55:04] INFO : Arrêt du démon z2m
[2024-04-29 13:55:05] INFO : Démarrage du démon Z2M : ZIGBEE2MQTT_DATA=/var/www/html/plugins/z2m/core/class/../../data npm start --prefix /var/www/html/plugins/z2m/resources/zigbee2mqtt
Voici le debut des log Z2m_firmware:
[2024-04-29 10:19:43] INFO : Lancement de la mise à jour du firmware pour : /dev/ttyS2 => sudo chmod +x /var/www/html/plugins/z2m/core/class/../../resources/misc/ezsp-fix-bootloader.sh;sudo /var/www/html/plugins/z2m/core/class/../../resources/misc/ezsp-fix-bootloader.sh /dev/ttyS2
[2024-04-29 10:19:43] ALERT : sudo chmod +x /var/www/html/plugins/z2m/core/class/../../resources/misc/ezsp-fix-bootloader.sh;sudo /var/www/html/plugins/z2m/core/class/../../resources/misc/ezsp-fix-bootloader.sh /dev/ttyS2
Begin change mode of /dev/ttyS2
Download source...
--2024-04-29 10:19:43-- https://github.com/Elelabs/elelabs-zigbee-ezsp-utility/archive/master.zip
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
voici les log Z2md
Zigbee2MQTT:info 2024-04-29 18:44:43: MQTT publish: topic 'zigbee2mqtt/0xa4c138974506e923', payload '{"child_lock":"UNLOCK","current":0.44,"device":{"applicationVersion":76,"dateCode":"","friendlyName":"0xa4c138974506e923","hardwareVersion":1,"ieeeAddr":"0xa4c138974506e923","manufacturerID":4417,"manufacturerName":"_TZ3000_ksw8qtmt","model":"A1Z","networkAddress":54111,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":78.26,"indicator_mode":"off/on","last_seen":"2024-04-29T16:44:43.346Z","linkquality":208,"power":64,"power_outage_memory":"restore","state":"ON","voltage":234}'
Zigbee2MQTT:info 2024-04-29 18:44:52: MQTT publish: topic 'zigbee2mqtt/0x84fd27fffe8d6ded', payload '{"child_lock":"UNLOCK","device":{"applicationVersion":67,"dateCode":"","friendlyName":"0x84fd27fffe8d6ded","hardwareVersion":1,"ieeeAddr":"0x84fd27fffe8d6ded","manufacturerID":4098,"manufacturerName":"_TZ3000_o005nuxx","model":"SM-O301-AZ","networkAddress":59590,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"last_seen":"2024-04-29T16:44:52.680Z","linkquality":156,"power_outage_memory_l1":"on","state_l1":"ON","state_l2":"ON","state_l3":"ON","state_l4":"ON","state_l5":"ON"}'
Zigbee2MQTT:info 2024-04-29 18:44:59: MQTT publish: topic 'zigbee2mqtt/0x3c2ef5fffeb9e535', payload '{"battery":100,"device":{"applicationVersion":0,"dateCode":"20230105","friendlyName":"0x3c2ef5fffeb9e535","hardwareVersion":0,"ieeeAddr":"0x3c2ef5fffeb9e535","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SNZB-02D","networkAddress":55898,"powerSource":"Battery","softwareBuildID":"1.0.9","type":"EndDevice","zclVersion":8},"humidity":41.9,"last_seen":"2024-04-29T16:44:59.611Z","linkquality":132,"temperature":24.2}'
Zigbee2MQTT:info 2024-04-29 18:45:00: MQTT publish: topic 'zigbee2mqtt/0x30fb10fffe770ca1', payload '{"battery":80,"device":{"applicationVersion":0,"dateCode":"20230105","friendlyName":"0x30fb10fffe770ca1","hardwareVersion":0,"ieeeAddr":"0x30fb10fffe770ca1","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SNZB-02D","networkAddress":47298,"powerSource":"Battery","softwareBuildID":"1.0.9","type":"EndDevice","zclVersion":8},"humidity":39.6,"last_seen":"2024-04-29T16:45:00.335Z","linkquality":144,"temperature":25.6}'
Zigbee2MQTT:info 2024-04-29 18:45:19: MQTT publish: topic 'zigbee2mqtt/0x3c2ef5fffeb9e535', payload '{"battery":100,"device":{"applicationVersion":0,"dateCode":"20230105","friendlyName":"0x3c2ef5fffeb9e535","hardwareVersion":0,"ieeeAddr":"0x3c2ef5fffeb9e535","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SNZB-02D","networkAddress":55898,"powerSource":"Battery","softwareBuildID":"1.0.9","type":"EndDevice","zclVersion":8},"humidity":41.9,"last_seen":"2024-04-29T16:45:19.460Z","linkquality":132,"temperature":24.2}'
Zigbee2MQTT:info 2024-04-29 18:45:24: MQTT publish: topic 'zigbee2mqtt/0x5c0272fffe03c755', payload '{"child_lock":"UNLOCK","device":{"applicationVersion":67,"dateCode":"","friendlyName":"0x5c0272fffe03c755","hardwareVersion":1,"ieeeAddr":"0x5c0272fffe03c755","manufacturerID":4098,"manufacturerName":"_TZ3000_o005nuxx","model":"SM-O301-AZ","networkAddress":44583,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"last_seen":"2024-04-29T16:45:24.646Z","linkquality":168,"power_outage_memory_l1":"on","state_l1":"OFF","state_l2":"OFF","state_l3":"OFF","state_l4":"OFF","state_l5":"OFF"}'
Zigbee2MQTT:info 2024-04-29 18:46:13: MQTT publish: topic 'zigbee2mqtt/0xa4c138974506e923', payload '{"child_lock":"UNLOCK","current":0.44,"device":{"applicationVersion":76,"dateCode":"","friendlyName":"0xa4c138974506e923","hardwareVersion":1,"ieeeAddr":"0xa4c138974506e923","manufacturerID":4417,"manufacturerName":"_TZ3000_ksw8qtmt","model":"A1Z","networkAddress":54111,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":78.26,"indicator_mode":"off/on","last_seen":"2024-04-29T16:46:13.480Z","linkquality":200,"power":64,"power_outage_memory":"restore","state":"ON","voltage":234}'
Zigbee2MQTT:info 2024-04-29 18:46:18: MQTT publish: topic 'zigbee2mqtt/0x30fb10fffe770ca9', payload '{"battery":80,"device":{"applicationVersion":0,"dateCode":"20230105","friendlyName":"0x30fb10fffe770ca9","hardwareVersion":0,"ieeeAddr":"0x30fb10fffe770ca9","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SNZB-02D","networkAddress":16505,"powerSource":"Battery","softwareBuildID":"1.0.9","type":"EndDevice","zclVersion":8},"humidity":40.2,"last_seen":"2024-04-29T16:46:18.516Z","linkquality":152,"temperature":25.1}'
Zigbee2MQTT:info 2024-04-29 18:46:19: MQTT publish: topic 'zigbee2mqtt/0x30fb10fffe770ca1', payload '{"battery":80,"device":{"applicationVersion":0,"dateCode":"20230105","friendlyName":"0x30fb10fffe770ca1","hardwareVersion":0,"ieeeAddr":"0x30fb10fffe770ca1","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SNZB-02D","networkAddress":47298,"powerSource":"Battery","softwareBuildID":"1.0.9","type":"EndDevice","zclVersion":8},"humidity":39.6,"last_seen":"2024-04-29T16:46:19.834Z","linkquality":156,"temperature":25.6}'
Zigbee2MQTT:info 2024-04-29 18:46:53: MQTT publish: topic 'zigbee2mqtt/0xa4c138d1543250b4', payload '{"child_lock":"UNLOCK","current":0,"device":{"applicationVersion":76,"dateCode":"","friendlyName":"0xa4c138d1543250b4","hardwareVersion":1,"ieeeAddr":"0xa4c138d1543250b4","manufacturerID":4417,"manufacturerName":"_TZ3000_ksw8qtmt","model":"A1Z","networkAddress":16749,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":24.53,"indicator_mode":"off/on","last_seen":"2024-04-29T16:46:53.891Z","linkquality":204,"power":0,"power_outage_memory":"restore","state":"ON","voltage":235}'
Voila, avec toutes mes excuse pour la copie precedente.
