Bonjour malgrès ma dernière mise à jour j’ai un soucis avec mon démon qui est en NOK
Je suis en V3.3.5.4
Le plugin est en 3.3.24
Je vous post les différents logs:
[2021-1-4 14:05:08][] : Proxy Init: reuse frc from former data
[2021-1-4 14:05:08][] : Proxy Init: reuse map-md from former data
[2021-1-4 14:05:08][] : Proxy Init: reuse deviceId from former data
[2021-1-4 14:05:08][] : Alexa-Cookie: Proxy-Server listening on port 38839
[2021-1-4 14:05:08][] : Alexa-Remote: Error from retrieving cookies
[2021-1-4 14:05:08][ERROR] : {API} ╠════════════════════════════════════════════════════════════════════════════════════════
[2021-1-4 14:05:08][ERROR] : {API} ║ Souci dans l'initiatlisation du serveur Error: You can try to get the cookie manually by opening http://undefined:38839/ with your browser.
[2021-1-4 14:05:08][ERROR] : {API} ║ ou le serveur alexa.amazon.fr n'est pas joignable
[2021-1-4 14:05:08][ERROR] : {API} ╚════════════════════════════════════════════════════════════════════════════════════════
[2021-1-4 14:10:07][] : Proxy Init: reuse frc from former data
[2021-1-4 14:10:07][] : Proxy Init: reuse map-md from former data
[2021-1-4 14:10:07][] : Proxy Init: reuse deviceId from former data
[2021-1-4 14:10:07][] : Alexa-Cookie: Proxy-Server listening on port 41971
[2021-1-4 14:10:07][] : Alexa-Remote: Error from retrieving cookies
[2021-1-4 14:10:07][ERROR] : {API} ╠════════════════════════════════════════════════════════════════════════════════════════
[2021-1-4 14:10:07][ERROR] : {API} ║ Souci dans l'initiatlisation du serveur Error: You can try to get the cookie manually by opening http://undefined:41971/ with your browser.
[2021-1-4 14:10:07][ERROR] : {API} ║ ou le serveur alexa.amazon.fr n'est pas joignable
[2021-1-4 14:10:07][ERROR] : {API} ╚════════════════════════════════════════════════════════════════════════════════════════
[2021-1-4 14:15:07][] : Proxy Init: reuse frc from former data
[2021-1-4 14:15:07][] : Proxy Init: reuse map-md from former data
[2021-1-4 14:15:07][] : Proxy Init: reuse deviceId from former data
[2021-1-4 14:15:07][] : Alexa-Cookie: Proxy-Server listening on port 44073
[2021-1-4 14:15:07][] : Alexa-Remote: Error from retrieving cookies
[2021-1-4 14:15:07][ERROR] : {API} ╠════════════════════════════════════════════════════════════════════════════════════════
[2021-1-4 14:15:07][ERROR] : {API} ║ Souci dans l'initiatlisation du serveur Error: You can try to get the cookie manually by opening http://undefined:44073/ with your browser.
[2021-1-4 14:15:07][ERROR] : {API} ║ ou le serveur alexa.amazon.fr n'est pas joignable
[2021-1-4 14:15:07][ERROR] : {API} ╚════════════════════════════════════════════════════════════════════════════════════════
[2021-01-04 13:55:03][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2021-01-04 14:00:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2021-01-04 14:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2021-01-04 14:10:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
[2021-01-04 14:15:03][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consecutivement
== 04/01/2021 13:29:18 == Installation des dépendances de alexaapi
[ 0% ] : Vérification des droits...
[ 9% ] : Vérification des droits : [0sec] : [ OK ]
[ 10% ] : Prérequis...
[ 19% ] : Prérequis : [0sec] : [ OK ]
[ 20% ] : Mise à jour APT et installation des packages nécessaires...
[ 29% ] : Mise à jour APT et installation des packages nécessaires : [3sec] : [ OK ]
[ 30% ] : Vérification de la version de NodeJS installée...
Version actuelle : v12.20.0
Ok, version suffisante
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
[ 49% ] : Vérification de la version de NodeJS installée : [2sec] : [ OK ]
[ 50% ] : Nettoyage ancien modules...
[ 59% ] : Nettoyage ancien modules : [0sec] : [ OK ]
[ 60% ] : Installation des librairies, veuillez patienter svp...
[ 89% ] : Installation des librairies, veuillez patienter svp : [13sec] : [ OK ]
[ 90% ] : Nettoyage...
[ 99% ] : Nettoyage : [0sec] : [ OK ]
[100% ] : Terminé !
== OK == Installation Réussie
