Bonjour à tous, depuis la dernière mise à jour, le Demon reste en rouge et je n’arrive pas à relancer le plugin. Mes faibles compétences font que je ne trouve pas la solution. Pouvez vous m’aider?
+ touch /tmp/jeedom_install_in_progress_mymodbus
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/mymodbus/ressources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/mymodbus/ressources/post-install.sh
* Nettoyage de l'ancienne version *
Mon Mar 20 09:47:53 GMT 2023
* Installation de pyenv *
**** Configuration de pyenv...
* Configuration de pyenv avec python 3.9.16 *
WARNING: The directory '/root/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (23.0.1)
Requirement already satisfied: setuptools in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (65.7.0)
Collecting setuptools
Downloading https://www.piwheels.org/simple/setuptools/setuptools-67.6.0-py3-none-any.whl (1.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.1/1.1 MB 13.6 MB/s eta 0:00:00
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 65.7.0
Uninstalling setuptools-65.7.0:
Successfully uninstalled setuptools-65.7.0
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
pymodbus 3.2.1 requires setuptools<66.0.0, but you have setuptools 67.6.0 which is incompatible.
Successfully installed setuptools-67.6.0
Requirement already satisfied: requests in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (2.28.2)
Requirement already satisfied: pyserial in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (3.5)
Requirement already satisfied: pyudev in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (0.24.0)
Requirement already satisfied: pymodbus in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (3.2.1)
Requirement already satisfied: certifi>=2017.4.17 in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (from requests) (2022.12.7)
Requirement already satisfied: idna<4,>=2.5 in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (from requests) (3.4)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (from requests) (1.26.15)
Requirement already satisfied: charset-normalizer<4,>=2 in /var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.9.16/lib/python3.9/site-packages (from requests) (3.1.0)
Collecting setuptools<66.0.0
Downloading https://www.piwheels.org/simple/setuptools/setuptools-65.7.0-py3-none-any.whl (1.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 11.8 MB/s eta 0:00:00
Found existing installation: setuptools 67.6.0
Uninstalling setuptools-67.6.0:
Successfully uninstalled setuptools-67.6.0
Successfully installed setuptools-65.7.0
* Installation terminée *
Mon Mar 20 09:48:15 GMT 2023
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end mymodbus
+ rm /tmp/jeedom_install_in_progress_mymodbus
