j’ai installé ce plugin mais le démon ne se lance pas.
je n’arrive pas à interpréter les logs.
Probléme Python?
les dépendances sont bien installé.
Log des dépendances :
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: websocket-client in /usr/local/lib/python3.9/dist-packages (1.4.1)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
--- Logging error ---
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/utils/logging.py", line 177, in emit
self.console.print(renderable, overflow="ignore", crop=False, style=style)
File "/usr/local/lib/python3.9/dist-packages/pip/_vendor/rich/console.py", line 1673, in print
extend(render(renderable, render_options))
File "/usr/local/lib/python3.9/dist-packages/pip/_vendor/rich/console.py", line 1305, in render
for render_output in iter_render:
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/utils/logging.py", line 134, in __rich_console__
for line in lines:
File "/usr/local/lib/python3.9/dist-packages/pip/_vendor/rich/segment.py", line 249, in split_lines
for segment in segments:
File "/usr/local/lib/python3.9/dist-packages/pip/_vendor/rich/console.py", line 1283, in render
renderable = rich_cast(renderable)
File "/usr/local/lib/python3.9/dist-packages/pip/_vendor/rich/protocol.py", line 36, in rich_cast
renderable = cast_method()
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/self_outdated_check.py", line 130, in __rich__
pip_cmd = get_best_invocation_for_this_pip()
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/utils/entrypoints.py", line 58, in get_best_invocation_for_this_pip
if found_executable and os.path.samefile(
File "/usr/lib/python3.9/genericpath.py", line 101, in samefile
s2 = os.stat(f2)
FileNotFoundError: [Errno 2] No such file or directory: '/usr/bin/pip3.9'
Call stack:
File "/usr/local/bin/pip", line 8, in
sys.exit(main())
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/cli/base_command.py", line 101, in main
return self._main(args)
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main
self.handle_pip_version_check(options)
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/cli/req_command.py", line 190, in handle_pip_version_check
pip_self_version_check(session, options)
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/self_outdated_check.py", line 236, in pip_self_version_check
logger.warning("[present-rich] %s", upgrade_prompt)
File "/usr/lib/python3.9/logging/__init__.py", line 1454, in warning
self._log(WARNING, msg, args, **kwargs)
File "/usr/lib/python3.9/logging/__init__.py", line 1585, in _log
self.handle(record)
File "/usr/lib/python3.9/logging/__init__.py", line 1595, in handle
self.callHandlers(record)
File "/usr/lib/python3.9/logging/__init__.py", line 1657, in callHandlers
hdlr.handle(record)
File "/usr/lib/python3.9/logging/__init__.py", line 948, in handle
self.emit(record)
File "/usr/local/lib/python3.9/dist-packages/pip/_internal/utils/logging.py", line 179, in emit
self.handleError(record)
Message: '[present-rich] %s'
Arguments: (UpgradePrompt(old='22.2.2', new='22.3'),)
Requirement already satisfied: rijndael in /usr/local/lib/python3.9/dist-packages (0.1.1)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: ipaddress in /usr/local/lib/python3.9/dist-packages (1.0.23)
for line in lines:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: pycrypto in /usr/local/lib/python3.9/dist-packages (2.6.1)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: aenum in /usr/local/lib/python3.9/dist-packages (3.1.11)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: requests in /usr/local/lib/python3.9/dist-packages (2.28.1)
Requirement already satisfied: charset-normalizer<3,>=2 in /usr/local/lib/python3.9/dist-packages (from requests) (2.0.12)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests) (3.4)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests) (2022.9.24)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests) (1.26.12)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon'...
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/__init__.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/communicationStatus.py'...
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/WebSocketConnection.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/__init__.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/configuration.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/connection.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/connectors.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/handlers.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/httpservice.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/identity.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/messages.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/requestUrl.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/connexion/service.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/crypto.py'...
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/encryption'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/encryption/__init__.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/encryption/aes_decrypt.py'...
*** File "/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/encryption/aes_decrypt.py", line 67
0L,0L,0L,0L,0L,0L,0L,0L,
SyntaxError: invalid syntax
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/encryption/encryption.py'...
*** Sorry: TabError: inconsistent use of tabs and spaces in indentation (encryption.py, line 38)
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/encryption/keys.py'...
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/events'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/events/SocketConnectionStatus.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/events/__init__.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/events/event.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/events/observer.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/events/publisher.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/exceptions.py'...
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/samsung'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/samsung/HttpService.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/samsung/TvProperties.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/samsung/__init__.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/smartcrypto.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/smarterror.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/tcphandler.py'...
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/utils'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/utils/__init__.py'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/lib/utils/smartJHLogger.py'...
Listing '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/logs'...
Compiling '/var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/smartJHDaemon.py'...
Everything is successfully installed!
Ci joint les logs :
[2022-11-01 18:24:49]ERROR : Attention je pense qu\'il y a un soucis avec le démon que j\'ai relancé plus de 3 fois consécutivement
[2022-11-01 18:24:49]INFO : stop deamon TvDomSamsung
[2022-11-01 18:24:49]DEBUG : TvDomSamsung deamon stopped
[2022-11-01 18:24:49]INFO : Lancement service : sudo python /var/www/html/plugins/TvDomSamsung/core/class/../../resources/smartJHDaemon/smartJHDaemon.pyc > /dev/null 2>&1 &
La page santée :
Est ce lié à Débian 11?
Merci ![]()
