Cette mise à jour a résolu mes soucis, de mon côté.
Toujours pas bon ici … (j’ai rebooté Jeedom aussi, mais rien)
Found existing installation: frozenlist 1.3.0
Uninstalling frozenlist-1.3.0:
Successfully uninstalled frozenlist-1.3.0
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 2.0.12
Uninstalling charset-normalizer-2.0.12:
Successfully uninstalled charset-normalizer-2.0.12
Attempting uninstall: attrs
Found existing installation: attrs 21.4.0
Uninstalling attrs-21.4.0:
Successfully uninstalled attrs-21.4.0
Attempting uninstall: asynctest
Found existing installation: asynctest 0.13.0
Uninstalling asynctest-0.13.0:
Successfully uninstalled asynctest-0.13.0
Attempting uninstall: yarl
Found existing installation: yarl 1.7.2
Uninstalling yarl-1.7.2:
Successfully uninstalled yarl-1.7.2
Attempting uninstall: cffi
Found existing installation: cffi 1.15.0
Uninstalling cffi-1.15.0:
Successfully uninstalled cffi-1.15.0
Attempting uninstall: async-timeout
Found existing installation: async-timeout 4.0.2
Uninstalling async-timeout-4.0.2:
Successfully uninstalled async-timeout-4.0.2
Attempting uninstall: aiosqlite
Found existing installation: aiosqlite 0.17.0
Uninstalling aiosqlite-0.17.0:
Successfully uninstalled aiosqlite-0.17.0
Attempting uninstall: aiosignal
Found existing installation: aiosignal 1.2.0
Uninstalling aiosignal-1.2.0:
Successfully uninstalled aiosignal-1.2.0
Attempting uninstall: cryptography
Found existing installation: cryptography 37.0.2
Uninstalling cryptography-37.0.2:
Successfully uninstalled cryptography-37.0.2
Attempting uninstall: aiohttp
Found existing installation: aiohttp 3.8.1
Uninstalling aiohttp-3.8.1:
Successfully uninstalled aiohttp-3.8.1
Attempting uninstall: zha-quirks
Found existing installation: zha-quirks 0.0.75
Uninstalling zha-quirks-0.0.75:
Successfully uninstalled zha-quirks-0.0.75
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
bellows 0.30.0 requires pyserial, which is not installed.
requests 2.28.0 requires charset-normalizer~=2.0.0, but you have charset-normalizer 2.1.0 which is incompatible.
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 asynctest-0.13.0 attrs-21.4.0 cffi-1.15.0 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.2 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 typing_extensions-4.2.0 voluptuous-0.13.1 yarl-1.7.2 zha-quirks-0.0.75 zigpy-0.47.0
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 12
+ sudo pip3 install --force-reinstall --upgrade zigpy-znp==0.7.0
Collecting zigpy-znp==0.7.0
Using cached zigpy_znp-0.7.0-py3-none-any.whl (124 kB)
Collecting jsonschema
Using cached jsonschema-4.6.0-py3-none-any.whl (80 kB)
Collecting async-timeout
Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting voluptuous
Using cached voluptuous-0.13.1-py3-none-any.whl (29 kB)
Collecting coloredlogs
Using cached coloredlogs-15.0.1-py2.py3-none-any.whl (46 kB)
Collecting pyserial-asyncio
Using cached pyserial_asyncio-0.6-py3-none-any.whl (7.6 kB)
Collecting zigpy>=0.40.0
Using cached zigpy-0.47.0-py3-none-any.whl (150 kB)
Collecting cryptography
Using cached cryptography-37.0.2-cp36-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.manylinux_2_24_aarch64.whl (3.6 MB)
Collecting aiohttp
Using cached aiohttp-3.8.1-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.2 MB)
Collecting crccheck
Using cached crccheck-1.1-py3-none-any.whl (29 kB)
Collecting aiosqlite>=0.16.0
Using cached aiosqlite-0.17.0-py3-none-any.whl (15 kB)
Collecting typing-extensions>=3.6.5
Using cached typing_extensions-4.2.0-py3-none-any.whl (24 kB)
Collecting humanfriendly>=9.1
Using cached humanfriendly-10.0-py2.py3-none-any.whl (86 kB)
Collecting importlib-resources>=1.4.0
Using cached importlib_resources-5.8.0-py3-none-any.whl (28 kB)
Collecting importlib-metadata
Using cached importlib_metadata-4.11.4-py3-none-any.whl (18 kB)
Collecting attrs>=17.4.0
Using cached attrs-21.4.0-py2.py3-none-any.whl (60 kB)
Collecting pyrsistent!=0.17.0,!=0.17.1,!=0.17.2,>=0.14.0
Using cached pyrsistent-0.18.1-cp37-cp37m-linux_aarch64.whl
Collecting pyserial
Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
Collecting zipp>=3.1.0
Using cached zipp-3.8.0-py3-none-any.whl (5.4 kB)
Collecting yarl<2.0,>=1.0
Using cached yarl-1.7.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (287 kB)
Collecting aiosignal>=1.1.2
Using cached aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
Collecting asynctest==0.13.0
Using cached asynctest-0.13.0-py3-none-any.whl (26 kB)
Collecting charset-normalizer<3.0,>=2.0
Using cached charset_normalizer-2.1.0-py3-none-any.whl (39 kB)
Collecting frozenlist>=1.1.1
Using cached frozenlist-1.3.0-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (145 kB)
Collecting multidict<7.0,>=4.5
Using cached multidict-6.0.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (96 kB)
Collecting cffi>=1.12
Using cached cffi-1.15.0-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (434 kB)
Collecting pycparser
Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Collecting idna>=2.0
Using cached idna-3.3-py3-none-any.whl (61 kB)
WARNING: Error parsing requirements for six: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/six-1.16.0.dist-info/METADATA'
Found existing installation: voluptuous 0.13.1
Uninstalling voluptuous-0.13.1:
Successfully uninstalled voluptuous-0.13.1
Attempting uninstall: pyserial
WARNING: No metadata found in /usr/local/lib/python3.7/dist-packages
Found existing installation: pyserial 3.5
ERROR: Cannot uninstall pyserial 3.5, RECORD file not found. You might be able to recover from this via: 'pip install --force-reinstall --no-deps pyserial==3.5'.
+ echo 13
+ sudo pip3 install --force-reinstall --upgrade zigpy-xbee==0.14.0
Collecting zigpy-xbee==0.14.0
Using cached zigpy_xbee-0.14.0-py3-none-any.whl (30 kB)
Collecting zigpy>=0.23.0
Collecting aiohttp
Collecting crccheck
Collecting pyserial
Collecting typing_extensions>=3.7.2
Collecting attrs>=17.3.0
Collecting async-timeout<5.0,>=4.0.0a3
WARNING: Error parsing requirements for pyserial: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/pyserial-3.5.dist-info/METADATA'
Installing collected packages: voluptuous, pyserial, crccheck, typing_extensions, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, asynctest, yarl, cffi, async-timeout, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, zigpy-xbee
Attempting uninstall: voluptuous
+ echo 14
+ sudo pip3 install --force-reinstall --upgrade zigpy-deconz==0.16.0
Collecting zigpy-deconz==0.16.0
Using cached zigpy_deconz-0.16.0-py3-none-any.whl (30 kB)
Collecting crccheck
Collecting aiohttp
Collecting pyserial
Installing collected packages: voluptuous, pyserial, crccheck, typing_extensions, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, asynctest, yarl, cffi, async-timeout, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, zigpy-deconz
+ echo 15
+ sudo pip3 install --force-reinstall --upgrade zigpy-zigate==0.8.0
Collecting zigpy-zigate==0.8.0
Using cached zigpy-zigate-0.8.0.tar.gz (37 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'error'
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [10 lines of output]
/usr/local/lib/python3.7/dist-packages/setuptools/_distutils/dist.py:257: UserWarning: Unknown distribution option: 'install_requires'
warnings.warn(msg)
/usr/local/lib/python3.7/dist-packages/setuptools/_distutils/dist.py:257: UserWarning: Unknown distribution option: 'tests_require'
warnings.warn(msg)
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: setup.py --help [cmd1 cmd2 ...]
or: setup.py --help-commands
or: setup.py cmd --help
error: invalid command 'egg_info'
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
+ echo 16
+ sudo pip3 install --force-reinstall --upgrade bellows==0.30.0
Collecting bellows==0.30.0
Using cached bellows-0.30.0-py3-none-any.whl (171 kB)
Collecting zigpy>=0.37.0
Collecting pyserial
Collecting click-log>=0.2.1
Using cached click_log-0.4.0-py2.py3-none-any.whl (4.3 kB)
Collecting pure-pcapy3==1.0.1
Using cached pure_pcapy3-1.0.1-py3-none-any.whl
Collecting click
Using cached click-8.1.3-py3-none-any.whl (96 kB)
Collecting setuptools
Using cached setuptools-62.6.0-py3-none-any.whl (1.2 MB)
Collecting aiohttp
Collecting crccheck
Collecting zipp>=0.5
Installing collected packages: voluptuous, pyserial, crccheck, zipp, typing_extensions, setuptools, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, asynctest, yarl, pure-pcapy3, importlib-metadata, cffi, async-timeout, aiosqlite, aiosignal, cryptography, click, aiohttp, zigpy, click-log, bellows
+ echo 17
+ sudo pip3 install --force-reinstall --upgrade zigpy==0.46.0
Collecting zigpy==0.46.0
Using cached zigpy-0.46.0-py3-none-any.whl (146 kB)
Collecting aiohttp
Collecting crccheck
Installing collected packages: voluptuous, crccheck, typing_extensions, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, asynctest, yarl, cffi, async-timeout, aiosqlite, aiosignal, cryptography, aiohttp, zigpy
Attempting uninstall: crccheck
Found existing installation: crccheck 1.1
Uninstalling crccheck-1.1:
Successfully uninstalled crccheck-1.1
Attempting uninstall: typing_extensions
Found existing installation: typing_extensions 4.2.0
Uninstalling typing_extensions-4.2.0:
Successfully uninstalled typing_extensions-4.2.0
Attempting uninstall: pycparser
Found existing installation: pycparser 2.21
Uninstalling pycparser-2.21:
Successfully uninstalled pycparser-2.21
Attempting uninstall: multidict
Found existing installation: multidict 6.0.2
Uninstalling multidict-6.0.2:
Successfully uninstalled multidict-6.0.2
Attempting uninstall: idna
Found existing installation: idna 3.3
Uninstalling idna-3.3:
Successfully uninstalled idna-3.3
Attempting uninstall: frozenlist
Found existing installation: charset-normalizer 2.1.0
Uninstalling charset-normalizer-2.1.0:
Successfully uninstalled charset-normalizer-2.1.0
Attempting uninstall: zigpy
Found existing installation: zigpy 0.47.0
Uninstalling zigpy-0.47.0:
Successfully uninstalled zigpy-0.47.0
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 asynctest-0.13.0 attrs-21.4.0 cffi-1.15.0 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.2 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 typing_extensions-4.2.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.46.0
+ echo 18
+ sudo pip3 install --force-reinstall --upgrade xmodem
Collecting xmodem
Using cached xmodem-0.4.6-py3-none-any.whl
Installing collected packages: xmodem
Attempting uninstall: xmodem
Found existing installation: xmodem 0.4.6
Uninstalling xmodem-0.4.6:
Successfully uninstalled xmodem-0.4.6
Successfully installed xmodem-0.4.6
+ echo 19
+ sudo pip3 install --force-reinstall --upgrade pycrypto
Collecting pycrypto
Using cached pycrypto-2.6.1-cp37-cp37m-linux_aarch64.whl
Installing collected packages: pycrypto
Attempting uninstall: pycrypto
Found existing installation: pycrypto 2.6.1
Uninstalling pycrypto-2.6.1:
Successfully uninstalled pycrypto-2.6.1
Successfully installed pycrypto-2.6.1
+ echo 20
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
Launch post-install of zigbee dependancy
Everything is successfully installed!
+ echo 21
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zigbee
+ rm /tmp/jeedom_install_in_progress_zigbee
Toujours KO chez moi sur l’installation des dépendances.
Je suis sur Rasberry à jour (j’ai fais un sudo apt update + sudo apt full-upgrade) et en Jeedom 4.2.19.
Pour Zigbee je viens également de faire la mise à jour en version 2022-06-23 11:08:56
Les dépendances bouclent à l’installation
J’ai essayé en redémarrant le Raspberry et ma clé Conbee2 est à jour de firmware.
zigbee_packages.log (39,7 Ko)
zigbee.log (875 Octets)
C’est la version de pip qui est pas jour il faut que tu ouvres un ticket au support avec accès support pour que je regarde ce qui cloche sur ton jeedom.
C’est fait, j’ai ouvert un ticket.
Quelle version du core ? Il faut être en 4.2.19
Démon NOK Dépendances NOK NOK - #8 par Sattaz
Jeedom de mon voisin en V4.2.19 et derniere version de Zigbee …
Bonjour @Loic,
J’ai ouvert un ticket depuis la box Atlas de mon voisin.
Merci pour votre aide!
Sebastien
Merci à tous ceux qui m’ont (nous ont) prodigués leurs conseils que j’allais justement appliquer. Finalement j’ai bien fait de patienter, je viens d’installer la màj du 2022-06-23 11:54:41 et tout est rentré dans l’ordre !
Et un grand merci @Loic
J’ai dû repasser mes 25 équipements à « actif » et « visible » mais tout va bien.
@plus
@Loic , on vient de voir la réponse du support et apparement c’est l’OS de Jeedom qui pose problème…
Il faut faire une réinstallation usine!
Purée c’est pas de bol, mon voisin a acheté une box Atlas il y a 2 mois et elle était deffectueuse après 1 mois (restore USB NOK) … donc retour et echange … et la c’est reparti avec un OS défectueux.
Dois-je essayer un restore avec l’image de restauration USB?
Puis mettre le backup de ce jour?
Merci,
Sebastien
De mémoire dans la réponse que je t’ai faite au support je parle aussi pour les backups et je le repete aussi dans le sujet principal sur le soucis zigbee
Excuse moi @Loic , je n’ai pas compris la procédure à appliquer.
il n’y a aucune mauvaise remarque, pas d’inquiétude … je suis informaticien et je comprends ce genre d’incident.
On a des backups de Jeedom mais pas du controleur Zigbee car mon voisin est/était (dans les 2 cas) entrain de construire son réseau …
Je souhaite juste avoir la bonne démarche, ai-je loupé un truc?
Sebastien
Mais la démarche pour faire quoi ? J’ai tout mis dans mon mail il n’y a rien de plus ou de moins a faire
Suite à dernière mise à jour Zigbee 2022-06-23 13:08:58 + Reboot Jeedom + Relance des dépendances, tout semble désormais OK maintenant. Zigbee est bien lancé et je commence à redécouvrir mes modules.
Tu es sérieux?
La raison est simple : je n’ai malheureusement pas le temps de faire des tests.
@Loic , dans l’email que mon voisin m’a transmis il y a marqué:
« il faut recuperer un backup, faire une reinstallation d’usine et remettre votre backup »
backup = backup de Jeedom de ce jour, vrai?
reinstallation d’usine = restauration image usine par USB, vrai?
Merci,
Sebastien
oui pour les 2
C’est désolant de lire ceci !
Pas de respect de votre part pour le travail accompli afin d’essayer de résoudre les problèmes.
Respect au développeur qui reste calme et prend encore la peine de vous répondre.
En feriez vous autant?
la raison est simple comme dit je n’ai pas le temps de tester je joue au pompier depuis vendredi sur ce sujet qui pour rappel proviens d’une nouvelle version zigpy bogué.
